I would like as many details as possible including price, lifespan and any problems. eg
Federal 691MF DIN65L Silver Calcium $290 Lifespan 7 years (requires ledge spacer) Recommended
Delkor DIN66D $176
I will post the details on my web.
> greg esposito <gregespo73@yahoo.com> wrote:Hey Phill, mine recently died and I replaced the din66 with a mf55 gold from here.
--- In Syncro_T3_Australia@yahoogroups.com, "hdvwoc" <plander@...> wrote:
> I am compiling a list of suitable batteries and would like some data
> from syncro owners for standard fitment batteries. The original battery
> is a DIN66L (191 915 105M) although the smaller capacity DIN55 is
> usable. The maximum height is 175mm. This is the problem.
> any problems. eg
> Delkor DIN66D $176
> davidleibmann <davidleibmann@yahoo.com.au> wrote:
> Hi Phill,
> Mt 1990 Trakka Syncro has a CCA500 RC90 that fits neatly under drivers
> seat. A 12 Volt Deep Cycle DC5 90AH encased under rear seat. Both
> batteries have performed problem free in the year I have owned the van.
> Sorry no other details on when and for what cost they were installed
> for.
> Cheers Dave
> battery
> > any problems. eg
> > Delkor DIN66D
> $176
> > Phill
Hi Phill. I just replaced my starter battery with the same one that had been in the vehicle for over 5 years. It is a SuperCharge Gold MF66. 277x175x175. Fits very neatly in the battery cavity and is held in place by the L shaped bracket. 3 year warranty. Cost me $180 from Autobarn who are the local agents.
I also recently installed a Varta 956002 deep cycle battery. Put in a swivel seat to get some more height but the passenger seat still does not go back all the way. Have it hooked up to the car battery with a traxide unit to prevent discharge of the car battery. Peter from Port.
> Dave,
> Do you know the brand?
> > davidleibmann <davidleibmann@...> wrote:
> > Hi Phill,
> > for.
> > Cheers Dave
> > --- In Syncro_T3_Australia@yahoogroups.com, "hdvwoc" <plander@>
> > battery
> > > any problems. eg
> > > Delkor DIN66D
> > $176
> > > Phill
> Dave,
> > Hi Phill,
> > for.
> > Cheers Dave
> > battery
> > > any problems. eg
> > > Delkor DIN66D
> > $176
> > > Phill
Thanks for this Phil -could I remind members that the rest of your site is well worth a look.
In particular the dimensions for front CV joint protectors is most useful for me as I noticed some time ago that both mine, which were part of the attraction of buying my vehicle, had been cut off just below the rivetts. To quote Craig Robertson I just can't explain what happened. I can only guess it happened to facilitate a repair or perhaps during a wheel alignment. Seems I should take a leaf from Hart's book and spend more time under my vehicle.
Anyway thanks to your site I now have the dimensions to buy suitable replacement rubber so I am much obliged.
Melbourne
--- On Thu, 21/6/12, hdvwoc <plander@optusnet.com.au> wrote:
Mark,
T3 batteries, including Syncro, last at least as long and frequently longer than batteries installed in an engine bay; this is due to the sheltered environment compared with the thermal assault in the engine bay.
You appear to have a specific problem with either under-charging and/or a serious parasitic drain. Start with measuring the alternator input when running and also check to see if there is any drain with everything shut down.
As a side issue, battery terminals should always be kept shiny clean and coated with petroleum jelly.
Behalf Of mark
Sent: 27 August 2012 13:12
To:
Batteries
Hi Folks,
My last two batteries have only lasted 12 months ( replaced under warranty ).
They're never run flat, and seem to be fine until dying a rapid death in
winter.
Is there a known issue with Syncro's where they don't charge properly but the
alternator light doesn't show ?
I have a deep cycle battery that's linked to a 20w solar panel on my roof to
prolong
it's life expectancy. Can I hook up the starter battery to this system also ?
Runs through
a controller.
Part 2:
A Syncro system, running to spec, does not need supplementary input.
Because my Syncro does not get much running, I regularly bring the battery up to 100% via a smart charger. Smart chargers are expensive but, in my case, I have resurrected a number of otherwise dead batteries.
Behalf Of mark
To:
Batteries
Hi Folks,
winter.
20w solar panel on my roof to prolong
its life expectancy. Can I hook up the starter battery to this
system also ? Runs through a
controller.
----- Original Message -----From: markSent: Monday, August 27, 2012 1:11 PMSubject: [Syncro_T3_Australia] BatteriesHi Folks,
They're never run flat, and seem to be fine until dying a rapid death in winter.
I have a deep cycle battery that's linked to a 20w solar panel on my roof to prolong
it's life expectancy. Can I hook up the starter battery to this system also ? Runs through
a controller.
| Reply via web post | Reply to sender | Reply to group | Start a New Topic | Messages in this topic (19) |
