Re: [Syncro_T3_Australia] Digest Number 3691
I looked into the rolling diameter of different tyres a few years ago, before replacing my worn-out 14" BFGs with 15" Firestones.
The information might be out of date now, but you can check it on the manufacturer's websites:
O.E. tyres (Australia) were Michelin X 185/80R14 or 205/70R14. I have not been able to determine the diameter, but they turned at 773 rpm (revolutions per mile). This is the yardstick.
My van had similar road-oriented tyres when I bought it, (670mm O.D.) and they were replaced with BFG 27x8.5x14 which turned at 782 rpm - a minor difference. They had 673 mm O.D.
Sadly those tyres are no longer imported, so when they wore out I bought some 15" rims and fitted Firestone Destination 205/70R15 with 689mm O.D. That's around 3% bigger.
I considered BFG 205/75R15 but was put off by reports of tyre rubbing. They are bigger again - 706mm, 748 rpm. That's 5% bigger than their little brothers.
GoWesty claims that they change gearing by 12% over the OE tyre (although U.S. vans have a taller FDR than ours). Go figger!
I noticed when I changed from BFG to Firestone that the van had much less rolling resistance, probably due to the stiffer sidewall and smoother tread. I could push the van around a lot easier over the pit, and fuel economy improved. But I have to use a lower gear on the mountain.
Cheers, Roger.
On Thu, Nov 3, 2016 at 8:43 PM, <Syncro_T3_Australia@yahoogroups.com> wrote:
4 Messages
Digest #3691
1a
Re: Digest Number 3690 by "Roger Bayley" gullyraker1953
1b
Re: Digest Number 3690 by "neil smith" jackthebearau
1c
Messages
Wed Nov 2, 2016 3:57 am (PDT) . Posted by:
Made a very noticeable difference to power and braking. Doesn't like hills
- have to change back a gear where you never needed to before. Slower
pickup. Uses more petrol. Won't climb extremely steep gradients in Gelande
gear as well, especially with a full load. More stress on CV joints and
other components.
Greater unsprung weight has detrimental effect on ride and handling.
The only advantage is a small increase in ground clearance and a longer
footprint which is occasionally useful in extreme conditions. But you pay
for it the rest of the time.
Most people only went to 15" because BFG stopped sending them to Oz in 14".
If you could get decent 14" off-road tyres I would bolt them back on
tomorrow. The VW engineers knew what they were doing when they chose the
ratios ...
On Wed, Nov 2, 2016 at 8:58 PM, <Syncro_T3_Australia@ yahoogroups.com> wrote:
> [image: Yahoo! Groups]
> <https://groups.yahoo.com/neo; _ylc= X3oDMTJlb2t1MWU1BF9TAzk3MzU5Nz E1BGdycElkAzEzMjY3MzE1BGdycHNw SWQDMTcwOTkyNjI0MARzZWMDZnRyBH NsawNnZnAEc3RpbWUDMTQ3ODA4MDcx Nw-->
> Syncro_T3_ Australia Group
> <https://groups.yahoo.com/neo/ groups/Syncro_T3_Australia/ info;_ylc= X3oDMTJlZGozaGxsBF9TAzk3MzU5Nz E1BGdycElkAzEzMjY3MzE1BGdycHNw SWQDMTcwOTkyNjI0MARzZWMDaGRyBH NsawNocGgEc3RpbWUDMTQ3ODA4MDcx Nw-->
> 4 Messages
> Digest #3690
> 1a
> Re: Trakka gas cooker <#m_-3851274794551037620_1a> by richo1166
> 2a
> 14" verse 15" Wheels <#m_-3851274794551037620_2a> by richo1166
> 2b
> Re: 14" verse 15" Wheels <#m_-3851274794551037620_2b> by "Tom Mischler"
> energysustained@ymail.com
> 2c
> Re: 14" verse 15" Wheels <#m_-3851274794551037620_2c> by hdvwoc
> Messages
> 1a Re: Trakka gas cooker
> <https://groups.yahoo.com/neo/ groups/Syncro_T3_Australia/ conversations/topics/26585;_ ylc= X3oDMTJzcTRxYjExBF9TAzk3MzU5Nz E1BGdycElkAzEzMjY3MzE1BGdycHNw SWQDMTcwOTkyNjI0MARtc2dJZAMyNj U4NQRzZWMDZG1zZwRzbGsDdm1zZwRz dGltZQMxNDc4MDgwNzE3>
> Tue Nov 1, 2016 4:08 pm (PDT) . Posted by: richo1166
> <richo1166@yahoo.com.au? subject=Re%3A%20Trakka%20gas% 20cooker>
> On our camper trailer we had 2 of 4kg bottles that I did not want to swap
> and go. I purchased one of these to refill them at home myself. I paid $100
> for it a couple of years ago..
> LPG Filler Gun & Hose Plus Adapters | eBay http://www.ebay.com.au/itm/
> LPG-Filler-Gun-Hose-Plus- Adapters-/231620669166
> http://www.ebay.com.au/itm/ LPG-Filler-Gun-Hose-Plus- Adapters-/231620669166
> LPG-Filler-Gun-Hose-Plus- Adapters-/231620669166 LPG Filler Gun & Hose,
> comes with 3/8 camper, Primus cylinder Adapters, and Automotive 1 3/4" Acme
> filler adapter. This kit is suited to refilling of standard ...
