BMW e30 brake booster.Modified Drivshaft.Front CVs.Skid plate
As the year comes to an end,and my time runs out,today,I installed the bigger BMW booster to my bus.
It is not something that is a needed to convert a t3/t25 to Subaru power but,with Audi ventilated,twin spot calipers,coming early next year,the BMW booster is the largest standard fit you will squeeze under the instruments.
I had already felt better pedal pressure since the engine conversion.(suspect better engine vaccum).
I can report that with the bigger 10'' BMW booster,I have a lower pedal but,I have about 20% more braking with the same pedal effort with the VW 9''er.
The booster came from a 80,s to 90,s model 3 series BMW.
To get it in there,remove your VW one first.
From the BMW booster, 25mm has to be cut off the threaded rod,(to the pedal).
The original VW clevis has to be drilled and tapped(M10x1.5).Run a die down the thread.
Adjust the clevis,down the threaded rod,to 111.5mm from the centre of the clevis pin to the booster mounting face.This is very important to get the right amount of free play.
To get to the booster, the instrument panel is removed,master cylinder removed,then the pedal box is unbolted.I also removed the clutch slave from the pedal box,so I could pull the booster up higher.
Two people can make this job easier.
I have AC.3mm was trimmed from some plastic.
Not a job to take on for something to do.
Pulls up much better at low speed and better again 100+.
Hardy Spicer driveshaft,with bigger common unis and slip yoke vibrated at first.Returned to Hardys for another check and balance.Fitted and tested Ok.
Front Cvs replaced with the 'last ones' Lobro inners,cleaned and repacked outers.All cluncks and knocks stopped.
It sure is a great feeling driving a freshly powered and serviced AWD vehicle.
I lenghtened the skid plate 50mm, and some plates have been cut to bolt to the skid plate,to protect the sump,trans and drive shaft.
Photos up soon.
Well done Ben, she must be a dream to drive now. With your pedal height, (,I have a lower pedal but,) is that applied or static. The clevis adjustment is to adjust your static height. Greg E
--- On Mon, 6/12/10, bencroft96 <bencroft96@yahoo.com> wrote:
Subject: [Syncro_T3_Australia] BMW e30 brake booster.Modified Drivshaft.Front CVs.Skid plate
Received: Monday, 6 December, 2010, 10:48 PM
Photos up soon.
Ben, I don't know whether this is the problem but you should only be cutting about 6.5mm of the threaded rod not 25mm. Greg
--- On Tue, 7/12/10, greg esposito <gregespo73@yahoo.com> wrote:
Subject: Re: [Syncro_T3_Australia] BMW e30 brake booster.Modified Drivshaft.Front CVs.Skid plate
Received: Tuesday, 7 December, 2010, 10:41 AM
Photos up soon.
Ben, I would agree with Greg here – I found in my conversion it was not necessary to cut off anything from the threaded rod having sufficient adjustment as is. The actual free-play on the clutch pedal is adjusted on the actuating rod on the clutch master cylinder. You will see a significant improvement with the Audi twin cylinder calliper. Good work, enjoy your “new” syncro.
Yurik
Sent: Tuesday, 7 December 2010 7:52 AM
Photos up soon.
Well done Ben.
I will be checking all this out when we meet for the Point Plommer Rd challenge - hopefully with less monsoonal rain than last year.
Sent: Monday, December 06, 2010 10:48 PM
Photos up soon.
Ben Good to hear you got the conversion finished.
I was just about to inquire as to how it was all going.  I will be upgrading my brake system over christmas, if it all arrives in time.  How many hours do you think it took you to swap the booster over?
Michael Roberts
Sent: Tue, December 7, 2010 2:43:21 PM
Well done Ben.
Photos up soon.
Skot/Ben,
Maybe you meet at my place before the Plomer challenge..Hart
Sent: Tuesday, 7 December 2010 2:43 PM
Well done Ben.
Photos up soon.
Sounds great.
Sent: Tuesday, December 07, 2010 7:12 PM
Subject: RE: [Syncro_T3_Australia] BMW e30 brake booster.Modified Drivshaft.Front CVs.Skid plate
Skot/Ben,
Well done Ben.
Photos up soon.
Very good Greg,that was a typo.Approx 6.5 mm is the correct amount to cut off the BMW booster.The clevis adjustment of 111.5mm off the booster mounting face is for the correct free play so that the master cylinder is not applied all the time.
