I read this article quite a while ago, and considered doing my own like Hart did. I can however force the fan on by turning on the AC (fan runs permanent with AC on), so never fitted a separate switch.
With all my playing and investigating, I don't know there is any real benefit if the original system is functioning correctly. About all it will do is turn the fan on a little sooner than the temperature switch will do anyway, and perhaps run the fan more than is necessary.
Similar to when I fitted the low temp thermostat for a short while. I can't say there are any benefits.
The only time I switch the fan on manually (eg turn on AC) is if I know the fan is about to kick in just before I turn off. I will turn the fan on before I stop so it does start up with the engine off.
Don't forget, the thermostat controls the engine temperature. Turning the fan on will not lower the engine temperature! That should always be steady
Out of interest, was very hot here in Brisbane on Saturday, with my little temp gauge reading the coolant temp coming out the radiator, it was the hottest I have seen driving at a steady speed on the highway (57degC). This was with the AC on, so the fan was running also.
I have a 2002 golf. It recently had a fault where the fan was running all the time. The control of the cooling system on these is much more complex (for example the fan speed is fully variable, not just a couple of pre-set speeds). Interesting fact is the system try's to predict your driving habits. There are a number of sensors that control this feature, but basically if it detects you driving the car for a period under heavy load, It can over ride the thermostat to lower the engine temp a little to compensate!
Getting a little further off topic, I really like these systems
In addition to full control of how the system operates, the coolant flow rate is independent of engine speed. It's a much smarter system than a belt driven pump and a thermostat.
I have a kit left over from another project, but would be a difficult install on a boxer engine,unless you tried to run dual pumps.
