Worn flywheel end float
Hey Guys , I have a wbx 2.1 that has the bearing surface worn and appears the wear is not even across the surface as you can feel a slight lip about 4 mm from the outer edge.
 The shims appear fine any hints on how this occurs.
 The only force I can think of is the clutch pressure plus general wear from dirty oil etc.
 Anyway im after a flywheel to suit the 2.1 wbx if anyone has one and I am on the sunshine coast
Cheers Guys Pete seq
