----- Original Message -----From: plander@optusnet.com.auSent: Wednesday, December 03, 2008 10:15 AMSubject: Re: Re: [Syncro_T3_Australia] New MemberI never really noticed it until somebody showed it to me. I have to try to make it bump.
> Gary Cookson <gary@twentytwentyon e.net> wrote:
> Interesting, i have the same bang issue but it only happened when i
> fitted new rear shocks (Bilsteins). I'm pretty sure with the old
> shocks I didn't get the noise. I hadn't got any further with
> investigating though.
> Anyone else?
> [2 0 / 2 1 Design]
> 28 Gwynne St
> Richmond
> Vic 3121
> www.twentytwentyone .net
> Tel 3 9429 1868
> Fax 3 9421 1110
> Mob 0417 352782
> On 03/12/2008, at 5:57 AM, plander@optusnet. com.au wrote:
> > . It appears the
> > > vehicle is sitting a couple of inches higher than normal on 14" rims
> > > and the back end fairly bangs coming off speed bumps. Not sure
> > whether
> > > to change the springs back to original spec or the shockies. The
> > front
> > > is the same height but rides beautifully.
> > The bang really is normal. It is just the suspension stop is inside
> > the shock absorber. If you have taller springs it will happen more
> > often.
> If the stop is inside the shock absorber, as has been suggested, itThere is not much room in the rear shocks for a decent compressible component. It's not a metal2metal sound. Just the sound of the shock reaching the limit.
> would never be metal to metal. There would be a compressible component
> to take the load progressively before the limit is reached. I have
> never had to look into this before but I will do some checking now that
> the matter has been raised.
To try it out, come off a steep speed hump at a 45 degree angle so that the wheel drops to full travel before hitting the ground.
28 Gwynne St
Richmond
Vic 3121
gary@twentytwentyone.net
www.twentytwentyone.net
Tel 3 9429 1868
Fax 3 9421 1110
Mob 0417 352782
Mine don't bang and I would be a bit alarmed if they did.Normally, the up travel in a suspension system is limited by bump stops, not the shockers, and these bump stops compress before the spring goes solid. Similarly, the downward limit usually has a mechanical restraint rather than a hydraulic restraint. If it was otherwise, the shockers would be getting a lot of punishment that they weren't designed to take.If the stop is inside the shock absorber, as has been suggested, it would never be metal to metal. There would be a compressible component to take the load progressively before the limit is reached. I have never had to look into this before but I will do some checking now that the matter has been raised.If a vehicle has taller springs fitted, it will also need to have shockers that have the correct stroke and the correct end point of up and down stroke.I have never hit a speed bump very hard so it could be that I have not reached the limit referred to here, but I know of no vehicle where the limit is metal to metal.Greg,I am running B F Goodrich All Terrains 215-75-15, which are 20 mm bigger diameter than the 8.5-27-14 BFG's. Measuring from under the wheel arches to the ground, I have 800 mm front and 820 mm rear. Take 20 mm off those figures and I would have 780 and 800. St first sight, the Syncro looks like it has been jacked up but they are all the same.And, on the subject of tyres, you must NEVER run dissimilar tyre sizes front and back. Doing so stuffs the Viscous Coupling very quickly.Les----- Original Message -----From: plander@optusnet. com.auSent: Wednesday, December 03, 2008 10:15 AMSubject: Re: Re: [Syncro_T3_Australi a] New MemberI never really noticed it until somebody showed it to me. I have to try to make it bump.
> Anyone else?
> [2 0 / 2 1 Design]
> 28 Gwynne St
> Richmond
> Vic 3121
> Tel 3 9429 1868
> Fax 3 9421 1110
> Mob 0417 352782
> > . It appears the
> > whether
> > front
> > often.
I am having our local retired VW legend Kevin Rowlands get under the
thing next week and take off a shockie and check the springs etc.
I have BFG All terrains on at the moment but they are bit noisy on
the black top.
I have 16" alloy rims and a set of 14" steel wheels.
I am not sure what tyres to put on for all round performance (99% of
driving will be on good roads) ie noise and reasonable off road
capability and I am not sure if I should use the 16s or 14s.
Does anyone have any ideas?
and down stroke.
> Greg,
the same.
quickly.
> From: plander@...
> Phillwhen i
> > fitted new rear shocks (Bilsteins). I'm pretty sure with theold
> > shocks I didn't get the noise. I hadn't got any further with14" rims
> > Anyone else?
> > [2 0 / 2 1 Design]
> > 28 Gwynne St
> > Richmond
> > Vic 3121
> > gary@...
> > Tel 3 9429 1868
> > Fax 3 9421 1110
> > Mob 0417 352782
> > On 03/12/2008, at 5:57 AM, plander@... wrote:
> > > . It appears the
> > > > and the back end fairly bangs coming off speed bumps. Notsure
> > > whethershockies. The
> > > frontinside
> > > the shock absorber. If you have taller springs it will happenmore
> > > often.
----- Original Message -----From: ngreg61Sent: Saturday, December 06, 2008 6:05 PMSubject: [Syncro_T3_Australia] Re: Suspension Travel & ShockersThanks Les
the black top.
Does anyone have any ideas?.![]()
