Looking for the perfect gift? Give the gift of Flickr!
> Michael Roberts <type500@yahoo.com> wrote:
> Hi,
> Just been removing all the old AC wiring in the course of wiring up the
> new dash and found this behind the passenger side head light (see pic).
> Who ever fitted the AC used it as a power supply and it looks as if it
> may have over heated. I just wanted to know what it was so I could
> follow it through on the wiring diagram. I also had the misfortune to
> crush my passenger side door to day with a car hoist and stairway,
> lowered the window three inches before I noticed. O well need a new door
> anyway. If any one can help with the identification it was be
> appreciated.
> Michael R
> __________________________________________________________________
> http://www.flickr.com/gift/
Sent: Mon, December 28, 2009 9:23:21 PM
Subject: Re: [Syncro_T3_Australia] AC wiring remove and unknown thing?
It could be the feed to the radiator fan.
> Michael Roberts <type500@yahoo. com> wrote:
> Hi,
> appreciated.
> Michael R
> http://www.flickr. com/gift/
resides behind the left side headlights.
Sent from my mobile device
>> Hi,
>> the
>> pic).
>> it
>> to
>> door
>> appreciated.
>> Cheers,
>> Michael R
I have those resistors too, are they giving the fan half power when it is switched to Low ?? hartmut
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Michael
Roberts
Sent: Monday, 28 December 2009 9:56 PM
Hi Phill,
That is my guess too. But I could not find in on the wiring diagram. It appears to be in the same loom as the rad fan power, so it must be related some how.
Michael R
>com/gift/
> Hi,
> appreciated.
> Michael R
> http://www.flickr.
Yes they are heater fan resistors, most non gen a/c has a separate fan on t3. Mine has three speeds therefore needs two resistors for lower speeds. Greg--- On Mon, 28/12/09, Hartmut Kiehn <hartis@live.com.au> wrote: |
See what's on at the movies in your area. Find out now.
I know about the two speed radiator fan but not three speed. Bentleys 19.12 lists the cut in and cut out temperatures of Stage 1 and Stage 2.
My fan has only ever run at full speed since I bought the Syncro and I will have to go looking for the resistor, which Ben Tan tells me is behind the LH headlight. It tends to frighten anyone within earshot when it cuts in, particularly if I have stopped at a pedestrian crossing!
On Behalf Of greg esposito
Sent: 29 December 2009 13:54
Yes they are
Can someone with a knowledge of the electrical system please tell me the function of J101, Radiator cooling fan relay2nd stage, on Bentleys 97.82. Does that trigger the radiator cooling fan thermoswitch or is it the other way around? I am trying to understand how the two speed fan system works.
On Behalf Of Les Harris
Sent: 29 December 2009 14:16
Syncro_T3_Australia @yahoogroups. com
[mailto: Syncro_T3_Australia @yahoogroups. com ]
Subject: RE: [Syncro_T3_Australi a]
Yes they are
On Dec 28, 2009, at 7:16 PM, "Les Harris" <leslieharris@optusnet.com.au> wrote:Greg,
Les,It sounds to me like Greg is talking about his heater fan rather than the radiator fan.Every post-86 model US-spec Vanagon I've ever owned has that fan resistor.BenT
not heater or radiator fan but non genuine a/c fan.Is this not part of what Micheal is removing. Greg--- On Mon, 28/12/09, BenT Syncro <syncro@gmail.com> wrote: |
Becomes more interesting as I never had any a/c installed and still have those resistors installed. What now? I will have a close look tomorrow. hartmut
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of greg esposito
Sent: Tuesday, 29 December 2009 7:27 PM
On Dec 28, 2009, at 7:16 PM, "Les Harris" <leslieharris@ optusnet. com.au> wrote:
Sorry guys my mistake I thought michael was saying he removed that resistor as part of his old a/c. It must be the heater fan resistor or the rad fan resistor. Away on holidays and unable to check. Greg--- On Tue, 29/12/09, Hartmut Kiehn <hartis@live.com.au> wrote: |
Sent: Tue, December 29, 2009 2:38:15 PM
Subject: RE: [Syncro_T3_Australia] AC wiring remove and unknown thing?
Yes they are
Make your browsing faster, safer, and easier with the new Internet Explorer® 8. Optimized for Yahoo! Get it Now for Free!
Slow speed cuts in at 95 and is wired through a series resistance behind the headlight.
Fast speed (stage 2) is through the radiator fan stage 2 relay and supplies a full 12 volts to the radiator fan at 105 degrees by bypassing the resistors. These fans draw too much current to be run through the fuse box on high speed.
The seperate fan relay replaces J101 which is just a standard 30A relay.
> 97.82.
> other
> works.
> [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Les Harris
> Greg,
> 19.12
> will
> the LH
> on
> speeds.
> Greg
> <http://ca.toolbar.yahoo.com/> !
> <http://geo.yahoo.com/serv?s=97359714/grpId=13267315/grpspId=1709926240/m
> sgI
> d=7534/stime=1262055252/nc1=3848621/nc2=5741391/nc3=4836036>
Phill and Michael,
Now it is starting to make some sense! Thank you both. It is easy to misinterpret what’s going on when it is so hard to determine what is Syncro specific in the wiring diagrams.
Sent: 30 December 2009 08:05
Subject: Re: RE:
Most
Australian spec syncros have the large fan with the seperate wall mounted
relay. (See Bentley 97.200)
headlight.
> Phill and Michael,
> misinterpret what's going on when it is so hard to determine what is
> Syncro
> Subject: Re: RE: [Syncro_T3_Australia] AC wiring remove and unknown
> thing?
> Most Australian spec syncros have the large fan with the seperate wall
> mounted relay. (See Bentley 97.200)
> headlight.
> supplies
> box
> on high speed.
