I bet you wish you were 20 years younger haha.
One needs the flexibility of Houdini to penetrate the nooks and crannies
to trace wires and connectors, it's no laughing matter eh ... as I so
painfully remember. All the more depressing when the wiring methodology
is exposed for all to be incredulous about.
See if you can get at and check out the condition of the micro
switch/connectors under and at the back of the sink that operates the
cold water tap. I found the wires to the connectors were left hanging,
the weight of the wires swinging about lasted just long enough for me to
touch them and the micro switch connectors disintegrated. It'd be a
lovely pickle to have that happen a long way from home.
If I was inspired enough, probably I could write a book about the Trakka
wiring system. Well if I was a masochist that is.
<leslieharris@...> wrote:
>have been pulling a lot of stuff out to try to generate a diagram that
> Since none of us have a wiring diagram for the Trakka conversion, I
we can all use. I am getting close to feeling that I shouldn't have
started!
>core wire and calling it a rat's nest would be very derogatory of the
> The entire vehicle has been wired with the same black/black-green dual
average rat! Splitters have been used in may places and it is clear that
the wiring was put in first and the cabinetry after, because there is no
manipulation room in a lot of places.
>intake. What is curious is that I have found only one dual core going up
> Another curious find is two dual core runs going up inside the RH air
the sleeve into the roof. Since the only need for power in the pop top
is the fluro, it's difficult to imagine what the other one is for.
>wires by the only method possible - inserting sewing needles through the
> I will tidy it up as I go along but it will be slow work. I am tracing
insulation in order to make voltage or continuity measurements. Don't
expect a definitive result any time soon.
>standard on the Gold Pak. Can anyone confirm that?
> Mine has a Cobra alarm fitted and I think that it might have been
>between the seats, under the mat in the passenger's foot well and
> There are two dual core runs from behind the fridge, up the passage
disappearing behind the fuse panel. Behind the fuse panel are other
curious objects, like a relay handing loose amongst the wires and a bus
bar. Haven't got near enough to them yet to determine what they might
be. They might or might not be associated with the alarm.
>I have a diagram for some Cobra alarms.
----- Original Message -----From: KenSent: Wednesday, November 19, 2008 6:02 PMSubject: [Syncro_T3_Australia] Re: Trakka Owners
Gday Les,
Ken.
----- Original Message -----From: plander@optusnet.com.auSent: Wednesday, November 19, 2008 6:22 PMSubject: Re: [Syncro_T3_Australia] Trakka Owners>
> aftermarket?Cobra used their own installers.
any level of Trakka conversion, but it was an optional extra for any
level of conversion. Makes sense as Phill says, they would have had
Cobra do the install whenever ordered by a customer. Cheers.
>process and I will get back to you. Was a Trakka fitting or an
> Phill,
> Wait until I have finished with the sewing needles and the tracing
aftermarket?
> From: plander@...
> Ken <unclekenz@yahoo.com> wrote:Well you wouldn't want Trakka doing any complex wiring, would you?
> Les, I understand the Cobra alarm system was not a standard inclusion on
