Hi, Cheers, Michael R |
You won't damage the shock absorbers by going to full extension. They have a bump stop built into them and that is part of their function. Limit straps are to stop your suspension extending beyond the point your set up can handle IF you have fitted shock absorbers with greater rebound than stock. Did you compare the length of your old shock and new for compression and rebound before fitting? What I like to do is fit up modified suspension minus the spring and work it through its travel whilst turning axles and going from lock to lock to make sure all is right before I hit the road. Greg E
On Thursday, 31 October 2013 12:05 PM, Michael Roberts <type500@yahoo.com> wrote:
Hi,
Just wondering if anyone out there is running limiting straps on there suspension? Just put fox shockers on and don't want to damage them hitting full drop. Cheers,
Michael R
Has been done Michael,
see attached. How are the shocks performing.
---In Syncro_T3_Australia@yahoogroups.com, <syncro_t3_australia@yahoogroups.com> wrote:
Hi,
Just wondering if anyone out there is running limiting straps on there suspension? Just put fox shockers on and don't want to damage them hitting full drop.Cheers,
Michael R