> --- On Tue, 7/12/10, greg esposito <gregespo73@...> wrote:
> From: greg esposito <gregespo73@...>
> Â
> --- On Mon, 6/12/10, bencroft96 <bencroft96@...> wrote:
> From: bencroft96 <bencroft96@...>
> Â
> Photos up soon.
> Â
Skot,Hart and other Christmas mid coasters.
There is no challenge to do PP.Last year was about as difficult as I have seen it in along time.
I dont know if I will do it this year,but are keen to catch up for a few,and some photos etc.Skot,I think you may be camping one night at Harts.Is this still on?Maybe Harts place would be the best place to meet up.
I do not get up there to the 27th Dec.Skot I think you are there till the 31st??
Whilst I am up there,daily I drive down to Cresso on Russells Fire Trail,Skot look it up.It is a easy fun track.There is heaps of tracks just north of Cresent and Hungary Head Beach,which can be difficult to get off some years.(not anymore I suspect).
Cant wait to get up to Hat Head.
> Skot/Ben,
> Well done Ben.
> Skot
> From: bencroft96 <mailto:bencroft96@...>
> 9''er.
> pedal).
> the thread.
> vehicle.
> Photos up soon.
Two typos in that last post.6.5mm was trimmed from the booster threaded rod.also,I repacked the inner cvs and replaced the outers(lobro).sorry.
--- In Syncro_T3_Australia@yahoogroups.com, "Yurik Orlowsky" <yuriko@...> wrote:
> Ben, I would agree with Greg here â€" I found in my conversion it was not necessary to cut off anything from the threaded rod having sufficient adjustment as is. The actual free-play on the clutch pedal is adjusted on the actuating rod on the clutch master cylinder. You will see a significant improvement with the Audi twin cylinder calliper. Good work, enjoy your “new” syncro.
> Yurik
> Photos up soon.
We get to Cresso on 25th and get kicked out on 1st Jan (Sat - Sat). I was hoping maybe just after that say the Saturday night @ Hartmuts in Port (1/1/11)?
Sent: Tuesday, December 07, 2010 11:45 PM
Subject: [Syncro_T3_Australia] Point Plomer-what challenge??
> Skot/Ben,
> Well done Ben.
> Skot
> 9''er.
> pedal).
> the thread.
> vehicle.
> Photos up soon.
Whoops,
I think I meant stay @ Hart's on 2/1/11?
> Skot/Ben,
> Well done Ben.
> Skot
> 9''er.
> pedal).
> the thread.
> vehicle.
> Photos up soon.
How about it Hart.A gathering at your place on th 2/1/11?
> Whoops,
> Skot
> From: bencroft96
> --- In Syncro_T3_Australia@yahoogroups.com, "Hartmut Kiehn" <hartis@> wrote:
> > Skot/Ben,
> > Well done Ben.
> > Cheers,
> > Skot
> > From: bencroft96 <mailto:bencroft96@>
> > 9''er.
> > pedal).
> > the thread.
> > vehicle.
> > Photos up soon.
Fine with me, what time??   Hart
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of bencroft96
Sent: Wednesday, 8 December 2010 8:26 AM
Subject: [Syncro_T3_Australia] Re: Point Plomer-what challenge??
> Whoops,
> Skot
> From: bencroft96
> > Skot/Ben,
> > Well done Ben.
> > Cheers,
> > Skot
> > 9''er.
> > pedal).
> > the thread.
> > vehicle.
> > Photos up soon.
Maybe around or just before lunch?
We can work that out the day before. We cant plan these things too much.
Sent: Wednesday, December 08, 2010 8:31 AM
Subject: RE: [Syncro_T3_Australia] Re: Point Plomer-what challenge??
> Whoops,
> Skot
> From: bencroft96
> > Skot/Ben,
> > Well done Ben.
> > Cheers,
> > Skot
> > 9''er.
> > pedal).
> > the thread.
> > vehicle.
> > Photos up soon.
Sorry, mate, it was meant to be a joke  Hart
Sent: Wednesday, 8 December 2010 9:30 AM
Subject: Re: [Syncro_T3_Australia] Re: Point Plomer-what challenge??
> Whoops,
> Skot
> From: bencroft96
> > Skot/Ben,
> > Well done Ben.
> > Cheers,
> > Skot
> > 9''er.
> > pedal).
> > the thread.
> > vehicle.
> > Photos up soon.
