Please help again.
Hello again All.
Well Pepita goes over the pits again tomorrow at 3.30. All fixed and ready to go.
Ive just been up to fill her up at petrol station. On the way the rain was hitting hard so decided to put her in syncro mode. All good until i came to do a tight turn on the forcourt and i seem to get a small clunking sound. Its not there when in 2 wheel mode only when in 4wd. Any ideas. I did notice a ball joint rubber had split the other day could this have anything to do with it?
I also noticed when changing the steering rack rubbers that there appears to be 2 extra (8mm ish) home made spacers on the 2 bottom nuts out of the 4. which appears to kick the steering rack up a little bit. Is this normal.
Thanks in advance and appreciate your time
Anthony
