Gary, the manual states,to pull or install drive shaft,loosen diff and transmission bolts.I have never done this. I have no decoupler and drive around 11 months a year in 2wd.I did not have any vibrations last year.I do now have a slight vibration between 60 and 65 kays.I am keen to try your suggestions on Monday and will report back.I was going to try the shaft in different positions,as my marks,didnt line up exactly.Could not work that out.
--- In
Syncro_T3_Australia @yahoogroups. com, Gary Cookson <gary@...> wrote:
> Ben
> I've had new ujs pressed into my driveshaft but i have yet to refit it
> to test, previously it was vibrating. The rubber donut usually lasts
> ok, it is the bronze bush on the shaft it sits on that cause problems.
> Google Aidan Talbot in the UK he has a stripdown on his site.
> There has been recent discussion on a new technique for curing
> driveline vibrations, that of slackening of the diff mounts, go for a
> short drive and then retighten, I believe. Someone correct me if i'm
> missing something.
> CV Protectors would probably have to be sourced overseas but you could
> make them really.
> Gary
> [2 0 / 2 1 Design]
> 28 Gwynne St
> Richmond
> Vic 3121
> gary@...
> www.twentytwentyone .net
> Tel 3 9429 1868
> Fax 3 9421 1110
> Mob 0417 352782
> On 18/11/2009, at 10:36 PM, bencroft96 wrote:
> > Hi Group,Great to hear that DOTVW was a good weekend,(with some
> > unexpected complications) .Maybe next year there can be even more
> > Buses!
> > Some questions to all,
> > Has anyone ever had their Driveshaft balanced?
> > Does the dampner ever wear out?
> > When you pull your tailshaft out,do you follow the manual?,I never
> > have.
> > My vehicle now drives better than it ever has.I now have new
> > shockies all round,poly urathane lower bushes,bushes, were badly
> > worn out,Yoky, Geolander 16'' tyres,new front cv boots and badly
> > needed wheel alignment.Took the bus out Boat Harbour Monday for test
> > drive,She'll be right for Christmas.
> > Front CV protectors,are they in the country.Does anyone know if I
> > can get them before Christmas?
> > Is anyone in the market for a Decoupler?Good time to get one.A full
> > kit from Stuart will cost 12 hungey,+machining of nose cone.Whats
> > the cost in that?Does anyone know who can do the machining?
> > One from the States,with no machining,is going to cost way over 2
> > Grand.What do you guys think?Does anyone want to get one too?
> > Right into my rebuild know,Its funny how Syncro's get easier to work
> > on , the more you work on them!
> > Give a wave on the road.
