I have now been asked to check with you guys (the syncro experts) by my mechanic before he continues!
Apologies for my lack of understanding of the insides of gearboxes etc.
As follows.
I am changing my non-locking petrol transmission to a diesel locking transmission - same final drives. Do I simply need to change over the bell-housing?
The mechanic has noticed that the spigot shaft on the diesel box appear 10mm shorter - is this an issue or can this be ignored? He said it seems this can be ignored, there should still be enough room for the flywheel, but said to check with you guys.
So... is it as simple as changing the bell-housing, as I believed, or is there more complexity in changing the transmission than I understood?? Does the spigot shaft need to be taken from the old gearbox, and tips on doing this?
Apologies if I lost anything in translation here. And thanks to this group for all your help, you guys are great.
Sam
