Towbar/Bumper Mount
Um.....I made the plates the same depth as the original bumper mounting brackets.  The plates slide into the rear chassis rail and pick up on the original mounting holes.  The Trakka rear bumper on mine has the same bumper mounting holes as the original mounts, so all of the hole positioning is the same as the standard mounting.  No cut-out is needed.
Sent: Saturday, July 26, 2008 4:17 PM
Subject: Re: Re: Re: [Syncro_T3_Australia] VANAGON Telstra syncro bumper - wanted
> Les Harris <leslieharris@ optushome. com.au> wrote:
> Phill,
> Thanks for reminding me about that. It had slipped out of my memory
> but this has prompted me to find the drawings and amend them to include
> the foremost hole.
There also needs to be a bit of a cut out on the botton edge.
Get one of our Euro friends to send a picture and measurements.
Yes, but if you use the third hole, there needs to be a cutout between the third hole and where the original bumper ends. (This is very hard to explain clearly!)
Ah, I see.  I will have a look in daylight tomorrow.
Sent: Saturday, July 26, 2008 4:53 PM
Subject: Re: [Syncro_T3_Australia] Towbar/Bumper Mount
Here is a genuine towbar.
> mounting
> hole
> needed.
> > Les
> explain clearly!)
Thanks for that.  I can see the restriction.
Sent: Saturday, July 26, 2008 5:16 PM
Subject: Re: Re: [Syncro_T3_Australia] Towbar/Bumper Mount
> From: plander@optusnet. com.au
> Subject: Re: [Syncro_T3_Australi a] Towbar/Bumper Mount
> mounting
> hole
> needed.
> > Les
> explain clearly!)