> View on www.ebay.com.au http://www.ebay.com.au/itm/
> Preview by Yahoo
> This way if I have a bottle that has some gas in it i.e. not completely mt
> but need a fill one to go away I don't give back that gas I just top up
> from a 9kg bottle...
> You maybe able to use it for your Trakka bottles. ??
> Reply to sender
> <richo1166@yahoo.com.au? subject=Re%3A%20Trakka%20gas% 20cooker> . Reply to
> group
> <Syncro_T3_Australia@ yahoogroups.com?subject=Re%3A% 20Trakka%20gas%20cooker> .
> Reply via Web Post
> <https://groups.yahoo.com/neo/ groups/Syncro_T3_Australia/ conversations/messages/26585;_ ylc= X3oDMTJzdTdhMmxnBF9TAzk3MzU5Nz E1BGdycElkAzEzMjY3MzE1BGdycHNw SWQDMTcwOTkyNjI0MARtc2dJZAMyNj U4NQRzZWMDZG1zZwRzbGsDcnBseQRz dGltZQMxNDc4MDgwNzE3?act= reply&messageNum=26585> .
> All Messages (4)
> <https://groups.yahoo.com/neo/ groups/Syncro_T3_Australia/ conversations/topics/26582;_ ylc= X3oDMTM4dWF0cnBqBF9TAzk3MzU5Nz E1BGdycElkAzEzMjY3MzE1BGdycHNw SWQDMTcwOTkyNjI0MARtc2dJZAMyNj U4NQRzZWMDZG1zZwRzbGsDdnRwYwRz dGltZQMxNDc4MDgwNzE3BHRwY0lkAz I2NTgy> .
> Top ^ <#m_-3851274794551037620_toc>
> 2a 14" verse 15" Wheels
> <https://groups.yahoo.com/neo/ groups/Syncro_T3_Australia/ conversations/topics/26586;_ ylc= X3oDMTJzaW44MDNwBF9TAzk3MzU5Nz E1BGdycElkAzEzMjY3MzE1BGdycHNw SWQDMTcwOTkyNjI0MARtc2dJZAMyNj U4NgRzZWMDZG1zZwRzbGsDdm1zZwRz dGltZQMxNDc4MDgwNzE3>
> Tue Nov 1, 2016 5:04 pm (PDT) . Posted by: richo1166
> <richo1166@yahoo.com.au? subject=Re%3A%2014%22%20verse% 2015%22%20Wheels>
> I expect that this has been discussed numerous times but just thought I'd
> ask anyway.
> What are peoples experience been like going from standard 14" wheels to
> 15" and 215x75x15 BFG's?
> With a standard 2.1 wbx engine. I have seen on other lists saying to
> expect a 9% loss in power, is this really that noticeble in a under powered
> car anyway...?
> Thanks :)
> Reply to sender
> <richo1166@yahoo.com.au? subject=Re%3A%2014%22%20verse% 2015%22%20Wheels> . Reply
> to group
> <Syncro_T3_Australia@ yahoogroups.com?subject=Re%3A% 2014%22%20verse%2015%22% 20Wheels> .
> Reply via Web Post
> <https://groups.yahoo.com/neo/ groups/Syncro_T3_Australia/ conversations/messages/26586;_ ylc= X3oDMTJzYjh0b3BqBF9TAzk3MzU5Nz E1BGdycElkAzEzMjY3MzE1BGdycHNw SWQDMTcwOTkyNjI0MARtc2dJZAMyNj U4NgRzZWMDZG1zZwRzbGsDcnBseQRz dGltZQMxNDc4MDgwNzE3?act= reply&messageNum=26586> .
> All Messages (3)
> <https://groups.yahoo.com/neo/ groups/Syncro_T3_Australia/ conversations/topics/26586;_ ylc= X3oDMTM4aGV1bGdjBF9TAzk3MzU5Nz E1BGdycElkAzEzMjY3MzE1BGdycHNw SWQDMTcwOTkyNjI0MARtc2dJZAMyNj U4NgRzZWMDZG1zZwRzbGsDdnRwYwRz dGltZQMxNDc4MDgwNzE3BHRwY0lkAz I2NTg2> .
> 2b Re: 14" verse 15" Wheels
> <https://groups.yahoo.com/neo/ groups/Syncro_T3_Australia/ conversations/topics/26587;_ ylc= X3oDMTJzMXRxbm1hBF9TAzk3MzU5Nz E1BGdycElkAzEzMjY3MzE1BGdycHNw SWQDMTcwOTkyNjI0MARtc2dJZAMyNj U4NwRzZWMDZG1zZwRzbGsDdm1zZwRz dGltZQMxNDc4MDgwNzE3>
> Tue Nov 1, 2016 11:51 pm (PDT) . Posted by: "Tom Mischler"
> <energysustained@ymail.com? subject=Re%3A%2014%22%20verse% 2015%22%20Wheels>
> How can you loose power by putting bigger wheels on? Tom
> Sent from Yahoo7 Mail on Android
> On Wed, 2 Nov, 2016 at 11:04, richo1166@yahoo.com.au
> ask anyway.
