I've attached a cooling system diagram from RJES.
Not sure of your cooling system but this is basically the same as the small car version.
I dont know any mechanics good with Suby conversions in Adelaide but at least you can show them this.
Have you had the heater on while trying to bleed the system?
Does your conversion have the heater by-pass system?
This is the filling procedure which has some good hints.
http://rjes.com/html/filling_procedure.html
Best of luck,
Hi there I'm heading to through Adelaide and a mechanic to sort out cooling system probs in the van.A familiarity with Subaru conversions might help. Any recommendations ?
Pushes coolant into the expansion tank but was recently tested as not having combustion gas in the coolant system. Can't get it to bleed properly and then the thermo fan cut out after one of my bleeding attempts.
Made it to Ceduna so far what a trip..
But then we have these vans for adventure right ?
Hope your further travels are issue free.
Hi Scott ,
thanks for that. Solved the bleed problem in Ceduna with $20. A bit of pipe 700 mm long and rubber to fit on the expansion tank and sit up higher than the front bleed valve. Fill up pipe, run with the heater on and hey presto all air gone. Known as the libby bong method.
Still have a CV issue from a dodgy mechanic. Minor problems now.
Roll on baby happy days !
Courtesy of Gerry & Robyn.
https://drive.google.com/file/d/1bwvvCIu9OzzP-7D-SX2gXWsYjMdudxk5/view?usp=drive_web
Video of DOVW in Vic 2018.
On 30/01/2019 9:16 pm, Scott Pitcher wrote:
> DOVW Stuff.
> Scott
Another video of the DOVW 2018 - this time the convoy. Again courtesy of
Gerry & Robyn.
Hope it works....
https://drive.google.com/file/d/1XHr94jtuExDPCv82GGGgcXYMj9JOqnnR/view?usp=drive_web
On 30/01/2019 9:28 pm, Scott Pitcher wrote:
> Hopefully this works.
> Scott
>> DOVW Stuff.
>> Cheers,
>> Scott
Worked for me.
Again,
Gerry & Robyn.
Hope it works....
> Scott
>> DOVW Stuff.
>> Cheers,
>> Scott
Great lineup!
Alex
And all those other syncronauts that made it happen on the day.
It was a great event put on by the Volkswagen Club of Victoria.
Gerald
Again,
Gerry & Robyn.
Hope it works....
> Scott
>> DOVW Stuff.
>> Cheers,
>> Scott
Thank you for the photo and video, brings back memories.
From: Syncro_T3_Australia@yahoogroups.com <Syncro_T3_Australia@yahoogroups.com>
Sent: Wednesday, 30 January 2019 9:50 PM
Subject: Re: [Syncro_T3_Australia] Re: DOVW Victoria 2018 - Photo
Thanks Scott........and also to the teenagers in your house that worked it out.
Gerald
