Hi group, need to replace the rotors on my Van Cafe Audi based big brake conversion. Does anyone know the Audi model that the rotors come from? Trying to source them localy rather than shipping from the states. Have so far narrowed the search to an Audi a3 or a4. they seem to have the same dimensions for the rotors but not sure of the centre bore and size of the stud holes they come with. Thanks , Eddie.
Eddie,if they are the same as mine(smallcar),the rotors are from a Passat.The calipers were from an early Audi 100 or 200.I think I still have the boxes with part numbers,I will look on Monday.
BenC
BenC
Eddie,no luck with rotor part numbers as all I had was UPS boxes.sorry.
BenC
BenC
> BenC
Hi,
I have just received my big brake kit from Smallcars and I have attached a photo of the label on the box of the rotor.
They are made by TEXTAR.
Hope this helps.
Gold Coast
BenC
> BenC
is that just the front only ?
Sent: Tuesday, 19 February 2013 9:50 AM
Subject: Re: [Syncro_T3_Australia] Re: Big brake rotors.
Hi,
Hope this helps.
Gold Coast
BenC
> BenC
Yes. Front only.
Hi,I have just received my big brake kit from Smallcars and I have attached a photo of the label on the box of the rotor.They are made by TEXTAR.Hope this helps.CheersPeterGold CoastOn 18 February 2013 21:37, Ben <bencroft96@yahoo.com> wrote:
BenC
> BenC
OK - i previously asked MAO of small car to get me the model cars they come from - still trying to find my old email covering both front and rear.
Sent: Tuesday, 19 February 2013 10:01 AM
Yes. Front only.
BenC
> BenC
I have done some detective work on the TEXTAR website. Attached are 4 screen shoots and a link to the website.Enter article number: 92083600
Thanks all for the detective work. Have a few leads now & have found rotors with the right specs on DBA's website that fit an audi A3. Will also check the rotors on my in laws' Passat to see if these are the same.
Cheers Eddie.
Cheers Eddie.
--- In Syncro_T3_Australia@yahoogroups.com, Peter Kolevas <peter.kolevas@...> wrote:
> Hope this helps.
> Peter
> http://www.brakebook.com/bb/textar/en_GB/articleSearch.xhtml?result=1361235563083&showResult=1
Picked up my new rotors yesterday at my local brake supplier. They are RDA brand , with all the right specs to suit the van cafe big brake kit. They are slightly bigger than the small car kit, 288 vs 282, but all other dimensions are the same. I got the better than sandard rotors as these are grooved and dimpled. Cost was $210. Will report on performance when I get them on.Thanks to Peter for the link to the Textar website. Eddie.
> Hi,
> Hope this helps.
> Cheers
> Peter
> Gold Coast
> > BenC
> > > BenC
Installed the rotors & all is working great. Have a question for Peter & Ben. I believe you both have the small car kit & if this kit was supplied with the rotors from a passat & have a 68mm centre bore what, if anything, did you or did small car recommend you do, with the small difference in the 68mm c/b on the rotors and the 66.6mm hub on the van? I made up some spacers to take up the slack & centre the rotor but I'm curious to know if you had to do the same.
> --- In Syncro_T3_Australia@yahoogroups.com, Peter Kolevas <peter.kolevas@> wrote:
> > Hi,
> > Hope this helps.
> > Cheers
> > Peter
> > Gold Coast
> > > BenC
> > > > BenC
Eddie,I just bolted it all up and got some brake pipes made up.The rotors were Zimmerman.S/C did do some machining,but I thought it was with the calipers,I cant remember.Do a search with previous posts.
BenC
BenC
> > > Hi,
> > > Hope this helps.
> > > Cheers
> > > Peter
> > > Gold Coast
> > > > BenC
> > > > > BenC
I have SCP rotors all round.
No centering / ring used just 68mm bore. No balance issues what so ever.
Sent from my iPhone
Sent from my iPhone
>>> Hi,
>>> Hope this helps.
>>> Cheers
>>> Peter
>>> Gold Coast
>>>> BenC
>>>>> BenC
Eddie,a bit late but found this info today.
The SCP Audi big front brakes,the brake pads suit calipers from,
Audi 80 93-95 Quattro
200 87-91 Quattro turbo
A6 94-98
Quattro 93-95 2.2
S4 93-95 sedan
and the rotors are from 96-05 Passat.
BenC
A6 94-98
Quattro 93-95 2.2
S4 93-95 sedan
BenC
--- In Syncro_T3_Australia@yahoogroups.com, Hamish Dobson <dobson_hamish@...> wrote:
> Sent from my iPhone
> >>> Hi,
> >>> Hope this helps.
> >>> Cheers
> >>> Peter
> >>> Gold Coast
> >>>> BenC
> >>>>> BenC
> > Yahoo! Groups Links
Thanks Ben and Hamish. The rotors I got are from a Passat as Ben has described. I was curious as to whether the bigger centre bore on these would make for some vibrations & Hamish has answered that. I still don't know which rotors Van Cafe supply with their kits, as the c/b is the correct size. Maybe they get something with a smaller bore & then machine them. I' m just happy I've found a local supply that works well,and at a reasonable price. Eddie.
> A6 94-98
> Quattro 93-95 2.2
> S4 93-95 sedan
> BenC
> --- In Syncro_T3_Australia@yahoogroups.com, Hamish Dobson <dobson_hamish@> wrote:
> > Sent from my iPhone
> > >>> Hi,
> > >>> Hope this helps.
> > >>> Cheers
> > >>> Peter
> > >>> Gold Coast
> > >>>> BenC
> > >>>>> BenC
> > > Yahoo! Groups Links
