2.1 syncro WAS RUNNING now wont start
Hello group,
I just recently purchased my 89 syncro and it has been running great
starting first time every time. However after leaving it sit in the
shed for a few days I started it up to find it had a sort of sticky
lifter noise. Being the mechanical minded kinda blokes we are we
pulled the rocker cover off the left side and had a look. Put it all
back together and then nothing. Turns over, has spark, has fuel, just
wont kick over. Doesn't even back fire up the pipe as if its a timing
issue. Unplugged battery for a while to see if it "restarted the
computer". . Any help would be great as I'm in Brisbane, 20 yrs old
and had plans to take this sweet heart to Tasmania by boxing day for 3
weeks. . . .
Many Thanks..
My phone is 0438253274 also.
Bart
Bart,
A bit of lifter noise after sitting for a few days is normal, it usually goes away after heading up the road a bit.
If you pulled the rockers off you must make sure you seat the push rods back into the lifters properly or you will damage the retaining clips on the lifters and you could damage or bend a push rod on start up.
Not sure about your starting problem, you didn't knock of a wire or something off the coil? earth wire?.
Good luck with it
Dave
Sent: Sunday, December 21, 2008 5:45 PM
Subject: [Syncro_T3_Australia] 2.1 syncro WAS RUNNING now wont start
Hello group,
weeks. . . .
Many Thanks..
Bart
Checked by AVG - http://www.avg.com
Version: 8.0.176 / Virus Database: 270.9.19/1859 - Release Date: 12/20/2008 2:34 PM
Hi Dave
We managed to get the push rods back into the lifters correctly.   I disconnected the coil wire from the dizzy whilst I cranked the motor to make sure all the rockers were operational.  Whilst I cranked the motor, would any arching in that coil wire being disconnected have cause the computer to go into limp mode? ? cause that's all we can believe must have happened.
Whilst searching hi and low in the engine bay for a missing earth however, i do see a blade connection on the edge of the dizzy cap but don't recall any wire ever being attached to that connection (and it doesn't look like its been of any use).  Should there be a blade earth connected to the side of the dizzy cap? ?(anyone with an original 2.1 setup) bearing in mind that we have spark at the plugs, plenty of fuel pressure at each cylinder, we did not touch distributor timing, or anything else other than remove and replace a rocker shaft, 4 push rods and crank the motor with the coil wire disconnected.
 Bart
P.S i just went down to take a photo of this blade earth on the side of the dizzy and it fired up as if it was going to start. Then it just went back into cranking over mode. ALMOST GOT IT !
Sent: Sunday, 21 December, 2008 5:26:47 PM
Subject: Re: [Syncro_T3_Australia] 2.1 syncro WAS RUNNING now wont start
Bart,
Good luck with it
Dave
Subject: [Syncro_T3_Australi a] 2.1 syncro WAS RUNNING now wont start
Hello group,
pulled the rocker cover off the left side and had a look.. Put it all
weeks. . . .
Many Thanks..
Bart
Checked by AVG - http://www.avg. com
Hi Bart,
It sounds like your hydraulic lifters are out of adjustment – probably the valves are not closing properly. To adjust them you need to back off the adjusting screws so that the push rods are free. Then with engine at TDC turn, on the appropriate cylinder, the adjusting screw in until it just touches the valve stem and finally turn clockwise the screw by 2 turns. Repeat for each cylinder. After the engine is started, run it for some time so that the lifters become primed properly (clatter sound diminished) then repeat the adjustment process.
All the best
Yurik
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Bartley Olsen
Sent: Sunday, 21 December 2008 5:45 PM
Hi Dave
 Bart
Bart,
Good luck with it
Dave
Hello group,
weeks. . . .
Many Thanks..
Bart
If it is of any help - i seem to find the old donk  benifits from a new set of leads about every 16 months -  i seem to always drop a cyl which makes the old girl a little harder to start.
Its cheap as: change the plugs, leads rotor and cap
Look at it this way -  it cant hurt
All the best
Hamish
Sent: Sunday, 21 December, 2008 6:44:52 PM
Hi Dave
We managed to get the push rods back into the lifters correctly.   I disconnected the coil wire from the dizzy whilst I cranked the motor to make sure all the rockers were operational..  Whilst I cranked the motor, would any arching in that coil wire being disconnected have cause the computer to go into limp mode? ? cause that's all we can believe must have happened.
