I know this is sacrilegious, though unfortunately dollars to spend on my van are short at the moment, and a lot of winding noise is coming from what I assume is the transmission / diff. Best to pull it out before something breaks. And with my viscous completely passive, I am driving a 2wd anyway.
So, my question, does a 2wd 4 or 5 speed easily fit into a syncro? Just remove the prop-shaft? Do you need any other 2wd mounts or??
My plan is until I can save up some $$ and properly rebuild my box, add the taller 3rd and 4th gears and perhaps a LSD or locking diff, I will just put in a cheap 2wd box for a year or two. Which I guess leads me to my last question, does anyone know where I can get a cheap 2wd transmission? Unless of course someone knows of a cheap syncro box floating around somewhere...
Ok, sadly, thanks for your help guys,
Sam.
