I'm actually in a slightly different position where I have a Syncro van with No gearbox/motor, was purchased this way. Of course I have now found out that gearboxes are almost impossible to find ! Looks like I'll also have to go with a 2wd box for the time being till I find a better offer :)
Scotty
--- In Syncro_T3_Australia@yahoogroups.com, Gary Cookson <gary@...> wrote:
> Sam, surely you'd be better off getting your syncro box rebuilt? If
> you have to go to all the trouble of dropping it out and fabricating
> parts to fit the 2wd it is not going to be that cheap plus the cost of
> fixing the syncro box in the future remains.
> You might find the syncro box only needs a new bearing or two. I think
> the major cost in most Syncro box rebuilds is when the crown and
> pinion is stuffed. I can't remember but it didn't sound like that was
> the case with yours. I know you wanted to do oil plates and taller
> gearing but maybe that bit could wait.
> Anyway, i'll shut up now...
> Good luck with whatever approach you take.
> Gary
> [2 0 / 2 1 Design]
> 28 Gwynne St
> Richmond
> Vic 3121
> gary@...
> www.twentytwentyone.net
> Tel 3 9429 1868
> Fax 3 9421 1110
> Mob 0417 352782
> On 2 Sep 2009, at 09:47, heysamuelarnold wrote:
> > Thank you so much to everyone on this forum.
> > I'm still exploring my options at the moment, and a few more phone
> > calls to make, but it is looking like I might go down the 2wd path,
> > as I have found a cheap 2wd 5-speed box. If anyone knows of a syncro
> > or 2wd 5-speed box at a good price, please get in touch.
> > Bill, Martin, is this custom adaptor plate the only modification
> > required? It bolts on?? Bill, I may definitely take you up on the
> > offer to copy your adaptor plate.
> > Boris from Volkscare who said he has done this conversion said he
> > cut the rear mount off his syncro? I don't like the idea of cutting
> > my precious van.
> > Will give you all an update as I progress.
> > Sam
> > --- In Syncro_T3_Australia@yahoogroups.com, "muddy3267"
> > <marg_bill@> wrote:
> > > Sam. I ran my syncro with a 2wd box while my 4wd box was being
> > rebuilt. I have the adaptor plate fabricated by my very capable vw
> > mechanic. If you wish i could send it to you to copy and return.
> > Regards Bill Sullivan.
28 Gwynne St
Richmond
Vic 3121
gary@twentytwentyone.net
Tel 3 9429 1868
Fax 3 9421 1110
Mob 0417 352782
Hi All,
Scotty
> Gary
> [2 0 / 2 1 Design]
> 28 Gwynne St
> Richmond
> Vic 3121
> gary@...
> www.twentytwentyone .net
> Tel 3 9429 1868
> Fax 3 9421 1110
> Mob 0417 352782
> > my precious van.
> > Sam
> > --- In Syncro_T3_Australia @yahoogroups. com, "muddy3267"
Sent: Monday, 31 August, 2009 3:10:42 PM
Subject: [Syncro_T3_Australia] 2wd transmission into a syncro?
Hi Everyone,
I know this is sacrilegious, though unfortunately dollars to spend on my van are short at the moment, and a lot of winding noise is coming from what I assume is the transmission / diff. Best to pull it out before something breaks. And with my viscous completely passive, I am driving a 2wd anyway.
So, my question, does a 2wd 4 or 5 speed easily fit into a syncro? Just remove the prop-shaft? Do you need any other 2wd mounts or??
My plan is until I can save up some $$ and properly rebuild my box, add the taller 3rd and 4th gears and perhaps a LSD or locking diff, I will just put in a cheap 2wd box for a year or two. Which I guess leads me to my last question, does anyone know where I can get a cheap 2wd transmission? Unless of course someone knows of a cheap syncro box floating around somewhere...
Ok, sadly, thanks for your help guys,
Sam.
Find local businesses and services in your area with Yahoo!7 Local. Get started.
----- Original Message -----From: neil smithSent: Monday, September 07, 2009 10:27 PMSubject: Re: [Syncro_T3_Australia] 2wd transmission into a syncro?
Hi Sam,You may like to give Ron Schmidt a call on (02) 6562 5730. He is a VW gearbox guru, sells Albins gears and his labour charges are very reasonable. Ron specialises in kombi gearboxes used in offroad racing buggies but I know he has done Syncro boxes too and he has fitted a diff lock and Albins gears to my gearbox. He has the proper VW jigs for setting up the crown wheel and pinion so there is no guesswork. He can build it as mild or wild as you want it to be. Good idea to stop driving before something breaks as parts will be the biggest cost of the rebuild.Neil.
