Leak head
Any rebuild should get new head studs fitted !
Try Tooley imports or go westy for new studs.
The issue when rebuilding is getting your old head studs out from a labor point of view.
Best practice is to leave your case halves out In the sun studs up and dig out the bases of the stud to form a cavity to store a good quality stud remover lubricant to sit in. As the case heats up in the sun keep giving each stud a spray again. Give it a day it two. Then install case in a proper stand and get a good sized hammer and give each stud a bloody good wack maybe once or twice or even three times on its end!! Then u really only get one go at unscrewing it. Worst case is it snaps!
If if does well then be prepared to take ages getting the remainder out and make sure you don't damage the thread too much - a helicoil can be used here.
Alternatively try heating up the block where the stud seats with a oxy briefly and then spray it with the lubricant working on the principle that AL exp faster than the steel stud therefore breaking the seal and allowing lub in.
To be honnest most leaking heads are a result of not running the correct coolant or lack of it and simply a corroded head surface. But if that's the case the head studs will also be pitted leading to either a broken head stud or you breaking it when trying to remove it or re tension it.
The Key is to run the correct coolant always!
Sent from my iPhone
On 4 Apr 2014, at 6:47 pm,Syncro_T3_Australia@yahoogroups.com wrote:
There are 10 messages in this issue.
Topics in this digest:
1a. That time in every Syncro's life
1b. Re: That time in every Syncro's life
1c. Re: That time in every Syncro's life
1d. Re: That time in every Syncro's life
1e. Re: That time in every Syncro's life
1f. Re: That time in every Syncro's life
1g. Re: That time in every Syncro's life
1h. Re: That time in every Syncro's life
1i. Re: That time in every Syncro's life
1j. Re: That time in every Syncro's life
Messages
________________________________________________________________________
  Posted by: "Nicholas Fletcher"nwjfletcher@yahoo.com nwjfletcher
  Date: Thu Apr 3, 2014 2:34 pm ((PDT))
HI,
Our beloved Syncro has the dreaded head gasket leak so needs the job doing, plus a bit of a tune up and so on.
We are in Victoria but I am happy to drive quite a long way for the best mechanic for the job. Does anyone have a recommended mechanic that would also provide some kind of warranty for the work? And how much should it cost? ( I think it should be a couple of thousand)
many thanks
Nick
Messages in this topic (10)
  Posted by: "Steve Clarke"sclarke7171@gmail.comsclarke7171
  Date: Thu Apr 3, 2014 2:53 pm ((PDT))
Interesting. I had the same problem. I'm seriously thinking about
converting mine over to a Volvo B23 engine. Same power and bullet proof.
Will keep you all in the loop on what I do. :)
On Friday, April 4, 2014, Nicholas Fletcher <nwjfletcher@yahoo.com> wrote:
HI,
many thanks
Nick
  Posted by: "Les Harris"leslieharris@optusnet.com.ausyncroaustralia
  Date: Thu Apr 3, 2014 3:08 pm ((PDT))
Nick,
You are a long way from anywhere so you might as well go to the best
workshop - Volkwerke at Greensborough.  They are long established, much
respected and very reliable.  Speak to Lloyd Davies (owner) and tell him
that you are a member of Syncro_T3_Australia.
_____
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Nicholas Fletcher
Sent: 04 April 2014 08:34
To:syncro_t3_australia@yahoogroups.com
Subject: [Syncro_T3_Australia] That time in every Syncro's life
HI,
many thanks
Nick
  Posted by: "Robert Dale"rcdale@bigpond.comrobertdale1945
  Date: Thu Apr 3, 2014 3:23 pm ((PDT))
Nick;
When you are getting prices ask how much it will cost to have s/steel head
studs fitted over normal units this should stop the corrosion problems that
can cause the head to leak.
Bob
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Steve Clarke
Sent: Friday, 4 April 2014 8:54 AM
To:Syncro_T3_Australia@yahoogroups.com
Subject: Re: [Syncro_T3_Australia] That time in every Syncro's life
Interesting. I had the same problem. I'm seriously thinking about converting
HI,
many thanks
Nick
  Date: Thu Apr 3, 2014 3:30 pm ((PDT))
Bob,
The studs do not corrode so long as the correct coolant is used.
