Stranded Pt 2
Turns out our Syncro had a meltdown in its catalytic converter. No wonder it felt as though there was a potato up the pipe as we struggled along the Princes (glorified goat track that is). New aftermarket one fitted. Chugging along nicely now. Readying ourselves for the next adventure!
Francesca.
Francesca,
Did Lloyd venture an opinion as to why it melted?
Sent: 09 July 2010 15:39
Subject: [Syncro_T3_Australia] Stranded Pt 2
Francesca.
Well done Francesca.
Great to hear it was just a minor thing and not really the motor causing he problem.
Happy trails from here on!
Sent: Friday, July 09, 2010 3:38 PM
Francesca.
Thanks, Skot.
In response to your question Les, I did ask Lloyd why he thought the meltdown happened. He said possibly it was the AFM/Vanagon syndrome problem, leading to a too-lean mixture overheating the converter (I think I got that right). Next thing will be to tackle this, I guess.
From what I understand it could also be symptomatic of some as-yet-undiagnosed problem. I'm going to get Tony to quiz him more on this when he picks it up later. Anyone here have any considered opinions to add? I'd hate to chew through another converter in short order.
Of course it could just be that the shelf life on an ageing part was up, I guess.
Francesca.
On Fri, Jul 9, 2010 at 3:54 PM, Mr Scott Pitcher <spbconsulting@bigpond.com> wrote:
Francesca.
Francesca,
I asked because I thought that it might have been AFM related, which brings us back to the VAG modified harness for the AFM.  You now need to determine if your Syncro has it or not.
Sent: 09 July 2010 16:03
Subject: Re: [Syncro_T3_Australia] Stranded Pt 2
Thanks, Skot.
Francesca.
On Fri, Jul 9, 2010 at 3:54 PM, Mr Scott Pitcher <spbconsulting@ bigpond.com> wrote:
Subject: [Syncro_T3_Australi a] Stranded Pt 2
Francesca.
Thanks, Les. To be honest I haven't checked, assuming that it doesn't, given that we experience intermittent Vanagon Syndrome (which we have ignored at our peril). I don't think we'll drive it too much further before fitting one, however. On that note, how do we get hold of one? Any joy to be had through VW dealers??? Or can you purchase them from the US? I gather that faulty O2 sensors can also superheat cat converters.
Francesca.
On Fri, Jul 9, 2010 at 4:05 PM, Les Harris <leslieharris@optusnet.com.au> wrote:
Francesca,
Thanks, Skot.
Francesca.
Francesca.
Francesca,
I think that it is still available as a VAG part but if it isn’t, Mike Plompen would likely have it.  Ben Tan would know about availability in the US .
And, yes, the O2 sensor might be suspect.  They should be available and should be inexpensive.
Sent: 09 July 2010 16:17
Thanks, Les. To be honest I haven't checked, assuming that it doesn't, given that we experience intermittent Vanagon Syndrome (which we have ignored at our peril). I don't think we'll drive it too much further before fitting one, however. On that note, how do we get hold of one? Any joy to be had through VW dealers??? Or can you purchase them from the US ? I gather that faulty O2 sensors can also superheat cat converters.
Francesca.
> given
> at
> one, however.
I doubt if that was the cause. You would notice VS and stop the car. Then you would restart it and it would be OK.
I gather that
Unlikely as the O2 sensor is only a fine adjustment. You can disconnect them and the car will run fine.
Probably age related. Was there a banging/rattling noise?
Could be poor fuel related.
> US.
More common in the US than Germany.
Thanks, Phil.
Need to fit AFM harness in any case, even if not the cause.
No banging or rattling.
Should I be concerned about the risk of fire, now that this has happened, if there is an underlying problem? Don't like the thought of kids in the back seat with meltdowns happening under their bottoms (well, more or less). It wouldn't be that fuel is entering the exhaust, I hope....
Francesca.
> US.
Francesca,
Cats are designed with this in mind and the ‘melt-down’ is confined to the inside of the Cat.  The boy’s bums are safe!
Sent: 09 July 2010 16:45
Subject: Re: RE: [Syncro_T3_Australia] Stranded Pt 2
Thanks, Phil.
Francesca.
The only fire risk is described in the owner's manual.
Do not park on dry grass after a long drive.
I'd like to know what he meant by "meltdown" ???????
Cats can be repaired with a broom handle. Just shove it up the pipe and mash up the internals. It'll get you home and drive normally until you replace it.
> Francesca Coles <fcoles6@gmail.com> wrote:
> Thanks, Phil.
> happened, if
> back
> It
> Francesca.
> availability
> > in the
> > > US.
Yes, they are still available here. We have a friend at the VW dealership in Southern California. Rennie Wibble is the parts manager and active on both the Vanagon and worldwide Syncro List. Pmail me for his contact info. He is very good at working around VW rules on ordering parts not ordinarily available in his territory.
Sent from my discarded AFM harness
On Jul 8, 2010, at 11:28 PM, "Les Harris" <leslieharris@optusnet.com.au> wrote:
Francesca,
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com ] On Behalf Of Francesca Coles
Francesca.
Ben,
Thanks for the info.  It has now penetrated my brain that I haven’t ever checked to see if I have the modified harness or not.  I assume that it will have a different part number.
(Sent from my electric toothbrush.)
Sent: 09 July 2010 16:58
Yes, they are still available here. We have a friend at the VW dealership in Southern California . Rennie Wibble is the parts manager and active on both the Vanagon and worldwide Syncro List. Pmail me for his contact info. He is very good at working around VW rules on ordering parts not ordinarily available in his territory.
I think my fevered imagination was working overtime there. Glad to hear that boys (and bums) are safe. Will, however, studiously avoid parking over flammable flora after long drives, especially on days of extreme fire danger...
Like the broom handle remedy - sometimes agricultural methods come into their own. Might pack one for that express purpose! Or maybe any Jo-Blow stick out in the bush will do, if handled skillfully.
I guess 'melted to the point of partial obstruction' might explain it.
Francesca.
> Thanks, Phil.
> happened, if
> back
> It
> Francesca.
> availability
> > in the
> > > US.
If it's available in the US, it's available here.
> BenT
> > Francesca,
> > I think that it is still available as a VAG part but if it isn��������t, Mi
> > ity in the US.
> > Les
> > Coles
> > Francesca.
It's not a modified harness but like a short adapter harness like the ones they have for converting trailer plugs. Here are some photos;
http://www.telusplanet.net/public/gary2a/rack/afmharness/afmharness.htm
> Ben,
> Thanks for the info. It has now penetrated my brain that I haven't ever
> will
> [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of BenT Syncro
> dealership in
> both
> is
> BenT
It would of been an expensive recall!
> > Les Harris <leslieharris@...> wrote:
> > Ben,
> > will
> > Les
> > _____
> > dealership in
> > both
> > is
> > BenT
Not a recall.
It was a secret that you only found out about if you did a lot of complaining. I only found out through inside information after much time looking for fuel problems! It cost me $$$$ changing fuel filters, using injector cleaners etc.
> > > Ben,
> ever
> it
> > > will
> > > Les
> > > _____
> Syncro
> > > dealership in
> on
> > > both
> info. He
> > > is
> ordinarily
> > > BenT
I meant it would of been expensive,if it was a recall.Thats why it was a secret!
> Not a recall.
> > > > Les Harris <leslieharris@> wrote:
> > > > Ben,
> > ever
> > it
> > > > will
> > > > Les
> > > > _____
> > Syncro
> > > > dealership in
> > on
> > > > both
> > info. He
> > > > is
> > ordinarily
> > > > BenT