Subject: [Syncro_T3_Australi a] 2wd transmission into a syncro?
Hi Everyone,
Sam.
Checked by AVG - www.avg.com
Version: 8.5.409 / Virus Database: 270.13.81/2350 - Release Date: 09/06/09 17:51:00
Hi Scott,
That youtube footage is Volkers compilation of footage from the trip. I think all the participants have it on disc, but I never realized that it had been posted. Good find. It was nice to see it again.
BRIAN REED
FAIRFIELD NATURAL THERAPIES
185 Wingrove St
Fairfield, Vic. 3078
03 9481 5673 0407 319 521
Behalf Of Mr Scott Pitcher
Sent: Thursday, 17 September 2009
10:18 PM
To:
Neil,
There is a guy named Terry from Lake Illawarra NSW who wants to do a similar thing to his 74 bay kombi as you have done to yours.
His email address is:
If you are interested in pointing him in the right directions.
He has a large old Bus he is planning a round Oz trip in and is going to tow the kombi behind until he finds somewhere restrictive he wants to go.
By the way - I found this link to the Kombis to the Kape trip you did.
Maybe bring back some nice memories.
Subject: Re: [Syncro_T3_Australi a] 2wd transmission into a syncro?
Hi Sam,
Neil.
Hi Everyone,
Sam.
size=2 width="100%" align=center>
----- Original Message -----From: Brian ReedSent: Thursday, September 17, 2009 10:51 PMSubject: RE: [Syncro_T3_Australia] 2wd transmission into a syncro?
Hi Scott,
BRIAN REED
185 Wingrove St
From: Syncro_T3_Australia @yahoogroups. com [mailto:Syncro_ T3_Australia@ yahoogroups. com] On Behalf Of Mr Scott Pitcher
Sent: Thursday, 17 September 2009 10:18 PM
Neil,
Hi Sam,
Neil.
Hi Everyone,
Sam.
Version: 8.5.409 / Virus Database: 270.13.102/2377 - Release Date: 09/16/09 17:49:00
> Brian Reed <breed@bigpond.net.au> wrote:Can I get a DVD copy of that?
> had
(Pick up at DOVW)
Hi Scott,
BRIAN REED
185 Wingrove St
Neil,
Hi Sam,
Neil.
Hi Everyone,
Sam.
Hi Scott & Phil,
I discovered I don’t have it on disc, but rather on my laptop hard drive. I guess if it is posted on you-tube it is in the public domain now. Any-way I was able to copy it, and a 1000 or so pics, which you can look at (or not) if you like.
I’ll have my lap-top with me at old bar, so if any-one else wants a copy, just bring a blank DVD. (File size is ~600Mb)
Les, you might also want to post a link to the you-tube video on our site if it’s not there already. (address below).
BRIAN REED
185 Wingrove St
Sent: Friday, 18 September 2009
8:00 AM
To:
Brian,
I'd love a copy to if there is a chance of that.
Subject: RE: [Syncro_T3_Australi a] 2wd transmission into a syncro?
Hi Scott,
BRIAN REED
185 Wingrove St
10:18 PM
Neil,
Hi Sam,
Neil.
Hi Everyone,
Sam.
17:49:00
I have posted a link to the video on www.syncro.com.au as well as an approximate map of the route:
http://www.syncro.com.au/kombis-to-the-kape-preview-T3-Syncros-to-Cape-York
Mark.
PS - just back from German Autofest in Canberra - a great day - we were the only Syncro, and at the end of the day a 2nd T3 turned up - Caravelle GL with NSW reg.
On Sun, Sep 20, 2009 at 6:44 PM, Brian Reed <breed@bigpond.net.au> wrote:
Hi Scott & Phil,
BRIAN REED
185 Wingrove St
Sent: Friday, 18 September 2009 8:00 AM
Brian,
Hi Scott,
BRIAN REED
185 Wingrove St
Neil,
Hi Sam,
Neil.
Hi Everyone,
Sam.
And, speaking of videos, this one popped up on a US Syncro group – originally from Mike Plompen:
http://www.youtube.com/watch?v=JX1iiqgkILQ
On Behalf Of Mark Kofahl
Sent: 20 September 2009 20:23
You-tube video
Brian, Les and all,
I have posted a link to the video on www.syncro.com. au
http://www.syncro. com.au/kombis- to-the-kape- preview-T3- Syncros-to- Cape-York
Mark.