_____
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Robert Dale
Sent: 04 April 2014 09:23
Subject: RE: [Syncro_T3_Australia] That time in every Syncro's life
Nick;
Bob
  Posted by: "Greg Esposito"gregespo73@yahoo.comgregespo73
  Date: Thu Apr 3, 2014 3:58 pm ((PDT))
Nick, Where in Victoria are you? How many kms on the engine?
To: "syncro_t3_australia@yahoogroups.com" <syncro_t3_australia@yahoogroups.com
Sent: Friday, 4 April 2014 8:34 AM
HI,
many thanks
Nick
  Date: Thu Apr 3, 2014 4:03 pm ((PDT))
true
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Les Harris
Sent: Friday, 4 April 2014 9:30 AM
Bob,
_____
Nick;
Bob
  Posted by: "Tony Marshall"logwood_1@yahoo.com.aulogwood_1
  Date: Thu Apr 3, 2014 6:26 pm ((PDT))
Nick<br/><br/>Had mind done a few years back at Volkwerke in Greensborough Melb.. It cost me around $1600 from memory. Had new lifters installed at the same time. I was lucky enough to have the complete job done in a day. Lloyd is the man. <br/><br/>Good luck <br/><br/>Tony (Ballarat)<a href="https://overview.mail.yahoo.com?.src=iOS"><br/><br/>Sent from Yahoo Mail for iPhone</a>
  Date: Thu Apr 3, 2014 6:35 pm ((PDT))
A bit of further information about Volkwerke - Lloy
(Message over 64 KB, truncated)
I disagree Hamish, there is no need to replace studs that have no signs of corrosion. Original heads will always have corrosion on the surface because of the crap sealant the factory used - good coolant or not. The studs however will be like new if the engine has had any type of coolant in it for life.
Sent: Friday, 4 April 2014 11:26 PM
Subject: [Syncro_T3_Australia] Leak head
Sent from my iPhone
Messages
HI,
many thanks
Nick
HI,
many thanks
Nick
Nick,
_____
HI,
many thanks
Nick
Nick;
Bob
HI,
many thanks
Nick
Bob,
_____
Nick;
Bob
HI,
many thanks
Nick
true
Bob,
_____
Nick;
Bob
Nick<br/><br/>Had mind done a few years back at Volkwerke in Greensborough Melb.. It cost me around $1600 from memory. Had new lifters installed at the same time. I was lucky enough to have the complete job done in a day. Lloyd is the man. <br/><br/>Good luck <br/><br/>Tony (Ballarat)<a href="https://overview.mail.yahoo.com/?.src=iOS"><br/><br/>Sent from Yahoo Mail for iPhone</a>
A bit of further information about Volkwerke - Lloyd Davies is a lifelong
total VW person with exceptional experience.  He is also president of the VW
Club of Victoria, which is the world's oldest VW club.  In conjunction with
John Goodison (Volks Home), he is about the best source of genuine VAG
parts.
_____
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Tony Marshall
Sent: 04 April 2014 12:27
Nick
Good luck
Tony (Ballarat) <https://overview.mail.yahoo.com/?.src=iOS
  Posted by: "Nick Fletcher"nwjfletcher@yahoo.com nwjfletcher
  Date: Thu Apr 3, 2014 7:03 pm ((PDT))
Hi, we are in Anglesea (nor Geelong) and engine has about 165k on it. Regards. Nick
HI,
many thanks
Nick
Yahoo Groups Links
<*> Your email settings:
  Digest Email  | Traditional
  (Yahoo! ID required)
  Syncro_T3_Australia-normal@yahoogroups.com
<*> Your use of Yahoo Groups is subject to:
  https://info.yahoo.com/legal/us/yahoo/utos/terms/
Sent from my iPhone
This is a classic case of “if it ain’t broke, don’t fix it”!!  If the studs are free of corrosion, they will remain free of corrosion so long as the specified coolant is used.
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Greg Esposito
Sent: 05 April 2014 09:23
Subject: Re: [Syncro_T3_Australia] Leak head