> car anyway...?
> Thanks :)
> Reply to sender
> <energysustained@ymail.com? subject=Re%3A%2014%22%20verse% 2015%22%20Wheels> .
> Reply to group
> Reply via Web Post
> <https://groups.yahoo.com/neo/ groups/Syncro_T3_Australia/ conversations/messages/26587;_ ylc= X3oDMTJzb2NodTVrBF9TAzk3MzU5Nz E1BGdycElkAzEzMjY3MzE1BGdycHNw SWQDMTcwOTkyNjI0MARtc2dJZAMyNj U4NwRzZWMDZG1zZwRzbGsDcnBseQRz dGltZQMxNDc4MDgwNzE3?act= reply&messageNum=26587> .
> All Messages (3)
> <https://groups.yahoo.com/neo/ groups/Syncro_T3_Australia/ conversations/topics/26586;_ ylc= X3oDMTM4OTBub2ozBF9TAzk3MzU5Nz E1BGdycElkAzEzMjY3MzE1BGdycHNw SWQDMTcwOTkyNjI0MARtc2dJZAMyNj U4NwRzZWMDZG1zZwRzbGsDdnRwYwRz dGltZQMxNDc4MDgwNzE3BHRwY0lkAz I2NTg2> .
> 2c Re: 14" verse 15" Wheels
> <https://groups.yahoo.com/neo/ groups/Syncro_T3_Australia/ conversations/topics/26588;_ ylc= X3oDMTJzbm84MWNyBF9TAzk3MzU5Nz E1BGdycElkAzEzMjY3MzE1BGdycHNw SWQDMTcwOTkyNjI0MARtc2dJZAMyNj U4OARzZWMDZG1zZwRzbGsDdm1zZwRz dGltZQMxNDc4MDgwNzE3>
> Wed Nov 2, 2016 2:09 am (PDT) . Posted by: hdvwoc
> <plander@optusnet.com.au? subject=Re%3A%2014%22%20verse% 2015%22%20Wheels>
> Not much difference except with braking.
> Reply to sender
> <plander@optusnet.com.au? subject=Re%3A%2014%22%20verse% 2015%22%20Wheels> .
> Reply to group
> Reply via Web Post
> <https://groups.yahoo.com/neo/ groups/Syncro_T3_Australia/ conversations/messages/26588;_ ylc= X3oDMTJzZWY2cXFpBF9TAzk3MzU5Nz E1BGdycElkAzEzMjY3MzE1BGdycHNw SWQDMTcwOTkyNjI0MARtc2dJZAMyNj U4OARzZWMDZG1zZwRzbGsDcnBseQRz dGltZQMxNDc4MDgwNzE3?act= reply&messageNum=26588> .
> All Messages (3)
> <https://groups.yahoo.com/neo/ groups/Syncro_T3_Australia/ conversations/topics/26586;_ ylc= X3oDMTM4ZG1ibDloBF9TAzk3MzU5Nz E1BGdycElkAzEzMjY3MzE1BGdycHNw SWQDMTcwOTkyNjI0MARtc2dJZAMyNj U4OARzZWMDZG1zZwRzbGsDdnRwYwRz dGltZQMxNDc4MDgwNzE3BHRwY0lkAz I2NTg2> .
> Visit Your Group
> <https://groups.yahoo.com/neo/ groups/Syncro_T3_Australia/ info;_ylc= X3oDMTJmODhlbWYyBF9TAzk3MzU5Nz E1BGdycElkAzEzMjY3MzE1BGdycHNw SWQDMTcwOTkyNjI0MARzZWMDdnRsBH NsawN2Z2hwBHN0aW1lAzE0NzgwODA3 MTc->
> • Privacy <https://info.yahoo.com/ privacy/us/yahoo/groups/ details.html> •
> Unsubscribe
> <Syncro_T3_Australia- unsubscribe@yahoogroups.com? subject=Unsubscribe> • Terms
> of Use <https://info.yahoo.com/legal/ us/yahoo/utos/terms/>
Wed Nov 2, 2016 3:18 pm (PDT) . Posted by:
The ideal solution is to change your diff ratios to suit if you can't live with it. This will also counter any additional stress on the driveline but is a big undertaking. I normally like to try on a set to see how they are to live with before I buy them. Sometimes you can get some discarded tyres from a tyre shop for nothing but 215 75 15 is an uncommon size. Also you can buy cheap second hand on Ebay to try out the size. I don't have any to lend at the moment but someone may have some old ones. If you take out the tailshaft you can just put two on the back to see how the gearing and motor goes but wont tell you how the brakes feel.
Neil.
From: "Roger Bayley gullyraker53@gmail.com [Syncro_T3_Australia]" <Syncro_T3_Australia@ yahoogroups.com>
To: No Reply <notify-dg-Syncro_T3_ Australia@yahoogroups.com>
Cc: "Syncro_T3_Australia@ yahoogroups.com" <Syncro_T3_Australia@ yahoogroups.com>
Sent: Wednesday, 2 November 2016, 21:57
Subject: Re: [Syncro_T3_Australia] Digest Number 3690
Made a very noticeable difference to power and braking. Doesn't like hills - have to change back a gear where you never needed to before. Slower pickup. Uses more petrol. Won't climb extremely steep gradients in Gelande gear as well, especially with a full load. More stress on CV joints and other components.