 Bart
Subject: Re: [Syncro_T3_Australi a] 2.1 syncro WAS RUNNING now wont start
Bart,
Good luck with it
Dave
Hello group,
weeks. . . .
Many Thanks..
Bart
Bart,
No wire goes on there, mine is the same. How is the Battery, is it cranking over fast enough?
Dave
Sent: Sunday, December 21, 2008 7:44 PM
Hi Dave
 Bart
Bart,
Good luck with it
Dave
Hello group,
weeks. . . .
Many Thanks..
Bart
Bart,
Also taking off the coil wire would not effect anything on the computer, these things don't have a limp mode.
I'm thinking the engine is a bit flooded and the battery is now low and not cranking fast enough to start it. Jump start it from another car and see what happens.
Dave
Hi Dave
 Bart
Bart,
Good luck with it
Dave
Hello group,
weeks. . . .
Many Thanks..
Bart
> hamish dobson <dobson_hamish@yahoo.com.au> wrote:
> If it is of any help - i seem to find the old donk�� benifits from a new
What leads are you using?
VW leads nearly last forever.
Bart
Look in the files section under digifant fault finding.
There is a document that lists most of the causes for not starting or
erratic behaivour. The list is NOT in order and no substitute for the
manaul.
Start with the easy ones first ie: plugs and leads, earths, sensor
connections, fuel pump relay, ECU relay etc.
You have to work your way through all those items.
If someone has replaced the plugs and leads then they would almost
certainly be BERU (Not original) and they DO fail!
IF you said it had been sitting a few days, as said by others lifter
noise is normal (for a minute). Humidity could be the cause of your
problem. Most likely you have a bad connection, lead or plug.
LEADS & PLUGS: Order a new set from Vintage Vee Dub or go original if
you can afford it!
SENSORS and COIL: Get some electric cleaning solvent (such as CO
contact cleaner) and pull off each connection and spray liberally.
then work the connection a few times.
EARTHS (Engine bay on left hand side, ECU (behind back seat) BAttery
(under driver seat) Front dash (under glovebox): Remove the bolts and
clean all lugs with fine (220) emery paper and clean with solvent.
Sand the paint on the body as well. Finally after rebolting, coat all
with coldgal.
Re the ECU. My understanding is it will reset every power down. The
only thing it does differently is use another "MAP" if the O2 sensor
is crook, but that should be another topic...
Dont hesitate for more help.
Goodluck
--- In Syncro_T3_Australia@yahoogroups.com, "bartleyolsen"
<bartleyolsen@...> wrote:
> Hello group,
just
timing
for 3
> weeks. . . .
> Many Thanks..
> Bart
Have you done what Yurik said, I also belive that is where your problem is.
Alf
Will have to check (aprox $100)- what happens is the ends with the resistor go - thought its to do with all beach driving/wash down.
Sent: Monday, 22 December, 2008 6:14:48 AM
Subject: Re: Re: [Syncro_T3_Australia] 2.1 syncro WAS RUNNING now wont start
Yahoo! Groups Links
Stay connected to the people that matter most with a smarter inbox. Take a look http://au.docs.yahoo.com/mail/smarterinbox
Hello again group,
Sorry to abandon the forum, we've been working on what is a compression and lifter issue for the last three nights until midnight and have found Yurik's reply very helpful (thanking you greatly).  We managed to bleed 3 of the four lifters on the left bank and have one which is just adjustment manually.  It will probably decide to bleed its self half way to Melbourne on boxing day, so hopefully I get it adjusted right and we are back on our way again.  We've also been fitting out our own In House Trakka set up.
If anyone sees the fitted out white 89 syncro around over the next three weeks between Brisbane, Melbourne Tasmania, Sydney back to Brisbane be sure to flag us down.
Many thanks for the help once again guys.
 Bartley Olsen
On Sun, Dec 21, 2008 at 12:44 AM, Bartley Olsen <bartleyolsen@yahoo.com> wrote:
Hi Dave
 Bart
Bart,
You need to ground that coil wire anytime you try to try this operation. I have experienced a fired ECU as consequence of power surge caused by that arch you speak of. Check to see if any components got welded by the spark.
What oil filter are you using?
> Hello again group,
> Trakka set up.
> Bartley Olsen
