Re: [Syncro_T3_Australia] Main Coolant Pipes front to rear - Where do you get them?
thats the one     bob
Sent: Friday, September 09, 2011 3:12 PM
Subject: Re: [Syncro_T3_Australia] Main Coolant Pipes front to rear - Where do you get them?
Just Kampers have them.
> Scott Pitcher <spbconsulting@bigpond.com> wrote:
> Hi all,
> My syncro has developed what appears to be a common problem since I
> replaced the water pump on my scooby syncro which is the coolant pipes
> have split up near the radiator at the front of the vehicle which is
> spewing coolant out everywhere.
> My mechanic tried his usual supplier of after-market parts and found
> they are no longer available.
> Is there anywhere else that sells these or are stainless steel pipes the
> go? If so where do you get them in Sydney or Central Coast.
> I need to try and get them before Old Bar and in the syncro if possible.
> Any help is greatly appreciated.
> Thanks,
> Skot
If not Just Kampers (which is probably cheaper) we had exactly the same problem just recently and got a set from GoWesty. Took a couple of weeks or so to arrive, though.
Francesca.
On 9 September 2011 15:21, Bob Dale <rcdale@bigpond.com> wrote:
thats the one bob
> Hi all,
> Thanks,
> Skot
Thanks all.
Apparently the syncro ones are different to the 2wd?
Is that correct?
I want to make sure I get the correct ones.
Francesca.
thats the one bob
> Hi all,
> Thanks,
> Skot
Yes, that is correct. Good luck.
Francesca.
On 9 September 2011 16:20, Scott Pitcher <spbconsulting@bigpond.com> wrote:
Thanks all.
Is that correct?
Francesca.
thats the one bob
> Hi all,
> Thanks,
> Skot
Yes different and more expensive.
Sent: Friday, 9 September 2011 4:20 PM
Thanks all.
Is that correct?
Francesca.
thats the one     bob
> Hi all,
> Thanks,
> Skot
As with all things Syncro.... But you can buy a repair kit from GoWesty for just the front radiator hoses that Skot is referring to for around US$50 + postage. I think it came to around $70 all up.
Francesca.
From: Scott Pitcher <spbconsulting@bigpond.com>Sent: Friday, 9 September 2011 4:20 PM
Thanks all.
Is that correct?
Francesca.
thats the one bob
> Hi all,
> Thanks,
> Skot
I wonder how much of the problem is caused buy owners using the incorrect coolant or tap water?
> I would have to agree with Phill after seeing hoses kark it on cars just
> five or six years old!
> [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of
> plander@optusnet.com.au
> Sent: 10 September 2011 12:30
> Subject: Re: Re: [Syncro_T3_Australia] Main Coolant Pipes front to rear
> > Seems like all of these that are regularly used will have this coolant
> > pipe issue as it is clearly a very weak point in the system.
> ..........after 20 years
Set up a poll on the topic, might be enlightening.
Date: Sat, 10 Sep 2011 14:27:07 +1000
Subject: Re: RE: Re: [Syncro_T3_Australia] Main Coolant Pipes front to rear - Where do you get them?
