Tail shaft sleeve bearing
Got a graphite sleeve bearing fromTreotham in NSW.
Reduced ting noise considerably
Details in attatchment
Philippe (Perth)
Thanks all for the replies.
Sounds like the best I can do is leave it as is and use until things wear out. As mentioned it runs fine with no play, I was just hoping to extend it's life with some fresh grease.
Strange on the tinging there from new, I don't remember it when I first bought the bus. I did a few thousand km before I started to remove it when not required. Was really only noticeable on this trip away.
I have the ting in 4wd when coming off the power or changing gears. Dismissed it as rarely have the de-coupler disengaged so good to know it was there since new.
Jon.
On 30 Oct 2016 9:19 PM, "cathrich1@yahoo.com.au [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:
Pack it with grease and you will probably only notice it reversing. Gregor
Sent from Greg's iPhone
On 30 Oct 2016, at 9:19 PM, cathrich1@yahoo.com.au [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Also replace the oring to keep the grease in. Gregor
On 31 Oct 2016, at 8:37 AM, gregespo73@yahoo.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
