Drive-train Problems
OK Phill, thanks for that. I'll get onto them and ask what the
difference in dimensions is.
Michael.
> Here is the information that I have from Rudi.
> here is the info about uni/joint
> HARDY SPICER
> K5-A590
> U/J-KIT EG/WALTER SCHEID/BYPY
> CODE 244 507
I spoke with Hardi Spicer Phill, and they advised that the K5-A590
is an Agricultural Universal and that the K5-A767 is the correct
Syncro Uni. The former is 27mm diameter cap and 70mm overall, making
it .2mm longer/wider. I guess it could be used with a little
grinding of the circlips. With a price of just $28.50 it's certainly
worth some thought.
Michael.
> HARDY SPICER
> K5-A590
> CODE 244 507
> > blayney_michael <embkb2@...> wrote:
> > Thanks for the advice Andy. I checked and sure enough, with a
lever on
> > the Uni, it shows up plainly. I'll replace that and then see
what
> > gives.
> > I rang Hardi-Spicer in Adelaide and they have only one listing
for
> > Volkswagen Unis - with a cup diameter of 27mm and overall
dimension
> > with cups on of 69.8mm. That seems the right figures.
> > They quoted $190.00 each, with 2 available in Australia - one in
> > Brisbane and one in Melbourne. I've grabbed the one in Melbourne
so
> > you might be able to grab the Brisbane one. The Part No. was K5-
A767.
> > Michael.
I think that some research is needed here. If you use the wrong one it will cause big problems and damage! I wouldn't just go on price and I never believe salesmen.
Did the salesman measure the old one?
> worth some thought.
> Michael.
> > HARDY SPICER
> > K5-A590
> > CODE 244 507
> > Phill
> lever on
> what
> > > gives.
> for
> dimension
> so
> A767.
> > > Michael.
Phill, you have lost me somewhere along the line there. I did not buy
my Syncro new and have no way of finding out the previous replacements.
If I measure a failed Uni, how will I know if it failed 'cos of old
age or it failed because it was incorrect? At this stage I think I'd
prefer to take the Hardi Spencer listing even tho' it's more expensive.
Michael. (not meaning to create any animosity)
See if you can get a part number from other sources. Where did the salesman get the part number from? Does Rudi have any spares?
I am not saying that my part number is correct, but there is a big chance that the salesman's catalogue is wrong as most of them are. What does the listing say?
Try some other forums. SA or US etc.
> > Phill
