Tom Hanks, Syncro Owner
He may even look at this form!
I can't make it to Vw '09, building house, moving, kid, pregnant wife, etc have a good one, the weather will be great!
Campbell Miller
Classic!    :-))))
I think he needs a long range tank and a better fuel gauge.
Sent: Thursday, November 12, 2009 9:56 PM
Subject: [Syncro_T3_Australia] Re:Tom Hanks, Syncro Owner
Classic!    :-))))
Les,
Make sure that the link does not contain extras .eg. ">"
Sometimes it is better to cut and paste the link into your URL bar and edit out the extra bits.
> Ken,
> I am having massive computer problems at the moment and can't fix them
> until
> after the DOTVW is past. One of the problems is that I can't open email
> links and I don't know what is being discussed. Could you give me a
> quick
> description of it?
> -----Original Message-----
> [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Ken Garratt
> Sent: 13 November 2009 08:45
> To: Syncro_T3_Australia@yahoogroups.com.au
> Subject: FW: [Syncro_T3_Australia] Re:Tom Hanks, Syncro Owner
> I think he needs a reality check.
> Classic! :-))))
The problems are related to a prior instability of this PC.
I elected to run the Windows Repair function instead of doing a fresh install of the OS, which proved to be a mistake.  Amongst many other things that it comprehensively stuffed, it wiped Internet Explorer 8 entirely and replaced it with IE 6, with the result that none of the bookmarks will open on this PC (but OK on the laptop) and all of the existing File Associations (which also control opening email links), with the result that I can’t open them on the PC.
It is all fixable but I just don’t have the time before the DOTVW.  I have a few things on my plate, including the fact that the Syncro engine is misbehaving.  It is idling too fast after a normal local run, then won’t hot start.  I could really have done without that immediately before the DOTVW!!!!
Sent: 13 November 2009 09:12
Subject: Re: RE: [Syncro_T3_Australia] Re:Tom Hanks, Syncro Owner
Les,
I don't know about your computer but things to check on your syncro;
Throttle position switch on the throttle body.
Vaccuum leaks.
> Phill,
> things
> and
> open
> Associations
> (which also control opening email links), with the result that I can't
> open
> them on the PC.
> It is all fixable but I just don't have the time before the DOTVW. I
> have a
> misbehaving. It is idling too fast after a normal local run, then won't
> hot
> DOTVW!!!!
> Les,
> edit
> out the extra bits.
Hi Cam, that's a shame, i was expecting the same neighbours as last year!
Bring them all, nothing like a family day out in the boiling sun looking at old VWs, houses can wait!
Gary Cookson
[2 0 / 2 1 Design]
28 Gwynne St
Richmond
Vic 3121
gary@twentytwentyone.net
www.twentytwentyone.net
Tel 3 9429 1868
Fax 3 9421 1110
Mob 0417 352782
Campbell Miller
two recommendations/suggestions -
on the syncro, check the throttle switch, I find them out of whack quite frequently. Can cause your symptoms, or be a factor.
use Mozilla Firefox over Internet Explorer.  Way mo' betta !
Have fun at your event.
Post pics too !
Sent: Thursday, November 12, 2009 2:26 PM
Subject: RE: RE: [Syncro_T3_Australia] Re:Tom Hanks, Syncro Owner
From: Syncro_T3_Australia @yahoogroups. com [mailto: Syncro_T3_Australia @yahoogroups. com ] On Behalf Of plander@optusnet. com.au
Subject: Re: RE: [Syncro_T3_Australi a] Re:Tom Hanks, Syncro Owner
Les,
I've seen that many times.
More reliable, but IE is nicer to use. (I use Firefox)
Sent: Friday, November 13, 2009 9:26 AM
for what it may be worth check the temperature sensor for the engine managment system, sounds like a problem that i had in the past, if the resistance values change it affects the idle and fuel mix, motor runs very rich, hard to start and raised rpm on idle and stalls. have fun at the meet sorry i cannot make it.
regards
bob dale
Les,
Brian,
Your dream sounds in the region of $150,000.00.
But a nice dream nevertheless.
