Unknown Part
Can anyone out there enlighten me on what the gadget is in these photos does. Does anyone else have this? I always wondered about the plug attached to the alternator but now I have removed the throttle to see what is wrong with it, the other end is now visible where it goes into the gearbox? Any advice appreciated. Peter from Port
Peter it is the old diagnostics port. The test equipment that used this left dealerships decades ago. Some cut the wire off, I like to leave them for nostalgia. Gregor
From: "peter@coeconsult.com.au [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com>
Sent: Monday, 23 November 2015, 11:16
Subject: [Syncro_T3_Australia] Unknown Part [2 Attachments]
Aha. Thanks Greg. I will now stop thinking about that and get back to my throttle issues. Have it on the bench at the moment. Look at this photo of the barrel? Big idle screw is all the way in. It was having no effect on the idle at all. Cheers, Peter
Is the micro swtich making contact at idle ?
I have seen hundreds that were not after many miles.
very important that it does.
On 11/22/2015 3:31 PM, 'Peter Coe' peter@coeconsult.com.au [Syncro_T3_Australia] wrote:
The idle air bypass will typically have no effect when there is a vacuum leak. Gregor
From: "'SDF ( aka ;jim lahey' - Scott ) ' ScottDaniel@turbovans.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com>
Sent: Monday, 23 November 2015, 15:39
Subject: Re: [Syncro_T3_Australia] Unknown Part
Yes, the idle switch is working exactly as it should. Also tested as per Bentley and got the right result as well as the audible clicks. I think it’s just drawing air through the worn barrel. Have ordered a new throttle from GoWesty and it’s on its way. Will do an update when I install.  I am taking the van down to my old home State of Tassie for 4 weeks, leaving Port Mac on 9 December so hope to have it running like clockwork by then. Peter
Thanks Scott. I checked out the micro switch on the throttle using both the Bentley process with my multimeter and also with my ears to hear the clicks. When I reinstalled the throttle as a temporary measure until my new one arrives I got a friend to operate the gas pedal and its all working fine. I hope that when I put in a replacement throttle and don’t get all that air leaking through the barrel, all will be OK.
Cheers, Peter from Port
Hi .
as you may know there is an electro-pneumatic throttle switch available ..
What a great idea ......bypassing the limitations of reading from a mechanical device ..the throttle body and throttle plate..
to making contact based on air pressure/vacuuum.
On 11/27/2015 1:28 PM, 'Peter Coe' peter@coeconsult.com.au [Syncro_T3_Australia] wrote:
Hi Scott,
Interesting. Expensive?
Got a webpage link for a source that ships overseas?
Date: 30/11/2015 6:34 PM (GMT+10:00)
Subject: Re: [Syncro_T3_Australia] Throttle
Hi .
I have one from GoWesty that is now for sale as I have received a new throttle body from GoWesty. It has not been used as it was pointless given how bad my throttle was. It’s very simple to install. Hart put one in the Tristar. Peter from Port
Happy with that thing, easy to fit, about 12mins. and not expensive. hart
On 30 Nov 2015, at 8:24 pm, 'Peter Coe' peter@coeconsult.com.au [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
