T3 gear box
Once your bearing looks like this, you better stop. This is the inner race of the
Pinion main bearing
Looks noisy.
What else needs replacing?
How many kms?
Is this the TriStar box?
> race of the
> Pinion main bearing
> Hart
Looks noisy.
How many kms?
> race of the
> Pinion main bearing
> Hart
Hart,
That looks like the roads around the Central Coast of NSW.
Good job you had it fixed before it did any major damage.
See you up @ Valla soon.
Pinion main bearing
Sent from my WalkingStick!
Greetings Hart
Is this the 1st time for a gearbox overhaul for the Tristar?
Bob
Skot, I think the Central C roads did it, went there after the Nationals....( to be honest, it started going down to SYD) Ha.
Sent: Wednesday, 13 June 2012 4:04 PM
Subject: Re: [Syncro_T3_Australia] T3 gear box
Hart,
Pinion main bearing
It wouldn't be the first vehicle to suffer because of our crappy roads.
Good thing it was the camper and not Big Red!
Hart,
Pinion main bearing
250 000 km Trakka , Syncronizer rings have hairline cracks, shiftrod bushing (1 only) , c/w-pinion are ok.  Hart
So the moral of the event, if you notice a noise from the g/box stop and have it checked, the main bearing   ( $340)  is the weak link . If in doubt check the magnetic oil plug for metal shavings.
Sent: Wednesday, 13 June 2012 3:57 PM
Looks noisy.
How many kms?
> race of the
> Pinion main bearing
> Hart
Hart what are your thoughts on the aftermarket SA oiling plates as i understand they help the oiling of the gearbox mainshaft bearing??
You certainly have explored areas of our machines that terify mere mortals. Are you contemplating a decoupler for the Trakka.
Keep up the good fight
Regards Pete
> Hart
> plander@...
> Looks noisy.
> How many kms?
> > race of the
> > Pinion main bearing
> > Hart
Pete,   don’t wanna  frighten you, just always show awareness to your senses like hearing. If there is an unusual noise, do something about it, doesn’t have to be expensive if you catch it in the early stages.
Re decoupler, wouldn’t have a T3 without it.
Oiling plates, although it’s hard to tell if they are any good, but they certainly can’t do any harm. I’m contemplating to install oil cooling, just looking for an oil pump, the rest I have got .
Just ANOTHER project.
Colourful Greetings,  Hart
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Anette
Sent: Thursday, 14 June 2012 11:28 AM
Subject: [Syncro_T3_Australia] Re: T3 gear box
Regards Pete
> Hart
> plander@...
> Looks noisy.
> How many kms?
> > race of the
> > Pinion main bearing
> > Hart
Remember the oiling plates were put in by factory engineers. They found a need with the 5cyl motor and it extended the life of the gearbox. Cheap insurance!
> Pete, don't wanna frighten you, just always show awareness to your
> senses
> doesn't
> Re decoupler, wouldn't have a T3 without it.
> Oiling plates, although it's hard to tell if they are any good, but they
> certainly can't do any harm. I'm contemplating to install oil cooling,
> just
> mortals.
> Regards Pete
> <mailto:Syncro_T3_Australia%40yahoogroups.com> , "Hartmut Kiehn"
> bushing
> and
> doubt
> > Hart
> <mailto:Syncro_T3_Australia%40yahoogroups.com> ] On Behalf Of
> > plander@...
> > Looks noisy.
> > How many kms?
> > Phill
> <mailto:hartis@...%20%3cmailto:hartis%40live.com.au>
> inner
> > > race of the
> > > Pinion main bearing
> > > Hart
Point taken , a bit like the de coupler, also a factory development or the flat 6 which was built by öttinger...
Ha
> senses
> doesn't
> just
> mortals.
> Regards Pete
> bushing
> and
> doubt
> > Hart
> > plander@...
> > Looks noisy.
> > How many kms?
> > Phill
> inner
> > > race of the
> > > Pinion main bearing
> > > Hart
Hart yes they can run hot on hiway running and an oil cooler would be a great thing..
Please take some pics and put in the photos as I cant access the photos in messages.
Cheers Pete
> Ha
> > Phill
> > > senses
> > > doesn't
> > > just
> > > mortals.
> > > Regards Pete
> > > bushing
> > > and
> > > doubt
> > > > Hart
> > > > plander@
> > > > Looks noisy.
> > > > How many kms?
