I have the same set-up and with the big wheels (235 x 75 x 15 tyres) and heavy syncro camper I think you need that lower 4th gear overdrive ratio to get up the hills of which there are plenty around Oz.
I've left ratios standard after the Subi 2.5 conversion, running 235/75/15 tires.
Wouldn't change it even though she sits on about 3800 rpm @110kmh.
Means you're not constantly changing gears going uphill, and that power is handy when fully loaded.
Economy still seems reasonable, better than stock.
My two bobs worth.
Something else to consider is economy. I have stock gearing and 2.1 engine, but run two sets of tires. Commercial road tires 3% smaller diameter than original (205R14), and 4WD tires 3% larger.
Definitely change down more often with the 4WD tires, especially if the AC is on, but interestingly the fuel economy is the same at ~8.3-8.5km/L for both sets of tires (based on km reading of the speedo).
So with the difference in diameter, the fuel economy is ~6% better with the larger tires!
That’s amazing - 11.07L per 100km. The best I ever got was about 14L per 100km.
Must have a well tuned engine. Good on you.
Sent: Monday, 25 September 2017 4:25 PM
Subject: Re: [Syncro_T3_Australia] Re: Gearbox Service/Rebuilders
I always thought I was getting smashed by running huge wheels and tyres.
I bet the big wheels would cost you more if you drove only through one of the big cities every day and no freeway.
But maybe a mix of both works out in our favour?
I have to say my manual T3 caravelle is not great on fuel and it runs tyres slightly smaller than the original by using 215 x 60 x 16's on Merc alloys.
My syncro with the Suby 2.5 now get much better economy that a 5 speed 2wd???
Crazy I know...
On Mon, 25 Sep 2017 at 9:07 PM, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]<Syncro_T3_Australia@yahoogroups.com> wrote:Very interesting observation.
Crazy I know...
I cant work out how....
Believe it or not Scott my syncro camper gets better km's than my 5speed caravelle did too.
On Mon, 25 Sep 2017 at 9:07 PM, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]Very interesting observation.
Crazy I know...
On Tue, 26 Sep 2017 at 1:41 PM, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]<Syncro_T3_Australia@yahoogroups.com> wrote:Very interesting.
On 25/09/2017 10:31 PM, Nils Birkmann nilsbirkmann@yahoo.com [Syncro_T3_Australia] wrote:
Crazy I know...
