How many klms has the beast done?
Sent: Thursday, 14 January 2010 5:21 PM
Subject: [Syncro_T3_Australia] Re: Oil light and buzzer
Hi All,
Just in case anyone else comes across this one, I have found an interesting article on the "Flashing Oil Light and Buzzer Syndrome on Vanagon 86-91"
http://www.vanagain.com/buzzer2.htm
Another syndrome that affects the vanagon apparently.
So hopefully this is just electrical, though it is possible that my engine is getting too long in the tooth.
Sam
> I'm not sure, but I think that the buzzer should only work over 2000rpm and it only works on the high pressure sensor.
> > heysamuelarnold <me@...> wrote:
> > Phill, it was definitely the light and warning buzzer, but both were
> > going bananas just at idle?? Otherwise even my better half commented
> > that the engine sounded fine? Defective high pressure switch?
> > :) Sam
> > --- In Syncro_T3_Australia@yahoogroups.com, plander@ wrote:
> > > What brand of filter do you have now?
> > > What brand of oil do you have now?
> > > The high pressure switch operates the light and warning buzzer and
> > only works over 2000rpm. The low pressure only operates the light but at
> > all times.
> > > It could be your high pressure switch defective if the pressure is OK.
> > Are there any bearing rattles?
> > > Never ever buy oil filters from Repco, Autobahn, Supercheap etc. They
> > do not sell the correct ones.
> > > > heysamuelarnold <me@> wrote:
> > > > Hi all,
> > > > My latest dilemma. Previously the oil warning buzzer only came on
> > once
> > > > in a blue moon and I thought this stopped once I changed brand of
> > oil
> > > > filter. Then last trip up the coast it came on after a long drive
> > and
> > > > long idle, but didn't come on at all on the way back home. Driving
> > on
> > > > Sunday, a reasonably hot day, after say 20 minutes the oil warning
> > > > buzzer has been coming on a lot and mostly staying on. Stop the
> > engine
> > > > at the traffic lights, or park for a while, then the buzzer will
> > come
> > > > back on say after another 5 minutes of driving.
> > > > Any tips what to look for? Try some thicker oil? And yes, there is
> > > > plenty of oil in, just under the full mark, and still a good colour,
> > > > only changed about 2000km's ago.
> > > > Another quick question, would the dash and handbrake lever from an
> > 1983
> > > > T3 fit a syncro?
> > > > Thanks guys,
> > > > Sam
