2.1 wbx Engine Builder
G,day
I am in search of cases and crank to suit 1989 fuel injected water cooled T3 Syncro Digifant 2.1 Ltr WBX???
Thanks Col
Hi Gaetan
I am slow on the uptake these days with all the fog around BUT are you saying you have other than the heads a servicable crank and repairable case suitable to my needs ??
col
Hi Col,
yes indeed I do. The left crankcase is the only item in need of work (to weld the crack so it doesn’t leak coolant). All the other parts are in good order including crankshaft etc.
