I know there are plenty of vendors that sell urethane bushes ,but is anyone here running them & if so, how do they perform? Thanks, Eddie Bergodaz.
Eddie,I have been using poly two piece front lower bushes for 3 years now.
Easier to fit these than the one piece.Can replace them on the car,you do not remove the arm.
No more squeaks and never need replacing again.
BenC
BenC
Hi Eddie, I fitted Powerflex lower control arm bushes and sway bar eye bushes. Great products, the rack bushes are also ment to make a big differance over stock. Bought from here http://www.t3technique.com/ . Powerflex are English but as with everything else are cheaper through the States. Second what Ben says, genuine lower arm bushes are a bugger without the right tool. Greg E
Sent: Monday, 3 October 2011 10:01 PM
Subject: [Syncro_T3_Australia] Re: Poly Bushes.
BenC
BenC
Thanks for the replies Ben & Greg. Just one more question I have. Can you notice more vibrations or more jarring coming through the steering/body of the van due to the stiffer nature of the bushes? Thanks Eddie.
> Hi Eddie, I fitted Powerflex lower control arm bushes and sway bar eye bushes. Great products, the rack bushes are also ment to make a big differance over stock. Bought from here http://www.t3technique.com/%c3%82%c2%a0. Powerflex are English but as with everything else are cheaper through the States. Second what Ben says, genuine lower arm bushes are a bugger without the right tool. Greg E
> From: Ben <bencroft96@...>
> Â
> BenC
Eddie,as far as noticing anymore vibrations or jarring because of the stiffer bushes,I would have to say, no, I havent.
BenC
BenC
> --- In Syncro_T3_Australia@yahoogroups.com, greg esposito <gregespo73@> wrote:
> > From: Ben <bencroft96@>
> > Â
> > BenC
Eddie, I can't really answer your question because I did everything at once including stronger springs. Can't imagine it could cause jarring, you may get more road feel, thats a positive in my books. Greg E
Sent: Tuesday, 4 October 2011 9:48 PM
BenC
BenC
> > Â
> > BenC
Thanks once again Greg & Ben, will place an order with t3 technique shortly and typically that bloody Ozzy Peso has lost value again! Eddie.
> Â
> BenC
> > > Hi Eddie, I fittedÃÂ Powerflex lower control arm bushes and sway bar eye bushes. Great products, the rack bushes are also ment to make a bigÃÂ differance over stock. Bought from here http://www.t3technique.com/%c3%83%c2%82%c3%82%c2%a0. Powerflex are English but as with everything else are cheaper through the States. Second what Ben says, genuine lower arm bushes are aÃÂ bugger without the right tool.ÃÂ Greg E
> > > ÃÂ
> > > BenC
