----- Original Message -----From: plander@optusnet.com.auSent: Tuesday, February 24, 2009 5:39 PMSubject: Re: Re: [Syncro_T3_Australia] Ignition Switch - Help
> I was unaware that there might be differences in the RH drive Syncros.
> Is there any such thing as a diagram for them?
Yes, they are in those Blue/Orange genuine VW manuals.
Some of the stuff would be in the Haynes or Peter Russek manuals.
The wiring that I was
> referring to is at the battery positive terminal. Bentleys shows the
> starter cable and one 6mm. Mine has an additional 6mm on it but this
> might have been part of the Trakka wiring.
Sounds like Trakka.
> Everyone,
> What is the best way to clean corrosion off wiring terminals? There is
> something in the back of my mind but I can't drag it up.
What terminals do you want to clean?
Accessable = emery, steel wool, scotchbrite, wire brush, Brasso, Ajax
Inaccessable = spray contact cleaner
Corrosion:
Specifically the wires at the positive
terminal. The insulation on each has peeled back a bit and there is copper
oxide on them/ through them and I would like to get it out and reseal
them.
Blue/Orange manuals:
The ones I have do not have a wiring diagram.
They do show three wires at the positive end of the battery but they don't show
the third wire actually connected to the terminal. These three are
marked:-
1. Wire from battery to starter
2. Wire from battery to junction box
3. Wire to fuse/relay plate, terminal
30.
