Is it safety in case of an accident or is it to do with theft of the vehicle or neither.
I ask because I need to remove the dash and have read elsewhere that people put back the steering column using a normal metal bolt. regards Greg
Without going out in the cold and wet to have a look, it is usually a part of passenger safety design. It decouples the upper part of the steering column early in the crush/crumple phase of frontal impact.
Behalf Of Greg
Sent: 24 April 2012 14:29
To:
Shear Bolt
Hello, does anyone know the reason there is are shear bolts on the
steering column?
neither.
> Greg,
> [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Greg
> Subject: [Syncro_T3_Australia] Shear Bolt
> Hello, does anyone know the reason there is are shear bolts on the steering
> column?
> or neither.
--- In Syncro_T3_Australia@yahoogroups.com, Gullyraker@... wrote:
> It's a while since I pulled one apart Greg, but from memory I think I had
> no trouble undoing them with and "Ezy-out".
> Cheers, Roger [Beetle].
> steering column?
> vehicle or neither.
> Greg
On 4/23/2012 10:45 PM, plander@optusnet.com.au wrote:It's for theft.
> steering column?
> vehicle or neither.
> Greg
--- In Syncro_T3_Australia@yahoogroups.com, "Greg" <greg_navarro95@...> wrote:
> Thanks Roger, I have just ordered a couple of the shear bolts through our local VW dealer for $6.50 ea.
> Greg
> Greg
On 5/14/2012 5:03 AM, Greg wrote:
I have just collected my shear bolts for the steering column from the local VW dealer. they aren't what I expected and I just wanted to check I have the right thing.
These are made of metal (I thought for some reason they would be nylon).
They have a head that an allen key fits into (I am sure these have a name).
and under the head they have an odd shape that starts narrow at the top and widens at the base. Presumably the head breaks off as you tighten them into place. (is this right.)
Greg
> Greg
--- In Syncro_T3_Australia@yahoogroups.com, Scott Daniel - Turbovans <ScottDaniel@...> wrote:
> you got it.
> Designed for the top part of the head to break off when you tighten it.
> surprised they are even available.
> what did they cost ? if you don't mind saying.
> they wouldn't be nylon, especially for the era of when they first
> started using that part.
> and the shear strength of that diameter nylon would be near zilch.
> > name).
> > Greg
> > <mailto:Syncro_T3_Australia%40yahoogroups.com>, "Greg"
> > > Greg
> > think I had
On 5/14/2012 2:12 PM, Greg wrote:
Thanks Scott and Greg for confirmation.
The price of the bolts are AUD$6.50ea.
Greg
> you got it.
> > name).
> > Greg
> > > Greg
> > think I had
> like a gallon of gas each then, roughly, I take it.
> gas where I am is currently $ 4.25 US per US gallon.
> not hard to think of things in terms of how much gas what they cost will
> buy. Kinda fun actually.
> > Greg
> > <mailto:Syncro_T3_Australia%40yahoogroups.com>, Scott Daniel -
> > > you got it.
> it.
> > nylon).
> a
> > > > name).
> > > > Greg
> > > > > Greg
> > > > think I had
> Were the originals shear bolts?
> > > Greg
> > > Turbovans <ScottDaniel@> wrote:
> > > > you got it.
> > it.
> > the
> > > nylon).
> > a
> > > > > name).
> > the
> > > > > Greg
> > > > > > Greg
> > > > > think I had
> To be honest Phill
> I havent looked
> Greg
> > Phill
> will
> > > > Greg
> > > > > you got it.
> tighten
> > > it.
> first
> zilch.
> from
> > > the
> to
> be
> > > > nylon).
> have
> > > a
> > > > > > name).
> at
> > > the
> you
> > > > > > Greg
> bolts
> > > > > > > Greg
> memory I
> > > > > > think I had
> To be honest Phill
> I havent looked
> Greg
> > Phill
> will
> > > > Greg
> > > > > you got it.
> tighten
> > > it.
> first
> zilch.
> from
> > > the
> to
> be
> > > > nylon).
> have
> > > a
> > > > > > name).
> at
> > > the
> you
> > > > > > Greg
> bolts
> > > > > > > Greg
> memory I
> > > > > > think I had
