Australian & South African VW Silver Sticker Info
Australian & South African VW Van/Bus Lists,
In the US, we are having a spirited discussion around a tire report I just
published.
http://www.roadhaus.com/Tires/Guideline.html
One question has come up several times.
"What tire requirements do the South African & Australian Vans have.
If you would like to send me similar data .... I'd be glad to summarize and
publish it in the same manner.
P/S ... I believe the "Silver Stickers" are a US requirement ... But you
must something that documents these requirements.
Here's a few tables I built summarizing the US requirements
Silver Sticker Info 2WD vs 4WD by Year & Tire Size
http://www.roadhaus.com/Tires/Silver%20Sticker%20Info.html
VW Vanagon Original Equipment Tires 1984 - 1991
http://www.roadhaus.com/Tires/VW%20Vanagon%20Original%20Equipment%20Tires%20
1984%20-%201991.html
OE Tire Load Inflation Table
http://www.roadhaus.com/Tires/OE%20Tire%20Load%20Inflation%20Table.html
good tires,
larry chase
www.roadhaus.com
www.roadhaus.com/shops.html
www.roadhaus.com/tires.html
Larry,
Australia has Australian Design Rules (ADR's) which cover just about
everything for new and used vehicles. I will copy the relevant
ADR's and send them to you. If you can supply a direct e-mail
address, I will send them straight to you.
Les Harris
--- In Syncro_T3_Australia@yahoogroups.com, "Larry Chase"
report I just published.
summarize and publish it in the same manner.
