Front CV Replacement
To remove the front outer CV joint, is a special tool required, or do I
just tap the axle out with a hammer?
What is required to replace the front wheel bearing?
It's all explained in this CV joint maintenance/replacement article.
Print yourself out a copy for easy reference   .............
goto: http://www.van-cafe.com/vanagonparts.jsp?pa=ip&ip=1150562894
Can't see anything on removing fronts there.
> Phill,
> <http://www.van-cafe.com/vanagonparts.jsp?pa=ip&ip=1150562894>
> I
> > Phill
I need step 5.5. (How to remove the outer axle)
I
What is it then, CV/axle separation or axle removal, clearly 2 different
questions.
I believe my reply answered your first query.
> > Ken unclekenz@... wrote:
> > Phill,
> > Cheers.
do
> > I
> > > Phill
> Phill,
> questions.
Axle from the bearing
