I would like to know in which direction does the oil flow through our
2.1 Lit. engine - in relation to the oil filter and pressure sensor?
Any takers?
Hi All,
Any takers?
> Theo, all cartrige oil filters flow in the same direction, From the outside holes, through the filter medium and out the large inner hole. The main oil gallery supplies the two presssure sensors, firstly the one under the w/pump and secondly the one on the left after passing number four cylinders lifters. Greg E
> From: Theo Weiss <teows@...>
> Sent: Wednesday, 14 November 2012 7:51 AM
> Subject: [Syncro_T3_Australia] Oil flow
> Â
> Hi All,
> Any takers?
> Theo
Hi All,
Any takers?
--- In mailto:Syncro_T3_Australia%40yahoogroups.com, greg esposito <gregespo73@...> wrote:
> To: mailto:Syncro_T3_Australia%40yahoogroups.com
> Â
> Hi All,
> Any takers?
> Theo
Hi All,
Any takers?
Do you have a specific problem Theo?
Sent: Wednesday, 14 November 2012 9:57 PM
Subject: Re: [Syncro_T3_Australia] Oil flow
Greg, Scott,
Thanks for you explanation. What I should have asked is this. In which direction does the oil flow after the oil pump picks it up through the strainer?
Hi All,
Any takers?
Greg, Scott,
Hi All,
Any takers?
entry point for the Engine Pre Lube Kit.
Thanks for that clarification. Now we're getting somewhere.
the 'usual deal' is to use an adapter between the engine block and spin-on oil filter.
That gives you access to the right spot in the oil circuit with taping into the block anywhere.
If you've ever heard of a ...can't remember the ...right .
Accusump...
it's an oil pressure acumulator system ...it's designed to feed back-up oil under stored pressure ( via diaprham and spring in a large cylinder ) to the oil system if there is oil pressure loss..
and it can be used as a pre-lube device too...using the stored oil under pressure from the last time the engine ran.
The way that system interfaces with the engine is via an adapter plate .sometimes called a sandwich plate..
betwixt engine block and oil filter.
that would be the nicest easiest way. Such adapters are pretty common ..often used for external oil cooler hose connections.
That Accusump thing btw...
they come in two sizes ...2 qt and 3 qt I think ..this was on a Subaru SVX engine, that I did the installation on, in an 87 Syncro T3 van.
Since we had a shortened oil pan ..and they guy just seemed to love to spend money on his rig.
What I did not like about it though ...I could not figure out or find out how it could mind oil level in the sump.
I talked to the company a lot ..and they could not give me a good answer about how it knew how much oil to put in.
It only sensed oil pressure ..and nothing about oil level in the sump. We finally didn't keep it on there.
It made a nice pre-lube device though .
Imagine ..turn on the key ....energize your prelube device, watch OP come up on your OP gauge ..then start the engine. Nice.
In the real world though ....cars get by just fine without such systems,
scott
www.turbovans.com
This subject has been raised before. The engine does not have to fire before the oil pump delivers pressure. The oil pump delivers pressure from the moment that you engage the starter. By the time that the engine fires, there is pressure in the galleries and oil is being delivered to the points of lubrication. When the engine fires, it does not instantly go to several thousand RPM. At idle speed, there is more than ample lubrication to service the very low engine loads. This is one of those things that look good on paper until you sit down and work out what is actually happening on start-up.
Behalf Of Theo Weiss
Sent: 15 November 2012 07:49
To:
Oil flow
No problem, I just want to find the right entry point for the Engine Pre Lube
Kit.
Greg, Scott,
Hi All,
Any takers?
> start-up.
> [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Theo Weiss
> Greg,
> Lube Kit.
> Theo
> Greg, Scott,
> strainer?
> Theo
> lifters. Greg E
> Hi All,
> Any takers?
> Theo
If there was a measurable benefit from such a system, it is a reasonable assumption that they would be designed into, at the very least, such engines as Porsche and Ferrari.
Behalf Of gregespo73
Sent: 15 November 2012 10:08
To:
Oil flow
I agree with you Les, I don't see the need for one on
a wbx. Sounds like Theo has already purchased and is ready to install. Scott, I
think Theo has already fitted an aux cooler with a sandwich plate, he could
"T" into that I suppose. Greg
I agree with you Les, I don't see the need for one on a wbx. Sounds like Theo has already purchased and is ready to install. Scott, I think Theo has already fitted an aux cooler with a sandwich plate, he could "T" into that I suppose. Greg
> start-up.
> Greg,
> Lube Kit.
> Theo
> Greg, Scott,
> strainer?
> Theo
> lifters. Greg E
> Hi All,
> Any takers?
> Theo
> start-up.
> [ mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Theo Weiss
> Greg,
> Lube Kit.
> Theo
> Greg, Scott,
> strainer?
> Theo
> lifters. Greg E
> Hi All,
> Any takers?
> Theo