The only advantage is a small increase in ground clearance and a longer footprint which is occasionally useful in extreme conditions. But you pay for it the rest of the time.
If you could get decent 14" off-road tyres I would bolt them back on tomorrow. The VW engineers knew what they were doing when they chose the ratios ...
4 Messages
Digest #3690 1a Re: Trakka gas cooker by richo1166 2a 14" verse 15" Wheels by richo1166 2b Re: 14" verse 15" Wheels by "Tom Mischler" energysustained@ymail.com 2c Re: 14" verse 15" Wheels by hdvwoc
Messages
1a
richo1166
On our camper trailer we had 2 of 4kg bottles that I did not want to swap and go. I purchased one of these to refill them at home myself. I paid $100 for it a couple of years ago..
LPG Filler Gun & Hose Plus Adapters | eBay http://www.ebay.com.au/itm/ LPG-Filler-Gun-Hose-Plus- Adapters-/231620669166
LPG Filler Gun & Hose Plus Adapters | eBay http://www.ebay.com.au/itm/ LPG-Filler-Gun-Hose-Plus- Adapters-/231620669166 LPG Filler Gun & Hose, comes with 3/8 camper, Primus cylinder Adapters, and Automotive 1 3/4" Acme filler adapter. This kit is suited to refilling of standard ...
View on www.ebay.com.au http://www.ebay.com.au/itm/ LPG-Filler-Gun-Hose-Plus- Adapters-/231620669166
Preview by Yahoo
This way if I have a bottle that has some gas in it i.e. not completely mt but need a fill one to go away I don't give back that gas I just top up from a 9kg bottle...
Reply to sender . Reply to group . Reply via Web Post . All Messages (4) . Top ^
2a
richo1166
I expect that this has been discussed numerous times but just thought I'd ask anyway.
What are peoples experience been like going from standard 14" wheels to 15" and 215x75x15 BFG's?
With a standard 2.1 wbx engine. I have seen on other lists saying to expect a 9% loss in power, is this really that noticeble in a under powered car anyway...?
Reply to sender . Reply to group . Reply via Web Post . All Messages (3) . Top ^
2b
On Wed, 2 Nov, 2016 at 11:04, richo1166@yahoo.com.au [Syncro_T3_Australia]<Syncro_ T3_Australia@yahoogroups.com> wrote:
2c
hdvwoc
Not much difference except with braking. Reply to sender . Reply to group . Reply via Web Post . All Messages (3) . Top ^ Visit Your Group
• Privacy • Unsubscribe • Terms of Use
#yiv0849771677 #yiv0849771677 -- #yiv0849771677ygrp-mkp {border:1px solid #d8d8d8;font-family:Arial;marg in:10px 0;padding:0 10px;}#yiv0849771677 #yiv0849771677ygrp-mkp hr {border:1px solid #d8d8d8;}#yiv0849771677 #yiv0849771677ygrp-mkp #yiv0849771677hd {color:#628c2a;font-size:85%; font-weight:700;line-height:12 2%;margin:10px 0;}#yiv0849771677 #yiv0849771677ygrp-mkp #yiv0849771677ads {margin-bottom:10px;}# yiv0849771677 #yiv0849771677ygrp-mkp .yiv0849771677ad {padding:0 0;}#yiv0849771677 #yiv0849771677ygrp-mkp .yiv0849771677ad p {margin:0;}#yiv0849771677 #yiv0849771677ygrp-mkp .yiv0849771677ad a {color:#0000ff;text- decoration:none;}#yiv084977167 7 #yiv0849771677ygrp-sponsor #yiv0849771677ygrp-lc {font-family:Arial;}#yiv084977 1677 #yiv0849771677ygrp-sponsor #yiv0849771677ygrp-lc #yiv0849771677hd {margin:10px 0px;font-weight:700;font-size: 78%;line-height:122%;}# yiv0849771677 #yiv0849771677ygrp-sponsor #yiv0849771677ygrp-lc .yiv0849771677ad {margin-bottom:10px;padding:0 0;}#yiv0849771677 #yiv0849771677actions {font-family:Verdana;font-size :11px;padding:10px 0;}#yiv0849771677 #yiv0849771677activity {background-color:#e0ecee;floa t:left;font-family:Verdana; font-size:10px;padding:10px;}# yiv0849771677 #yiv0849771677activity span {font-weight:700;}#yiv08497716 77 #yiv0849771677activity span:first-child {text-transform:uppercase;}# yiv0849771677 #yiv0849771677activity span a {color:#5085b6;text- decoration:none;}#yiv084977167 7 #yiv0849771677activity span span {color:#ff7900;}#yiv0849771677 #yiv0849771677activity span .yiv0849771677underline {text-decoration:underline;}# yiv0849771677 .yiv0849771677attach {clear:both;display:table;font -family:Arial;font-size:12px;p adding:10px 0;width:400px;}#yiv0849771677 .yiv0849771677attach div a {text-decoration:none;}# yiv0849771677 .yiv0849771677attach img {border:none;padding-right:5px ;}#yiv0849771677 .yiv0849771677attach label {display:block;margin-bottom:5 px;}#yiv0849771677 .yiv0849771677attach label a {text-decoration:none;}# yiv0849771677 blockquote {margin:0 0 0 4px;}#yiv0849771677 .yiv0849771677bold {font-family:Arial;font-size: 13px;font-weight:700;}# yiv0849771677 .yiv0849771677bold a {text-decoration:none;}# yiv0849771677 dd.yiv0849771677last p a {font-family:Verdana;font-weig ht:700;}#yiv0849771677 dd.yiv0849771677last p span {margin-right:10px;font-family :Verdana;font-weight:700;}# yiv0849771677 dd.yiv0849771677last p span.yiv0849771677yshortcuts {margin-right:0;}#yiv084977167 7 div.yiv0849771677attach-table div div a {text-decoration:none;}# yiv0849771677 div.yiv0849771677attach-table {width:400px;}#yiv0849771677 div.yiv0849771677file-title a, #yiv0849771677 div.yiv0849771677file-title a:active, #yiv0849771677 div.yiv0849771677file-title a:hover, #yiv0849771677 div.yiv0849771677file-title a:visited {text-decoration:none;}# yiv0849771677 div.yiv0849771677photo-title a, #yiv0849771677 div.yiv0849771677photo-title a:active, #yiv0849771677 div.yiv0849771677photo-title a:hover, #yiv0849771677 div.yiv0849771677photo-title a:visited {text-decoration:none;}# yiv0849771677 div#yiv0849771677ygrp-mlmsg #yiv0849771677ygrp-msg p a span.yiv0849771677yshortcuts {font-family:Verdana;font-size :10px;font-weight:normal;}#yiv 0849771677 .yiv0849771677green {color:#628c2a;}#yiv0849771677 .yiv0849771677MsoNormal {margin:0 0 0 0;}#yiv0849771677 o {font-size:0;}#yiv0849771677 #yiv0849771677photos div {float:left;width:72px;}# yiv0849771677 #yiv0849771677photos div div {border:1px solid #666666;height:62px;overflow:h idden;width:62px;}#yiv08497716 77 #yiv0849771677photos div label {color:#666666;font-size:10px; overflow:hidden;text-align: center;white-space:nowrap; width:64px;}#yiv0849771677 #yiv0849771677reco-category {font-size:77%;}#yiv0849771677 #yiv0849771677reco-desc {font-size:77%;}#yiv0849771677 .yiv0849771677replbq {margin:4px;}#yiv0849771677 #yiv0849771677ygrp-actbar div a:first-child {margin-right:2px;padding-righ t:5px;}#yiv0849771677 #yiv0849771677ygrp-mlmsg {font-size:13px;font-family:Ar ial, helvetica, clean, sans-serif;}#yiv0849771677 #yiv0849771677ygrp-mlmsg table {font-size:inherit;font:100%;} #yiv0849771677 #yiv0849771677ygrp-mlmsg select, #yiv0849771677 input, #yiv0849771677 textarea {font:99% Arial, Helvetica, clean, sans-serif;}#yiv0849771677 #yiv0849771677ygrp-mlmsg pre, #yiv0849771677 code {font:115% monospace;}#yiv0849771677 #yiv0849771677ygrp-mlmsg * {line-height:1.22em;}#yiv08497 71677 #yiv0849771677ygrp-mlmsg #yiv0849771677logo {padding-bottom:10px;}# yiv0849771677 #yiv0849771677ygrp-msg p a {font-family:Verdana;}# yiv0849771677 #yiv0849771677ygrp-msg p#yiv0849771677attach-count span {color:#1E66AE;font-weight:700 ;}#yiv0849771677 #yiv0849771677ygrp-reco #yiv0849771677reco-head {color:#ff7900;font-weight:700 ;}#yiv0849771677 #yiv0849771677ygrp-reco {margin-bottom:20px;padding:0p x;}#yiv0849771677 #yiv0849771677ygrp-sponsor #yiv0849771677ov li a {font-size:130%;text- decoration:none;}#yiv084977167 7 #yiv0849771677ygrp-sponsor #yiv0849771677ov li {font-size:77%;list-style-type :square;padding:6px 0;}#yiv0849771677 #yiv0849771677ygrp-sponsor #yiv0849771677ov ul {margin:0;padding:0 0 0 8px;}#yiv0849771677 #yiv0849771677ygrp-text {font-family:Georgia;}# yiv0849771677 #yiv0849771677ygrp-text p {margin:0 0 1em 0;}#yiv0849771677 #yiv0849771677ygrp-text tt {font-size:120%;}# yiv0849771677 #yiv0849771677ygrp-vital ul li:last-child {border-right:none !important;}#yiv0849771677
Wed Nov 2, 2016 3:53 pm (PDT) . Posted by:
By my calculation the difference is only 5%
From: "neil smith jackthebearau@yahoo.com [Syncro_T3_Australia]" <Syncro_T3_Australia@ yahoogroups.com>
To: "Syncro_T3_Australia@ yahoogroups.com" <Syncro_T3_Australia@ yahoogroups.com>
Sent: Thursday, 3 November 2016, 9:12
Neil.
