Disc Brakes
Hi:
Opinions on rear Disc Brakes?
Our syncro has 16" wheels... Pros... Cons...
Regards,
Hector
You won't need extra breaking force and with the standard conversions
(e.g. Golf 3 / 245x10) you won't get it - but: Discs love mud, drums
hate it :)
.martin
On 12.05.2009, at 20:20, iatrade wrote:
> Hi:
> Regards,
> Hector
Martin Henning, DM5OY
martin@easy2design.de
http://log.tigerbus.de
Martin,
Mud is a concern... dirt roads are prevalent... I grew-up in Peru, dirt roads are all-over Central and South America... Our first plan trip is around South and Central America from Miami, Florida starts this coming January.
What would be your recommendation doing both extra breaking force other pros.
Hector
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com]On Behalf Of Martin Henning
Sent: Tuesday, May 12, 2009 5:31 PM
Subject: Re: [Syncro_T3_Australia] Disc Brakes
hate it :)
.martin
> Hi:
> Regards,
> Hector
martin@easy2design. de
http://log.tigerbus .de
Personally I have ATE57 (Audi 100/A6 C4 e.g. '96) on 288x25 vented in
front and Girling/Lucas38 (Golf 3 '97) on 245x10 non-vented in the
rear. This setup even fits under my 15" (with 30x9.5R15) rims, which
was very important. I don't want 16", I want as much rubber under my
a** as possible :) I guess the cheapest and easiest option would be
that G60 brake. You can buy a complete set at smallcar in the US. I
wouldn't recommend the SA setup for traveling around the world i
guess, as these parts are much harder to find than those standard Audi/
VW parts. Even though the actual caliper on the SA brake is supposed
to be an ATE FN60 used on several Ford (XR3i up to '98) and the disk
can be replaced by some Audi model (Audi 80 Quattro/ Audi S2)......
Anyway, my setup can also be bought in Germany from Raimund Feussner
(ray [at] v6bus.de), who is selling the complete setup with adapter
plates, all screws and every part from calipers to discs brand new for
around 1850 EUR. Smallcars setup for front ( http://smallcar.com/index.php?act=viewProd&productId=18
) and rear ( http://smallcar.com/index.php?
act=viewProd&productId=71 ) will be around US$ 1400.
There are numerous other brake upgrade options, ranging from Porsche,
to Mercedes and Ford. I would recommend to take something from the
Audi/VW toolboxes and not start that crazy mix vanagon - at least if
you're going to travel.
About vented discs: Some people over here don't recommend vented discs
as they will be full of mud after plunging into some muddy lake. They
see the discs rust away in no time. I can't support this argument, in
my opinion the discs will be worn out earlier than they rust away -
maybe there is local experience on that matter? The solution for these
people over here is easy: Front stays stock, rear gets upgraded to
245x10 discs, which gets the drum out of the way. They obviously do
not need better brakes, that just want to get rid of the drum. I
personally also want larger AND vented discs in front, as this is the
only way to keep a heavy bus on the road in summer time somewhere in
the mountains.
Something "cheap" that helps all setups: Change your brake booster in
front vom 8" to 10". That of course doesn't make the brake any better,
but it's certainly the easiest way to make it feel better. No, MUCH
better. You can fit a whole line of BMW E30 brake boosters in there,
which can - at least over here - be bought on ebay for close to
nothing. The exact models would be (posted by someone on some maling
list - NOT my know how here! [I'm using one, though :)]:
"The BMW part number is 34331157416 and it can be found in these models:
E28: Details on E28
E28 528e SEDAN, U.S.
E28 518 SEDAN, Euro
E28 518i SEDAN, Euro
E28 520i SEDAN, Euro
E28 524d SEDAN, Euro
E28 524td SEDAN, Euro
E28 525e SEDAN, Euro
E30: Details on E30
E30 318i COUPE, U.S.
E30 318i SEDAN, U.S.
E30 325e SEDAN, U.S.
E30 325e COUPE, U.S.
E30 325i COUPE, U.S.
E30 325i SEDAN, U.S.
E30 316i TOURING, Euro
E30 318i TOURING, Euro
E30 320i TOURING, Euro
E30 324td TOURING, Euro
E30 325i TOURING, Euro
E30 316 SEDAN, Euro
E30 316 COUPE, Euro
E30 316i SEDAN, Euro
E30 316i COUPE, Euro
E30 318i SEDAN, Euro
E30 318i COUPE, Euro
E30 318i CONVERTIBLE, Euro
E30 318is COUPE, Euro
E30 320i CONVERTIBLE, Euro
E30 320i COUPE, Euro
E30 320i SEDAN, Euro
E30 320is SEDAN, Euro
E30 320is COUPE, Euro
E30 323i COUPE, Euro
E30 323i SEDAN, Euro
E30 325i CONVERTIBLE, Euro
E30 324d SEDAN, Euro
E30 324td SEDAN, Euro
E30 325e SEDAN, Euro
E30 325e COUPE, Euro
E30 325i COUPE, Euro
E30 325i SEDAN, Euro
E30 325ix SEDAN, Euro
E30 325ix COUPE, Euro
Z1: Details on Z1
Z1 Z1 ROADSTER, Euro"
Have fun,
Martin
On 13.05.2009, at 00:05, <herquiaga@iatrade.com>
<herquiaga@iatrade.com> wrote:
> Martin,
> other pros.
> Hector
> hate it :)
> .martin
> > Hi:
> > Regards,
> > Hector
> > Yahoo! Groups Links
