Nothing is ever easy on the Syncro. Started a little maintenance on the Syncro after old bar. The front brake pads have been getting low for a while and figured it's time to change them, and look at a few other jobs I'd had planned at the same time as the brakes were due for bleeding also. The discs are like new, so have left these. And I wanted to change the brake hoses at the same time.
Well, of course it's never that easy. I have not had to touch the front brake pads yet. How do you remove them?? Of course our calipers are different to what they have in the US, so not shown in the Bentley, and most youtube video's are for the US style calipers.
Eventually figured how to remove the pins holding the top half of the caliper in place ( allen key bolt under the rubber boot)
The size was 7mm, which of course no std allen key set has a 7mm key!
Anyway, that job is done. Looks like the rebuild kit for the front calipers are not right also, so have to get the correct kits now!
Next was the hose (new stainless braded). The anchoring point to the body is very limited in room, so took ages to remove and re-install.
Couple of pictures attached.
Anyone have an old set of calipers they would sell? That way I can swap over and re-build them at my leisure.
Not critical, but would make life simpler.
