Hay guys have a cracked coolant manifold drivers side of engine held in place by wire clip. The larger pipes have spring clamps on the pipes however they are above therefore hard to access from below. Any tips before I start removing clip and clamps.
Are all replacements plastic as well or is there a alloy or other to choose from.
Don't think it will be cheap?
Thanks in advance Pete