Sent: Friday, November 13, 2009 11:12 AM
Hi Reiner,
I use this site for T5 info. http://www.brick- yard.co.uk/ forum/forum15. html . Like most fora you seem to get a high proportion of people talking about things going wrong, but I don't recall gearbox's being a regular issue. Overall, I think the consensus is that the VW, while it has some troubles, is better than pretty much all the contemporary competition. Like all modern vehicles, they are pretty complicated things, and not easy to fix yourself when things go wrong, but I guess that's the price you pay for all the nice amenities.
Maybe it's time to start saving for the new update model. Rumour has it that these will be available with a 7 speed DSG box in combination with 4 motion. Imagine then, a modification for the box with lower gearing overall and an ultra-low 1st gear (and the software set to start in 2nd unless 1st is selected), a suspension lift, big tyres, and some underbody protection. And imagine really hard for the Tattslotto winning numbers.
Brian
--- In Syncro_T3_Australia @yahoogroups. com, "Reiner Gudd" <reinerg@... > wrote:
> I nearly bought T5 but was told they have gearbox problems...is that a
> known fact or just rumors from the Toyota club? J
> After deciding not to go T5 I spend about 15k on my T3 which is not a Syncro
> ( wish it was) but still beautiful to drive, It is a 82 aircooled and will
> never leave this house I just love the car. I got a Landcruiser and a BMW
> but when I need to go somewhere the T3 is choice number one.
> Have a good weekend everybody and I hope les is getting his computer
> sorted....no fun at all
> Cheers
> Reiner
> [mailto:Syncro_T3_Australia @yahoogroups. com] On Behalf Of Alison & Bruce
> Black
> Sent: Friday, 13 November 2009 8:23 AM
> Subject: Re: [Syncro_T3_Australi a] Re:Tom Hanks, Syncro Owner
> As Tom says, people with dementia own syncros. So if we had a reality
> check we would all go and do what Brian has done - a new
> T5 !!!!!!!!!!!! !!!!!!!
> Bruce
Hi Scott,
If it included a Trakka conversion I’m sure it would be all of that and more. Still, if VW employed me as an ‘ideas consultant’, I might be able to afford it.
We all need to dream though.
BRIAN REED
FAIRFIELD NATURAL THERAPIES
185 Wingrove St
Fairfield, Vic. 3078
03 9481 5673   0407 319 521
From: Syncro_T3_Australia@yahoogroups.com [mailto: Syncro_T3_Australia@yahoogroups.com ] On Behalf Of Mr Scott Pitcher
Sent: Friday, 13 November 2009 11:16 AM
Subject: Re: [Syncro_T3_Australia] Re:Tom Hanks, Syncro Owner
Brian,
Brian,
You wouldn't accept anything less that a fully optioned Trakka conversion would you?
That's why you needed to upgrade your rear springs - all that bling = $$$ and extra weight.
Sent: Friday, November 13, 2009 11:34 AM
Subject: [Syncro_T3_Australia] RE: Dreams
Hi Scott,
BRIAN REED
185 Wingrove St
From: Syncro_T3_Australia @yahoogroups. com [mailto: Syncro_T3_Australia @yahoogroups. com ] On Behalf Of Mr Scott Pitcher
Brian,
While on the subject of T5 conversions these look rather good.
They are planning to bring them to Australia at some point.
[2 0 / 2 1 Design]
28 Gwynne St
Richmond
Vic 3121
Tel 3 9429 1868
Fax 3 9421 1110
Mob 0417 352782
I find Internet Explorer 8 is great for anyone with a Windows Live Hotmail address. Integrated into IE8 is Hotmail access directly into a hotmail mailbox with the (configured) click of a button on the browser and no need to login anymore. Just access your mailbox whenever, all day, any day. This has never been available before until IE8. Brilliant for a freeby email account. I believe no other browser can do that.
Date: Fri, 13 Nov 2009 10:16:35 +1100
Subject: Re: Re: RE: [Syncro_T3_Australia] Re:Tom Hanks, Syncro Owner
> two recommendations/ suggestions -
Brought to you exclusively by Windows Live Download new and classic emoticon packs at Emoticon World
> Les,
> Too easy. Consult your IT Administrator, he'll reinstall your specially
> configured OS from his previously saved OS image file ... you'll be up
> and running again flawlessly in say ... umm ... 20 minutes.
My IT Administrator is busy cooking dinner at the moment.
