I had a decoupler installed. I would recommend it for all syncros. Because of their age, it is quite possible that the VC is not quite as good as new, or the front diff may have an issue (or starting to develop one) and the same for the side shafts and or the alignment. So on tarmac, I have AWD is disengaged and as soon as I hit the dirt, I engage AWD. This is done on the fly although you use the clutch with engaging and disengaging.
To decoupler also helps on tarmac if your front to rear tyres are not equally worn. Unevenly worn tyres place no strain on the drive train off road, as there is constant wheelspin to absorb any buildup of strain.
Before fitting the decoupler, I experimented extensively by removing the propshaft but there was not material difference in fuel consumption. Therefor should you experience an improvement in fuel consumption by removing the propshaft, it may indicate that the VC, front diff, side shafts or alignment is not well, thereby causing additional strain on the drivetrain.
The syncro gearbox is essentially based on the 2WD 2,1i gearbox and for this reason I can not understand why running in 2WD as opposed to 4WD would create greater strain on the gearbox.
Perhaps your experience is different.
Regards, |
Piet Coetsee |
Managing Director |
T: 021 910 2654 F: 086 20 20 204 E: piet@smartpropertyservices.co.za W: www.smartpropertyservices.co.za |
From: Syncro_T3_Australia@yahoogroups.com <Syncro_T3_Australia@yahoogroups.com>
Sent: Saturday, 06 October 2018 10:27 AM
Subject: Re: [Syncro_T3_Australia] Decouplers
Gaetan,
Consider also that there could be worn universal joints in the prop shaft plus and the angles on the drive shaft faces may be incorrect.
Ideal - aim for 4 degrees down at each face - or more, make both faces the same angle.
It's an interesting fact of physics on the way in which the input shaft can turn less or more then the output shaft if the angles are different.
watch this
