---------- Forwarded message ---------
Date: Thu, 15 Aug 2019, 14:42
Subject: 1991:Syncro Caravelle for sale with rear diff lock
To: Philippe Tyack <philtyack@gmail.com>
After 9 years it's time to sell my trusty tintop Syncro (ex Roger Bell)Just completed a 3000km trip up North to Carnarvon and surrounds.Ran without a hiccup
Colour: Flash silver
Alpine cd receiver with bluetooth and amplifier
Rego till 11/01/2020
Tinted windows
5 X Steel Mercedes rims with BFG 215/75/15 tyres (about 50%)
0il and filter changed and tyres rotated every 5000km
Original 2.1 water-cooled wbx with 180000km
New clutch kit at 177000km (invoice)
Replaced: Rear main and flywheel O ring (invoice)
Clutch slave cylinder (invoice)
Rear diff lock actuator Invoice)
Old Man Emu shocks
Front lifting spacers from Syncro services
Duel fuel tank with fuel gauge
Rear diff lock
VC working
Van Cafe Oil pressure gauge
Spot lights (Rusty on top)
Fan over ride switch
Replaced:
Rear muffler
Tie rod ends
Urethane lower control arm bushings
Bosch fuel pump
Bosch distributor
Bosch Plug leads
Vacuum operated throttle position switch (TPS)
Oxygen sensor
Water pump
Go Westy gear reduction starter
90% of water hoses replaced (Have the rest as spares)
A/C not working ,removed compressor due to gas leak,all components are on vehicle.(compressor in garage)
Rear heater removed due to leaking rear radiator core.All components available for reinstallation
Both seats are available and in good nick( one head rest slightly damaged and one missing)
Awning with Annex and mosquito net
Roof racks
Battery box with 100amp/h AGM battery
Projecta 12v to 12v 3 stage 20amp battery charger
Spares: (New)
Set of front brake pads
Balance of water hoses
2 x Sets front coil springs
1 x Regulator
2 x V belts
2 x Outer cv boots
4 x Inner cv boots
3 x inner cv joints
1 x accelerator cable
1 x set rear wheel bearings
1 x Just Kampers Sliding door window seal
1 x JK Side window seal
1 x JK Rear side window seal
1 x Interior lamp lens
1 x Water reservoir cap (Blue)
Spares (Used)
1 x Stainless Steel muffler
1 x refurbished and balanced drive shaft
1 x ECU
1 x Fuel pump
1 x Distributor
1 x Oxygen sensor
1 x Plug lead set
Price is $18000.00
I live in Perth ,WA
Please call if interested - 0450059162