4 Messages
Messages
1a
richo1166
Preview by Yahoo
2a
richo1166
2b
2c
hdvwoc
#yiv2925183936 #yiv2925183936 -- #yiv2925183936ygrp-mkp {border:1px solid #d8d8d8;font-family:Arial;marg in:10px 0;padding:0 10px;}#yiv2925183936 #yiv2925183936ygrp-mkp hr {border:1px solid #d8d8d8;}#yiv2925183936 #yiv2925183936ygrp-mkp #yiv2925183936hd {color:#628c2a;font-size:85%; font-weight:700;line-height:12 2%;margin:10px 0;}#yiv2925183936 #yiv2925183936ygrp-mkp #yiv2925183936ads {margin-bottom:10px;}# yiv2925183936 #yiv2925183936ygrp-mkp .yiv2925183936ad {padding:0 0;}#yiv2925183936 #yiv2925183936ygrp-mkp .yiv2925183936ad p {margin:0;}#yiv2925183936 #yiv2925183936ygrp-mkp .yiv2925183936ad a {color:#0000ff;text- decoration:none;}#yiv292518393 6 #yiv2925183936ygrp-sponsor #yiv2925183936ygrp-lc {font-family:Arial;}#yiv292518 3936 #yiv2925183936ygrp-sponsor #yiv2925183936ygrp-lc #yiv2925183936hd {margin:10px 0px;font-weight:700;font-size: 78%;line-height:122%;}# yiv2925183936 #yiv2925183936ygrp-sponsor #yiv2925183936ygrp-lc .yiv2925183936ad {margin-bottom:10px;padding:0 0;}#yiv2925183936 #yiv2925183936actions {font-family:Verdana;font-size :11px;padding:10px 0;}#yiv2925183936 #yiv2925183936activity {background-color:#e0ecee;floa t:left;font-family:Verdana; font-size:10px;padding:10px;}# yiv2925183936 #yiv2925183936activity span {font-weight:700;}#yiv29251839 36 #yiv2925183936activity span:first-child {text-transform:uppercase;}# yiv2925183936 #yiv2925183936activity span a {color:#5085b6;text- decoration:none;}#yiv292518393 6 #yiv2925183936activity span span {color:#ff7900;}#yiv2925183936 #yiv2925183936activity span .yiv2925183936underline {text-decoration:underline;}# yiv2925183936 .yiv2925183936attach {clear:both;display:table;font -family:Arial;font-size:12px;p adding:10px 0;width:400px;}#yiv2925183936 .yiv2925183936attach div a {text-decoration:none;}# yiv2925183936 .yiv2925183936attach img {border:none;padding-right:5px ;}#yiv2925183936 .yiv2925183936attach label {display:block;margin-bottom:5 px;}#yiv2925183936 .yiv2925183936attach label a {text-decoration:none;}# yiv2925183936 blockquote {margin:0 0 0 4px;}#yiv2925183936 .yiv2925183936bold {font-family:Arial;font-size: 13px;font-weight:700;}# yiv2925183936 .yiv2925183936bold a {text-decoration:none;}# yiv2925183936 dd.yiv2925183936last p a {font-family:Verdana;font-weig ht:700;}#yiv2925183936 dd.yiv2925183936last p span {margin-right:10px;font-family :Verdana;font-weight:700;}# yiv2925183936 dd.yiv2925183936last p span.yiv2925183936yshortcuts {margin-right:0;}#yiv292518393 6 div.yiv2925183936attach-table div div a {text-decoration:none;}# yiv2925183936 div.yiv2925183936attach-table {width:400px;}#yiv2925183936 div.yiv2925183936file-title a, #yiv2925183936 div.yiv2925183936file-title a:active, #yiv2925183936 div.yiv2925183936file-title a:hover, #yiv2925183936 div.yiv2925183936file-title a:visited {text-decoration:none;}# yiv2925183936 div.yiv2925183936photo-title a, #yiv2925183936 div.yiv2925183936photo-title a:active, #yiv2925183936 div.yiv2925183936photo-title a:hover, #yiv2925183936 div.yiv2925183936photo-title a:visited {text-decoration:none;}# yiv2925183936 div#yiv2925183936ygrp-mlmsg #yiv2925183936ygrp-msg p a span.yiv2925183936yshortcuts {font-family:Verdana;font-size :10px;font-weight:normal;}#yiv 2925183936 .yiv2925183936green {color:#628c2a;}#yiv2925183936 .yiv2925183936MsoNormal {margin:0 0 0 0;}#yiv2925183936 o {font-size:0;}#yiv2925183936 #yiv2925183936photos div {float:left;width:72px;}# yiv2925183936 #yiv2925183936photos div div {border:1px solid #666666;height:62px;overflow:h idden;width:62px;}#yiv29251839 36 #yiv2925183936photos div label {color:#666666;font-size:10px; overflow:hidden;text-align: center;white-space:nowrap; width:64px;}#yiv2925183936 #yiv2925183936reco-category {font-size:77%;}#yiv2925183936 #yiv2925183936reco-desc {font-size:77%;}#yiv2925183936 .yiv2925183936replbq {margin:4px;}#yiv2925183936 #yiv2925183936ygrp-actbar div a:first-child {margin-right:2px;padding-righ t:5px;}#yiv2925183936 #yiv2925183936ygrp-mlmsg {font-size:13px;font-family:Ar ial, helvetica, clean, sans-serif;}#yiv2925183936 #yiv2925183936ygrp-mlmsg table {font-size:inherit;font:100%;} #yiv2925183936 #yiv2925183936ygrp-mlmsg select, #yiv2925183936 input, #yiv2925183936 textarea {font:99% Arial, Helvetica, clean, sans-serif;}#yiv2925183936 #yiv2925183936ygrp-mlmsg pre, #yiv2925183936 code {font:115% monospace;}#yiv2925183936 #yiv2925183936ygrp-mlmsg * {line-height:1.22em;}#yiv29251 83936 #yiv2925183936ygrp-mlmsg #yiv2925183936logo {padding-bottom:10px;}# yiv2925183936 #yiv2925183936ygrp-msg p a {font-family:Verdana;}# yiv2925183936 #yiv2925183936ygrp-msg p#yiv2925183936attach-count span {color:#1E66AE;font-weight:700 ;}#yiv2925183936 #yiv2925183936ygrp-reco #yiv2925183936reco-head {color:#ff7900;font-weight:700 ;}#yiv2925183936 #yiv2925183936ygrp-reco {margin-bottom:20px;padding:0p x;}#yiv2925183936 #yiv2925183936ygrp-sponsor #yiv2925183936ov li a {font-size:130%;text- decoration:none;}#yiv292518393 6 #yiv2925183936ygrp-sponsor #yiv2925183936ov li {font-size:77%;list-style-type :square;padding:6px 0;}#yiv2925183936 #yiv2925183936ygrp-sponsor #yiv2925183936ov ul {margin:0;padding:0 0 0 8px;}#yiv2925183936 #yiv2925183936ygrp-text {font-family:Georgia;}# yiv2925183936 #yiv2925183936ygrp-text p {margin:0 0 1em 0;}#yiv2925183936 #yiv2925183936ygrp-text tt {font-size:120%;}# yiv2925183936 #yiv2925183936ygrp-vital ul li:last-child {border-right:none !important;}#yiv2925183936
US syncros have lower profile tyres than Australia hence the different FDR. When I researched tyre sizes I found the manufacturers specifications to be incorrect. This is why I actually measured rolling diameters on brand new tyres.
Interesting read Roger,
The spare on mine (caravelle) was a Michelin 205R14 (which is 80% side wall), based on the date code was the original spare. Mine also had 4 Michelin 205R14's on it when I bought it. This matches the placard inside the passenger door.
I run two sets of tires, 205/75R14 commercial tires for normal driving and 215/75R15 AT's for off road fun, so the road tires are a little smaller than stock, and the AT's a little larger.
I drive to the speedo on both sets of tires (so am a little slower actual speed on the road tires). Based on the speedo reading there is no real difference in economy.
A good gauge for me is the Gateway bridge (in Bris), it's a long straight climb at a constant incline, on the road tires I can just hold the speed limit (80kph) to the top, on the AT's I drop ~5-10kph by the top.
Cheers, Roger.
4 Messages
Digest #3691
1a
1b
1c
Messages
other components.
ratios ...
> 4 Messages
> Digest #3690
> 1a
> 2a
> 2b
> energysustained@...
> 2c
> Messages
> <richo1166@...? subject=Re%3A%20Trakka%20gas% 20cooker>
> Preview by Yahoo
> Reply to sender
> <richo1166@...? subject=Re%3A%20Trakka%20gas% 20cooker> . Reply to
> group
> Reply via Web Post
> All Messages (4)
> <richo1166@...? subject=Re%3A%2014%22%20verse% 2015%22%20Wheels>
> ask anyway.
> car anyway...?
> Thanks :)
> Reply to sender
> <richo1166@...? subject=Re%3A%2014%22%20verse% 2015%22%20Wheels> . Reply
> to group
> Reply via Web Post
> All Messages (3)
> energysustained@...
> <energysustained@...? subject=Re%3A%2014%22%20verse% 2015%22%20Wheels>
> On Wed, 2 Nov, 2016 at 11:04, richo1166@...
> ask anyway.
> car anyway...?
> Thanks :)
> Reply to sender
> <energysustained@...? subject=Re%3A%2014%22%20verse% 2015%22%20Wheels> .
> Reply to group
> Reply via Web Post
> All Messages (3)
> <plander@...? subject=Re%3A%2014%22%20verse% 2015%22%20Wheels>
> Reply to sender
> <plander@...? subject=Re%3A%2014%22%20verse% 2015%22%20Wheels> .
> Reply to group
> Reply via Web Post
> All Messages (3)
> Visit Your Group
> Unsubscribe
Neil.
From: "Roger Bayley gullyraker53@... [Syncro_T3_Australia]" <Syncro_T3_Australia@ yahoogroups.com>
4 Messages
Digest #3690 1a Re: Trakka gas cooker by richo1166 2a 14" verse 15" Wheels by richo1166 2b Re: 14" verse 15" Wheels by "Tom Mischler" energysustained@... 2c Re: 14" verse 15" Wheels by hdvwoc
Messages
1a
richo1166
Preview by Yahoo
2a
richo1166
2b
On Wed, 2 Nov, 2016 at 11:04, richo1166@... [Syncro_T3_Australia]<Syncro_ T3_Australia@yahoogroups.com> wrote:
2c
hdvwoc
From: "neil smith jackthebearau@... [Syncro_T3_Australia]" <Syncro_T3_Australia@ yahoogroups.com>
Neil.
