Just fixed hesitation problem
Just fixed a random hesitation problem I have had for the last 5 months.  My parents have just turned up after a month long trip to QLD where they had the same issue.  The symptoms where sudden and temporary power loss after the engine has been running for a while and is up on temp. Ends up being the fuel pump relay is on the way out, swapped the relay and no more problems.  Both Syncros had done over 300Km’s our 2WD did over 600Km no problem but worth changing the relay before it stops you when you’re out on a trail.   Just thought I would let others know.
Michael R
Hi Michael,
Any sign of heating/melting/discoulouration on either/both old relays, or some other clue?
Date: Sat, 6 Oct 2012 02:24:09 -0700
Subject: [Syncro_T3_Australia] Just fixed hesitation problem
Michael R
Hi Ken,
No physical change to the outside of the relay, It is only when you pull it apart that you can see the point are warn. We figure that once the engine bay heats up the resistance builds up at drops the coil out temporarily.  Fuel rail pressure drops and you get fuel starvation.  The Coil cools and relay activates again.  The fuel pump will start up not a problem when cold so hard to track down until the issues is actually happening.  Just funny that Dad had the problem in his Trakka and I had the same issues on my caravelle. I was lucky he pick up to a spare relay for me as well.
Sent: Saturday, October 6, 2012 10:29:14 PM
Subject: RE: [Syncro_T3_Australia] Just fixed hesitation problem
Hi Michael,
To: Syncro_T3_Australia@yahoogroups.com From: type500@yahoo.com Date: Sat, 6 Oct 2012 02:24:09 -0700 Subject: [Syncro_T3_Australia] Just fixed hesitation problem
Michael R
Michael,
Where in the engine bay is the relay located?
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Michael Roberts
Sent: 07 October 2012 09:48
Subject: Re: [Syncro_T3_Australia] Just fixed hesitation problem
Hi Ken,
I think it is one of two in that plastic box above the coil. Greg E
Sent: Sunday, 7 October 2012 10:10 AM
Michael,
Hi Ken,
Those two relays ..
one is the Main Relay ( power to injectors, oxygen heat, ecu )
the other is the fuel pump relay. That's the one on the right.
Most handily one can jumper the fuel pump to run just by connecting the middle top, and the middle bottom wires where they are plugged onto the bottom of that relay. Even with key off. With either a small jumper wire or even with small screwdriver blade as a quick test.
- or to pump fuel out of a fuel tank you are going to remove ..any time you just want to quickly run the fuel pump.
or bypass the ecu portion of the circuit.
www.turbovans.com
Michael,
Hi Ken,
Spot on Scott,
It's the 40A relay on the right. also the one I drop out when it switch to LPG.
Cc: greg esposito <gregespo73@yahoo.com>
Sent: Sunday, October 7, 2012 11:38:34 AM
Those two relays ..
http://www.turbovans.com/
From: Les Harris mailto:leslieharris@optusnet.com.au
Michael,
Hi Ken,
Hi Scott,
in other words, we could install a jumper switch into that box or anywhere convenient  to switch on the pump when experiencing problems ?? this is standard in aeroplanes as those guys don't trust the mechanical pumps and therefore the check before take off and before landing does include
FUEL PUMP ON. This , of course,  does relate to the secondary electrical fuel pump.
On 07/10/2012, at 1:38 PM, Scott Daniel - Turbovans wrote:
Those two relays ..
www.turbovans.com
Michael,
Hi Ken,
Right ...electric boost pump for take off an landing, for more likelihood of fuel getting where it should
One could, use a cockpit located switch to power your fuel pump directly this way .
at the relay contacts.
It's nothing more complicated than battery power on one side, the the power feed to the fuel pump on the other side.
You'd want to make sure you never leave it on when leaving your rig ..
as the pump would keep running and drain the battery.
or ..you could use a '15' 12 volts 'ignition on' power source....then once key is off, it would be off too.
www.turbovans.com
On 10/6/2012 9:04 PM, Hartmut wrote:
Hi Scott,
Those two relays ..
www.turbovans.com
Michael,
Hi Ken,
Hi Scott,
Interesting and valuable information, thank you.
CC: hartis@live.com.au
Date: Sat, 6 Oct 2012 21:51:32 -0700
www.turbovans.com
Hi Scott,
Those two relays ..
www.turbovans.com
Michael,
Hi Ken,
