Air Flow Sensor. Vanagon Syndrome
HAve finally put a document together describing how to fix the air flow
sensor.
If any one notices errors or omissions or wants to add to the document
please let me know.
PK
Tried to upload it here but would'nt let me...
The file is on the other Syncro site at:
http://f1.grp.yahoofs.com/v1/oFSjSeqbH0F7psCJPzTJMyJoVx2k7yRARzo_FJFfvNm
CSQIP4qQUGmZVQQwpyRy5uSXAqj6waQ9r-1RbI3lBi4MG2g/technica/Digifant%
20Fault%20Finding/Intake%20Air%20Flow%20Sensor.doc
> sensor.
> please let me know.
> PK
Peter,
That's not really Vanagon syndrome. Vanagon syndrome is caused by static electricity and happened on new vehicles also and was fixed by using a factory part connected into the wiring loom to the air-flow sensor. It mostly happened in low humidity places like Australia and parts of the US.
There is plenty on the internet about it.
Peter,
There's something odd going on there.  As owner of the website, I get an automatic email whenever a new file is uploaded.  I got one recently when Ken uploaded his front suspension file and I got one today to say that yours had been uploaded but when I opened the URL in the message, it was not on the Syncro_T3_Australia site.
Sometimes, there can be a delay with the Yahoo Groups server and the only thing that I can think of so far is that there is a lag.  I will keep an eye on it.
Sent: Tuesday, February 24, 2009 1:44 PM
Subject: [Syncro_T3_Australia] Air Flow Sensor. Vanagon Syndrome
sensor.
please let me know.
PK
http://f1.grp. yahoofs.com/ v1/oFSjSeqbH0F7p sCJPzTJMyJoVx2k7 yRARzo_FJFfvNm
CSQIP4qQUGmZVQQwpyR y5uSXAqj6waQ9r- 1RbI3lBi4MG2g/ technica/ Digifant%
20Fault%20Finding/ Intake%20Air% 20Flow%20Sensor. doc
Hi Phil
The fsctory fix was a 20uF capacitor across pins 2&3. They put the
cap inside a wire connector. Depends on who you talk to as to why the
cap was added. From an engineering perspective the cap would reduce
electrical noise. This 'noise' would be a fluctuation in the output
voltage mostly cuased from the crude wiper and carbon track setup.
Ever heard a crackling volume control pot?
Sure static electricity would also cause a problem and this is fixed
by earthing the entire airflow sensor. Aahh, forgot to mention that
in the document! Thanks!
PK
air flow
> > sensor.
document
> > please let me know.
> > PK
Nm
> Peter,
> Hi Phil
No it wasn't. There was a few other components.
On brand new cars?
I don't think so.
Also it rarely happens in Europe. High humidity.
I have one of these factory Harness, Part No. 025 906 302, for sale. $50 plus shipping.
Yurik
Sent: Thursday, 26 February 2009 1:15 PM
Subject: Re: Re: [Syncro_T3_Australia] Re: Air Flow Sensor. Vanagon Syndrome
OK 'that' factory fix was an active filter ( probably 2nd or 3rd
order. Uses capacitors, transistors and resistors).
A bit more elaborate than a single cap (first order filter) however
the single cap works fine in this application.
I noticed they mentioned 'vibration resonance'. This is just another
way of describing what I have said. It all comes back to the carbon
track and wiper.
And yes even new you could have experienced this problem. If you look
at the carbon through a microscope the surface is far from smooth.
Then you drag a chunk of brass across it expecting a steady current.
This will never happen. Even new carbon pots suffer this problem.
PK
> > Hi Phil
setup.
> On brand new cars?
> I don't think so.
Low humidity countries?
I think that there are two seperate issues here. Vanagon syndrome and worn AFM.
> track and wiper.
> PK
> > > Hi Phil
> setup.
> > On brand new cars?
> > I don't think so.
--- In Syncro_T3_Australia@yahoogroups.com, "Yurik Orlowsky"
<yuriko@...> wrote:
>Yurik,
I would like to purchase this item !
Tony
> plus shipping.
> Yurik
> plander@...
Syndrome
> Here is a picture of it.
> http://www.telusplanet.net/public/gary2a/rack/afmharness/afmharness.htm
Peter and All,
Had no luck using your doc link below ... can't get it to work despite
linking all the bits of the address back together. Any other options
please?
Peter, can you describe or show a pic as to where exactly did you run an
earthing link from the AFM .. I'm assuming it's not simply from the
aluminium enclosure. TIA.
--- In Syncro_T3_Australia@yahoogroups.com, "Peter" <kestel.p@...>
wrote:
> Hi Phil
> PK
> --- In Syncro_T3_Australia@yahoogroups.com, plander@ wrote:
> air flow
> > > sensor.
> document
> > > please let me know.
> > > PK
> Nm
> > Peter,
> > Phill
Hi Ken
Have deleted the document since it has to be amended after some
discussion (rightfully) about pedantics. It will be back later today.
The earthing is simple. Just use a lug and attach a wire anywhere on
the alu case to anywhere on the chassis.
PK
--- In Syncro_T3_Australia@yahoogroups.com, "Ken" <unclekenz@...>
wrote:
> Peter and All,
despite
> please?
run an
> --- In Syncro_T3_Australia@yahoogroups.com, "Peter" <kestel.p@>
> wrote:
> > Hi Phil
the
reduce
output
fixed
that
> > PK
> > air flow
> > > > sensor.
> > document
> > > > please let me know.
> > > > PK
> > Nm
> > > Peter,
to
like
> > > Phill
Tony,
Sorry the item is sold.
Yurik
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of tonyricketts99
Sent: Friday, 27 February 2009 1:29 AM
Subject: [Syncro_T3_Australia] Re: Air Flow Sensor. Vanagon Syndrome
<yuriko@...> wrote:
>Yurik,
Tony
> plus shipping.
> Yurik
On Behalf Of
> plander@...
Syndrome
href="http://www.telusplanet.net/public/gary2a/rack/afmharness/afmharness.htm">http://www.telusplanet.net/public/gary2a/rack/afmharness/afmharness.htm
Have downloaded the file successfully after ammendments. Still forgot
to add the bit about earthing the unit.
<leslieharris@...> wrote:
> Peter,
> From: Peter
air flow
> sensor.
document
> please let me know.
> PK
Nm