4 Messages
Messages
1a
richo1166
Preview by Yahoo
2a
richo1166
2b
2c
hdvwoc
That's a good comparison Richard - gives us some real-world feedback.
Are you running BFG's on the 15" rims? Do they rub anywhere on the bodywork when travelling cross-country?
I measured my fuel consumption over a known distance - a 200km trip that I do regularly over a mixture of roads, from country highway to dirt, criss-crossing the Great Dividing Range between Goulburn and Bathurst via short-cuts and back-roads. That negated the difference in speedo reading.
There are plenty of steep climbs and sharp bends, and I have to change back to 2nd on a few of the steep pinches that I used to conquer in 3rd with the stock rims, which probably accounts for the extra fuel.
Great scenic drive through bushranger country, but unfortunately they keep improving the road, so now I have to take short-cuts to find enough dirt to make it fun.
One of my greatest joys is to pass everyone on the road when it snows. That's where the Syncro shows its balance and poise to great advantage over lesser 4WD's.
Excellent four-wheel-drifters in the snow or gravel.
Gotta keep up that momentum!
Roger.
Sounds like a wonderful trip Roger! Certainly what the Syncro's are built for. I still remember the first few off road trips in mine, and am still impressed with where it has taken me (as a novice off roader). Not been in the snow, but have done a lot of very loose gravel roads, both in 2WD and AWD. Whole world of difference to drive in AWD, and I guess like you see in the snow.
My setup is a little different as I have taken these from my T2 bus (figured I would wear the tires down before looking for something better). I have Merc rims, 6.5J15, ET49 with Yokohama Geolanders. This fitted nicely under the T2 with no body or suspension mods.
Have never rubbed anywhere, and have certainly bottomed the suspension front and rear in my travels.
Have heard good things on the Geolanders, but cannot say I have been impressed with them, mainly due to road noise, uneven wear pattern and they seem to be a magnet for picking up and holding onto small stones. They are quite old now, so probably no longer a current model
I should add on my fuel consumption, I have not done an indepth study, as in repeat a know trip etc, this is just watching each time I fill up. I don't have any "regular" runs, so my driving is always varied.
Roger.
Hi all, just looking at the attached photo. It's a bit hard to read the name on the tyres, are they Geolanders and are they on the original 14" rims?
Andy
Yes Yokohama Geolander, 215/75R15's on Merc rims.
I painted the rims factory colour and put clips on them to take the original hub caps for a stock look.
Andy
Thanks Richard, great idea! Did you make up the clips or buy them it looks great. What offset are this rims?
Andy
Hey Andy,
The clips are early VW (used on wide 5 rims). It does not pull the hubcaps hard against the rim, so needs a bit of foam to keep it all firm. If you are handy and got some good spring steel you could make something a little better. The clips are held on with pop rivets (stainless)
The offset is not ideal (ET49, compared to 30 for stock). I got these for my T2 many years ago, and they fit a stock T2  without modification (only slight rubbing at full lock on the front only)
Andy
I too am running BFG 215-15s on my doka they rubbed the wheel arch in full lock when going over a kerb but new springs and shocks fixed that problem.
New problem. Some times it is impossible to select !st & reverse gear without great force could it be the slippers on the selector fork or that the fork is damaged, i had Paul Muller check it and he said that it was ok he installed grease to the gear stick, problem is still there.
Bob
Sent: Tuesday, November 8, 2016 11:55 PM
Subject: [Syncro_T3_Australia] Re: Digest Number 3691 [1 Attachment]
Have heard good things on the Geolanders, but cannot say I have been impressed with them, mainly due to road noise, uneven wear pattern and they seem to be a magnet for picking up and holding onto small st ones. They are quite old now, so probably no longer a current model
I measured my fuel consumption over a known distance - a 200km trip that I do regularly over a mixture of roads, from country highway to dirt, criss-crossing the Great Dividing Range between Goulburn and Bathurst via short-cuts an d back-roads. That negated the difference in speedo reading.
Roger.
Hey Richard I might have to give it a go, I've been wondering if it is possible to use the original hubcaps somehow on the merc rims, worth a try! I haven't fitted my wheels yet, still working out which tyres I want to run so I might try the clips first. My rims are et37 which is a bit closer to standard.
Andy
Hi Dale,
Best thing to do is get underneath and have a look at all the guides. Start from one end and follow it through, there are a number of guides that can wear. The most likely though is at the gear box end
Here's a kit of parts that can wear out (other vendors sell parts also)
Shifter System Overhaul Bundle | GoWesty
Hi Andy, I will try and get some pictures for you
These are the clips, should be easy to get locally (I got mine from Mick Motors)
http://dasrestoparts.com.au/media/catalog/product/cache/1/image/800x800/03d12213f51cf30066853880a6dd7cae/e/_/e_10.jpg
That would be great thanks
Andy
