Hi everyone.
OK so the gearbox saga continues.. I know it’s been ages, and the van’s been off the road all that time.
In the meantime, I’ve managed to:
- get married
- fall off my bike and shatter my left (dominant) wrist to smitherins
- go on honeymoon
- come back and here we are, wrist bones are mended but only about 1/2 way through rehab.
The gearbox did come out again, and Mike the specialist went right through it a second time and could find nothing wrong with it internally.
Fitted again (by his mate at a much lower cost), and then it needed a new slave cylinder as clutch wouldn’t hold pressure. Tested, still popping out of 4th gear.
Put it on the ramp, disconnected the shifting mechanism, put it in fourth, ran it and it popped right off. That means the gearbox 100%, right??
I said please put it back together, refund the rebuild $$, and I’ll drive it home and see if Subagears is now the only way to a ($10k+) fix.
Then overnight Mike couldn’t sleep and wondered if he’d put the spacer on the gearbox shifting shaft on the correct side. Went back, swapped it around, took it for a test and said it’s no longer popping out (!)
I went to pick it up this eve to drive it home. It does mostly stay in 4th now, but still randomly pops out from time to time.
The whole shifting mechanism is SO stiff going back and forth it’s almost impossible to get it in first, and from 4th with my broken wrist still recovering I almost can’t get it to 3rd.
I have absolutely no idea wtf is going on, but it seems obvious the entire shifting mechanism is in dire need of checking / adjustment. Is there anyone here with strong knowledge / experience with this? I have a Haynes manual (non-syncro unfortunately) which isn’t of much help.
For the history:
- when I got the van it shifted just fine (2018)
- a few 1000 kms down the road it started to pop out of 1st and 4th
- I had the gearbox rebuilt (2019) and then it was ok again
- fitted the EJ25 in 2021 and had some great long trips all over WA, prolly did about 10-12,000 kms
- early 2024 it started popping out of 4th gear only, just a few odd times
- a couple of months later it wouldn’t stay in 4th under load at all
- had the gearbox taken out (by Vdub Repairs & Spares Fremantle) and taken to Mike (see above) who found a number of worn parts inside. All of these were replaced, gearbox rebuilt, also put in a lower ratio 4th gear.
- had Vdub r&s refit it, who tested and told me gearchange was stiff but other than that all fine (note: gearchange had never been stiff before)
- picked it up and as soon as I drove it popped out of 4th. Vdub r&s swore it had tested ok, and said it must be a gearbox problem.
Am I going mad, or does this point at Vdub Spares & Repairs doing a shit job on the refit? I’m sure they’ll say they didn’t touch it - just disconnected/reconnected, but surely part of the job is making the needed adjuatments so it all works properly?
Sorry for the long-winded post I am just venting a massive amount of frustration.
Any suggestions / help / pointers / gear shift mechanism adjustment experience highly welcome!
thanks all
