| Hello all, does anyone know if the 92 T3 syncros used by telecom had the attachment points for seating? I have a GL seat set and hope to install them to make a 7seater syncro for my family. Thanks, Toby Toby Mills Light Earth Designs P/L www.lightearthdesign.com |
Toby,
My Syncro has the Trakka conversion so my floor isn’t readily accessible but someone with no floor covering or easily lifted covering might be able to confirm that the seat anchors are part of the floor structure as they were in the T2. If they are, it is just a simple bolt-in job.
Can someone confirm this?
Syncro_T3_Australia@yahoogroups.com ] On Behalf Of Toby Mills
Sent: 14 January 2010 08:20
Subject: [Syncro_T3_Australia] 92
T3 Syncro seating attachment?
and hope to install them to make a 7seater syncro for my family. Thanks, Toby |
I'm not exactly sure about the points for seating, and am still in Melbourne atm so cannot check my van for you, but I know there was no bolt holes for seatbelts, and so for putting the rear westfalia seat in my 92 ex-telecom I had to weld in plates with nuts welded to them for things like the seat bolt z-bar etc. So pretty sure there was no bolt holes for rear seats as well.
Hope that helps, Sam.
> Toby,
> My Syncro has the Trakka conversion so my floor isn't readily accessible but
> [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Toby Mills
> Subject: [Syncro_T3_Australia] 92 T3 Syncro seating attachment?
> Toby Mills
