Front diff questions
Well my front and rear locking gearbox arrived today after being in transit for 4 months. Think I have a costly repair ahead of me as I found metal shavings stuck to the front diff drain plug. The front diff lock actuating rod is pushed all the way in yet the differential isn't locked? Does this mean the ring and pinion are stuffed or the actuating rod sheared or more likely both?
Metall shavings on the drain plug are normal, that is no indicator for
damage, unless you have real clunkers sticking there :)
Martin Henning, DM5OY
martin@easy2design.de
http://log.tigerbus.de
thanks martin. Hoping only the actuating rod is sheared off and pinion is fine. I'll check it out tomorrow.
Date: Thu, 3 Sep 2009 11:28:22 +0200
Subject: Re: [Syncro_T3_Australia] Front diff questions
martin@easy2design. de
http://log.tigerbus .de
Check out The Great Australian Pay Check Take a peek at other people's pay and perks
You should be able to check that simply by turning the "input shaft",
no?
> From: martin@easy2design.de
> > Yahoo! Groups Links
You should be able to check if your diff lock works by turning the input shaft and seeing whether the two CV outputs from the gearbox both turn in the same direction (locked) or turn in different directions (unlocked).
I could check mine by a little bit of compressed air in one of the vacuum servo tubes.
If that all works and it is not noisy it should be all good.
Sent: Thursday, September 03, 2009 7:25 PM
Subject: [Syncro_T3_Australia] Front diff questions
Checked by AVG - www.avg.com
Version: 8.5.409 / Virus Database: 270.13.76/2342 - Release Date: 09/02/09 18:03:00
Hey Martin,Scott,
yep that was how I came to the idea that either the pinion gear or rod is worn because the diff will not lock with the rod all the way in when spinning the cv outputs. If I remove the retaining pin on the rod and push it in further than intended it will lock. Is it possible to completely remove the rod without opening up the diff or is it secured from the inside? Cheers, erik
Date: Thu, 3 Sep 2009 22:15:07 +1000
Subject: [Syncro_T3_Australi a] Front diff questions
Click Here View photos of singles in your area
