air cond compressor bracket
I have been offered the chance to purchase a second hand air cond compressor bracket. Neither of us know what it is worth, other than both parties want a fair and reasonable exchange.
Can anyone one suggest what such an item would be worth. Greg
If it isn’t a genuine VAG, it probably isn’t worth considering even as a gift.
The aftermarket versions made locally were unbelievably rough and agricultural, on top of being incomprehensibly heavy.
It is still possible to source second hand genuine (cast aluminium) brackets from the US and Europe .
From: Syncro_T3_Australia@yahoogroups.com [mailto: Syncro_T3_Australia@yahoogroups.com ] On Behalf Of greg_navarro95
Sent: 07 February 2011 15:43
Subject: [Syncro_T3_Australia] air cond compressor bracket
Hi Greg,
for starters, it's worth every cent you spend on it, 'cose it's engineerd . I paid  +- 110 US and I think that was very reasonable indeed. Thanks BenT. Greg please check carefully the wiring towards the distributor which in my case was jammed between the the engine case and the extra heavy agricultural welded steel contraption. In my case the wiring was squashed flat and could have failed at any time.
When you instal the part you have to remove the 2 air intake tubes for access when taking off the 2 original clamps , you migth be able to reuse them or else use scew type clamps, preferrable the ones which don't cut into the rubber.  Hartmut  from Port also
Date: Mon, 7 Feb 2011 04:43:29 +0000
Sorry Greg, yes we are talking the genuine VW part of course.  And btw Stephan (Steve) Muller has got one for sale I believe. Try Kombi Rescue  0400 356 057       Hart
Date: Mon, 7 Feb 2011 16:14:33 +1100
Subject: RE: [Syncro_T3_Australia] air cond compressor bracket
Hi Greg,
Might mention that a good portion of cost is shipping to OZ from the US. If you can get one locally, there are definite advantages. And as Hartis mentioned, genuine VW only.
On Feb 6, 2011, at 9:14 PM, Hartmut Kiehn <hartis@live.com.au> wrote:
Hi Greg,
The bracket in question is a genuine VW part. See attached.
Yurik
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of greg_navarro95
Sent: Monday, 7 February 2011 12:43 PM
Hi Yurik,
in case Greg does  not want/need the part, could I stand in the row to buy it from you ?   Hartmut
Date: Mon, 7 Feb 2011 13:50:32 +0800
Yurik
Hartmut,
Will let you know.  Yurik
Sent: Monday, 7 February 2011 2:07 PM
To: Hartmut Kiehn
Hi Yurik,
Yurik
See attached ebay link. I bought one from this guy for $45us with bolts, this one has none. Was about $85aus shipped. Greg
http://cgi.ebay.com/ebaymotors/VW-Vanagon-AC-Compressor-Bracket-fits-83-91-yr-025-883C-_W0QQcmdZViewItemQQhashZitem53e1a76171QQitemZ360268128625QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Received: Monday, 7 February, 2011, 5:10 PM
Hartmut,
To: Hartmut Kiehn
Hi Yurik,
Yurik
Does anybody want a 20 years old sliding window?
Not genuine VW just the after-market type they put in them here.
Doesn't seem to have a brand name on it. Just been sitting in a room
under the house for the last four years.
Bruce
Gracemere CQ
PS Been sulking since I missed out on Shallow Crossing........
Pleased you all had a good time.. and Roger.. what can I
say...............
Left or right?
Middle or rear?
Black or silver?
> Bruce
> Gracemere CQ
> say...............
Questions Questions Phill
Left or right? Drivers side
Middle or rear?  Middle
Black or silver?  Black
Bruce
Hi Bruce I would be interested if it has provision for flyscreen and is a better fit in the corners than mine-photo attached. Greg E
--- On Mon, 7/2/11, Alison & Bruce Black <royalb@aapt.net.au> wrote:
Subject: Re: [Syncro_T3_Australia] Window
Received: Monday, 7 February, 2011, 6:18 PM
Bruce
I'll take it if it has the poorly fitting corners.
Price?
> Bruce
Average prices factory original sliding windows for either the sliding door or the opposite panel cost US$40-$80 used. To my knowledge, ALL Vanagons got middle sliders. They are quite plentiful here. The black ones tend to fetch more $. Of course, you can occasion find them for even less and often for more. It can be annoying when someone asks to source one then later find one for less then berate you for the effort.
As with anything distant from you, shipping is the deal killer.
ps: some Vanagon owners crave the clean look of solid glass middle windows.
On Feb 6, 2011, at 8:57 PM, "Les Harris" <leslieharris@optusnet.com.au> wrote:
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com ] On Behalf Of greg_navarro95
We only had sliders on Caravelles.
> BenT
> windows.
> wrote:
> > Greg,
> > If it isn��������t a genuine VAG, it probably isn��������t worth considering
> even as a gift.
> brackets from the US and Europe.
> > Les
We never got panel vans or T3's without the sliding windows.
People frequently those which he/she cannot have. Accessories or lack thereof on a T3 can be applicable in that situation.
>> BenT
>> windows.
>> wrote:
>>> Greg,
>> even as a gift.
>>> Les
Also,
RHD syncros & 2wd's central windows dont match those of the US models as the
sliding door window is different to that on the fixed side.
When I bought my syncro it had a US spec caravelle window in the sliding
door - it leaked like a sieve as it was installed backwards (the only way it
would fit as it was designed to be on the other side of the vehicle).
Wreckers often have these but also make sure they are from 1987 onwards as
the windows changed size slightly from then on.
Sent: Monday, February 07, 2011 7:38 PM
Subject: Re: Re: [Syncro_T3_Australia] air cond compressor bracket
>> BenT
>> windows.
>> wrote:
>> > Greg,
>> > considering
>> even as a gift.
>> > Les
Good point. In a pinch, you an cut and weld the frame smaller at least for the sliding door side. Guessing you wouldn't even need to cut the glass if the cut is made on the sliding side of the frame.
Sent from my Doka rear side sliders
On Feb 7, 2011, at 12:55 AM, "Mr Scott Pitcher" <spbconsulting@bigpond.com> wrote:
> Also,
> Skot
> From: <plander@optusnet.com.au>
>> Phill
>>> BenT
>>> windows.
>>> wrote:
>>>> Greg,
>>>> considering
>>> even as a gift.
>>>> Les
>> Yahoo! Groups Links
This is caused by the poor manufacturing of the local side window frames.   I had the same problem so I pulled them out and measured the frames.   I found that the top corner radius was wrong (too great) and that they were therefore around 6-7 mm short of filling the corner and allowing the rubber to fit correctly.
I fixed this by building up the frame with glass reinforced epoxy to restore the original correct frame size and corner radius.   It was a long and fiddly job but it was worth it.   I can’t remember if I put the pics in the photo section or not.
From: Syncro_T3_Australia@yahoogroups.com [mailto: Syncro_T3_Australia@yahoogroups.com ] On Behalf Of greg esposito
Sent: 07 February 2011 18:47
