wheel alignment
i have the vw official factory repair manual if you can provide me with a fax contact i can foreward the details
regards bob dale
Be aware that some earlier versions of the manual did NOT have the specific Syncro alignment figures.  If you haven’t got the pages I listed (44.3a & 44.5), you haven’t got the Syncro specific numbers
From: Syncro_T3_Australia@yahoogroups.com [mailto: Syncro_T3_Australia@yahoogroups.com ] On Behalf Of Bob Dale
Sent: 06 November 2009 10:28
Subject: [Syncro_T3_Australia] wheel alignment
regards bob dale
Thanks Bob,getting my new tyres on Tuesday,so those W/A details are greatly apprieciated.My work fax is 9525 3696.Attention it to me so I will get it.Thanks again
> regards bob dale
You could always print it out from your father's computer.
> > regards bob dale
I have been up to my ears in other things recently and have just tuned in to the wheel alignment discussion.
The Syncro Wheel Alignment details, as collated by Derek Drew, already appear in the Files section under the title:
Syncro Alignment Derek Drew.pdf
I have also added a new folder: Syncro Wheel Alignment, which contains scans of the two relevant pages from the manual.
Thanyou everyone,got the specs now.Phill wasnt aware it was on Dads computer.
> > --- In Syncro_T3_Australia@yahoogroups.com, "Bob Dale" <rcdale@>
> > > regards bob dale
Hi
Tom Mischler from  Belgrave Melbourne
I am new to the forum - thanks for the good info.
I met the syncro  folks @ the DoVW last year.
I do have a 1990 Syncro camper conversion with 138k km X St John's ambulance which I have owned now for 10 years.
My problem is uneven tyre wear @ the front left-- outside more worn than  inside. Right hand side is OK.
I am sure that this has been discussed before  - any pointers?
Has anybody got the alignment specs or knows of some one who does good alignments in Melbourne's outer east?
Cheers Tom
Hi Tom ,check files on this forum there is domething there Regards Pete
--- In Syncro_T3_Australia@yahoogroups.com, Thomas Mischler <energysustained@...> wrote:
> Hi
> I do have a 1990 Syncro camper conversion with 138k kmX St John's ambulance which I have owned now for 10 years.
> Cheers Tom
Tom,
You will find the specs in Files under Syncro Wheel Alignment.  Don’t let anyone tell you that it is the same for the 2WD T3 – it isn’t!
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Thomas Mischler
Sent: 12 January 2012 17:21
Hi
Has anybody got the alignment specs or knows of some one who does good alignments in Melbourne 's outer east?
Cheers Tom
Tom,
I meant to add that it pays to print the spec sheet and take it to whatever aligner you go to so that they have the right numbers in front of them.
Beware that some alignment machines have settings programmed into them; whilst some will have the 2WD T3, none will have the correct Syncro settings.  The specs in the Files are from Bentleys.
Sent: 12 January 2012 19:08
Subject: RE: [Syncro_T3_Australia] wheel alignment
Tom,
_,_._,___
