Gday Yurik,
It has never occurred to me I could R&R the a/c component parts myself, especially after reading through the VASA website at http://www.vasa.org.au/content/hotair/index.php and reading some of their relevant online newsletter items on this subject, warning members against taking short cuts etc.
For example, they warned against installing new components into an old system, meaning that when the evacuation processes are carried out, contaminants from old components often shift to new components and contaminate them as well, which apparently causes even more problems. However, you seem not to have had issues such as this in your case.
Also, they did talk about the importance that prior to installation into the system, to take the time to completely remove the manufacturers temporary fluids from the compressor first.
Yurik, I take it that as my a/c system has managed to de-gas itself, opening up the system to replace components is no longer problematic i.e., there is now no refrigerant to recover?
So as you can see, I assumed this was a job only for the pros. But I am encouraged by what you are suggesting and I should look into it more closely and perhaps add this project to my 2009 todo list. I suspect quite a few other Prestige Auto Air system users may also see the possibilities this presents.
I see there is a local Enzed service centre here so using their skilled services for the new o ring hose connectors is a very good solution. Goto: http://www.enzed.com.au/
Just in case someone has experience concerning a brand of compressor called Zexel, I would be interested to here positive and negative feedback here please.
Thanks again Yurik. Cheers.
--- In Syncro_T3_Australia@yahoogroups.com, "Yurik Orlowsky" <yuriko@...> wrote:
> Ken,
> If you can get a new modern compressor that bolts straight on the existing
> bracket
> then that would be the major part of the ac upgrade. The remaining things
> are to get
> new fittings on the hoses to connect to the compressor, new TX valve and
> receiver-drier.
> I would use Hose Masters/Enzed or similar to crimp on new o-ring connectors.
> Any decrease
> of length as the result of cutting off the old fittings can be made up by
> using longer Al tails
> on the new fittings, all available off the shelf. The rest of the components
> in the system are re-used
> ie condenser, evaporator, thermostat, pressure switch and hoses.
> I would then present the completed system to an ac specialist and ask them
> to do a re-gas.
> Making sure that the system is flushed to remove any R12, oil and
> contaminants. Having both
> a pressure test- using Nitrogen gas and a vacuum leak down test. Making
> sure they use extra oil
> because of the longer hoses in the syncro. They will probably inject a UV
> sensitive dye with the
> R134A for leak checking post re-gas. It would be a good idea to return to
> them after approx
> 600km with good use of the ac for a further leak test.
> My ac has remained very cold now some 3yrs later. However one would expect a
> slow reduction of
> efficiency after 5yrs or so due to the slow molecular diffusion of the gas
> through the long rubber hoses and seal leaks.
> For the moment I am keeping cool.
> Regards
> Yurik
> [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Ken
> Sent: Friday, 21 November 2008 9:41 AM
> Subject: [Syncro_T3_Australia] Re: Original circa 1990 aftermarket air
> conditioning system ... upgradeable?
> Gday Yurik,
> Thanks a lot for this, so far you are the only one who has experienced
> the sort of upgrade I had in mind and hopefully within a reasonable
> budget.
> Balance what you have done with the view of the accredited a/c installer
> I spoke to who essentially said an 18 year old system in this
> non-standard vehicle would be so affected by deterioration, corrosion,
> poor sealing etc in so many components including the long hoses,
> realistically no one in the industry with typical high labour costs and
> overheads would touch it. Only a complete new system would attract a
> warranty. In his view, the removal and replacement with a complete new
> system would be prohibitively expensive. He did say though to try and
> find someone with lower overheads such as the mobile a/c accredited
> installers, even then it would probably have to be treated as a "labour
> of love".
> Ok so please give me your thoughts on the following ok ....
> I believe I can get a new modern compressor with double pulley that
> bolts straight on to the existing bracket. The compressor pulley will
> line up correctly with the drive output pulley.
> I expect the o ring connectors on the new compressor head will be set
> up/located differently to the existing flair connectors on the old
> compressor head. So do you think that cutting off the hose flair
> fittings and replacing them with the newer o ring fittings, the hose
> will still be long enough to attach to the new compressor head? Worst
> comes to the worst, I believe there are adaptors available.
> The receiver-drier as a matter of course should be replaced.
> As you suggest, replace the X.T. valve.
> So from what you remember, you re-used the old front condenser (in front
> of the radiator), the in-dash evaporator, the thermostat and pressure
> switch as well as the 2 very long rubber refrigerant hoses. The whole
> system was evacuated of contaminants then regassed with R134A
> refrigerant, tested for leaks and it passed ok?
> Are you aware of any other issues and does the a/c system still hold
> it's gas ok ... that is, it's still quite cold even now when you use it,
> some 5 years later?
> Do you run it periodically to keep the seals moist and do you have it
> serviced annually or not?
> Thanks Yurik, I appreciate your help and guidance.
> <mailto:Syncro_T3_Australia%40yahoogroups.com> , "Yurik Orlowsky"
> yuriko@ wrote:
> > My syncro has the Prestige Auto Air system and I also found it to be
> > ineffective. At one point when a re-gas was needed
> > I had the XT valve replaced and this improved the cooling
> significantly.
> > Later when I did the Subaru engine conversion the
> > new engine(2003) came with a compressor which was retro fitted to the
> > existing system and this combination produced
> > very crisp cold air - a huge improvement. I have come to the
> conclusion
> > that the old compressors are inefficient and the modern
> > new ones are the answer to an aging ac system that we have. One of my
> > friends replaced his compressor in a 2L air cooled
> > VW bus with a smaller modern one and it transformed his ac.
> > With the T3, the engine compressor bracket would have to be modified
> and new
> > hose connectors installed to suit the compressor
> > used. All other components remain.
> > Yurik
> <mailto:Syncro_T3_Australia%40yahoogroups.com> ] On Behalf Of Ken
> > Sent: Thursday, 20 November 2008 3:36 PM
> > Subject: [Syncro_T3_Australia] re: Original circa 1990 aftermarket air
> > Gday ALL,
> > Many syncros, in particular Trakka campers, had an aftermarket a/c
> > system made by Prestige Auto Air in Sydney or else some other a/c
> > business. My observations conclude that most if not all of these old
> > systems no longer work satisfactorily, some people even resort to a
> > re-gas just prior to their annual trip, hoping it lasts the distance.
> > Has anyone had real success simply upgrading key components of the
> > original a/c system such, that it now works well and no longer leaks
> > refrigerant?
> > By that I mean for example, replacing the compressor, receiver/drier,
> > perhaps the thermostat, pressure switch, T.X. valve, gas seals etc.
> > Also, possibly replaced the front condenser (in front of radiator)
> > and/or the evaporator (mounted in/on dash in front of passenger seat.
> > If anyone can say it has been done successfully, did it also include
> > replacing the 2 large rubber refrigerant hoses that link the
> > compressor on the motor and the receiver drier behind the front
> > passenger side headlight? Perhaps they were replaced with metal lines.
> > I'm interested at this early stage to at least try and find out if it
> > is feasible in terms of being practical and economical. I've spoken
> > to an accredited installer today and he didn't paint a rosy picture.
> > Failing all else, I may remove the a/c components to lighten the load.
> > Any helpful feedback would be much appreciated. TIA.
> > Cheers.