> > > > Phill
> > > <mailto:hartis@%20%3cmailto:hartis%40live.com.au>
> > > inner
> > > > > race of the
> > > > > Pinion main bearing
> > > > > Hart
I am also interested in your set up Hart. A good quality, quite pump is pricey. Are you using the drain and fill holes or tapping new ones. I like the idea of having the return oil showering down on all the important bits. Greg E
Sent: Thursday, 14 June 2012 4:07 PM
Cheers Pete
--- In mailto:Syncro_T3_Australia%40yahoogroups.com, Hartmut Kiehn <hartis@...> wrote:
> Ha
> > Phill
> > > senses
> > > doesn't
> > > just
> > > From: mailto:Syncro_T3_Australia%40yahoogroups.com
> > > [mailto:mailto:Syncro_T3_Australia%40yahoogroups.com] On Behalf Of Anette
> > > To: mailto:Syncro_T3_Australia%40yahoogroups.com
> > > mortals.
> > > Regards Pete
> > > bushing
> > > and
> > > doubt
> > > > Hart
> > > > plander@
> > > > Looks noisy.
> > > > How many kms?
> > > > Phill
> > > inner
> > > > > race of the
> > > > > Pinion main bearing
> > > > > Hart
Aeration has to be guarded against on the return side.  It should not be a problem after the oil has been through a cooler but should be kept in mind.
Sent: 14 June 2012 16:36
Subject: Re: [Syncro_T3_Australia] Re: T3 gear box
,___
Thanks Les, always nice to have a professional on hand. So is it best to have the pump before the cooler? Is the shape of the outlet important? As I was saying finding the right pump is the hard thing. Something small with lots of flow but not pressure. Greg E
Sent: Thursday, 14 June 2012 4:42 PM
Subject: RE: [Syncro_T3_Australia] Re: T3 gear box
,___
Greg, Haven’t started yet, but seeing the gearboxes at Ron’s w/shop, the ones he builds for off road racing, which almost all have oil cooling with return of oil over c/w and pinion, gave me ideas.
Les, could you give us some more info on the aeration and what to watch for? As my g/box is out, now would be the time to do the fittings etc. And Ron would be the right person to do it as he is doing it all the time. He suggested not to use the drain as a pick up point because of its low position.
Sent: Thursday, 14 June 2012 4:36 PM
Cheers Pete
> Ha
> > Phill
> > > senses
> > > doesn't
> > > just
> > > mortals.
> > > Regards Pete
> > > bushing
> > > and
> > > doubt
> > > > Hart
> > > > plander@
> > > > Looks noisy.
> > > > How many kms?
> > > > Phill
> > > inner
> > > > > race of the
> > > > > Pinion main bearing
> > > > > Hart
Hart and Greg,
Ron has homed in on a key factor when he says not to pick up from the lowest point.
It is essential to have a safety margin in the event of an oil leak in the cooler circuit.  If the pickup is from the lowest point, the pump will very quickly empty the gearbox.  If it is above, the pickup position needs to be such that some gears are still able to touch the sump oil and therefore fling oil around the interior of the box.  (You can still use the drain plug but with a standpipe to set the level.)
With full dry sump engines and gearboxes, the oil being picked up by the pump is already aerated because it has already been flung around.  (The insides of engines and gearboxes are extremely busy places!!)  Before being returned to the sump, the oil is usually run through a pepper pot which allows the air to separate out.
In the case of a partial dry sump (picking up from above the lowest point), there will still be some entrained air in the oil but this tends to separate out as it travels through the oil cooler.  When it gets back to the gearbox, it can run through a horizontal pipe above the gear sets with outlet holes over each gear set.
There is certainly a it of work involved but, give the ambient temperature that are common on Australia road surfaces, it is a very good move.
PS: Greg, pump first, then the cooler.
Sent: 14 June 2012 17:26
Greg,  Haven’t  started yet, but seeing the gearboxes at Ron’s w/shop, the ones he builds for off road racing, which almost all have oil cooling with return of oil over c/w and pinion, gave me ideas. Les, could you give us some more info on the aeration and what to watch for? As my g/box is out,  now would be the time to do the fittings etc. And Ron would be the right person to do it as he is doing it all the time. He suggested not to use the drain as a pick up point because of its low position. Hart
Can you get pics of his sand rail setups Hart? Also finding out if he could advise/supply pumps would be good too. So he just dumps all the return straight onto the c&p? Greg E
Sent: Thursday, 14 June 2012 5:57 PM
Hart and Greg,
Greg, I will go over on Saturday and try to find out more .Ha.
Hart and Greg,
,_._,___
