buzzing
Hi there,
Our Syncro has developed a 'buzzing' noise, which appears to be emanating from within the dashboard (?). It happens intermittently while driving along at speed and sounds like a mini-swarm of angry bees. Anyone have any ideas about what might be causing this? It made for rather an annoying soundtrack over the Easter weekend.
Francesca.
Was the ventilator fan running?
Sent: 06 April 2010 17:28
Subject: [Syncro_T3_Australia] buzzing
Hi there,
Francesca.
Hi Les,
No, it wasn't. At first I thought it might be a gum leaf stuck in the ventilation system, but I checked and the fan was off.
Francesca.
On Tue, Apr 6, 2010 at 5:34 PM, Les Harris <leslieharris@optusnet.com.au> wrote:
Hi there,
Francesca.
I had a similar problem caused by the plastic cowl that is the instrument cover/access point to the master cylinder. I solved it by bending the metal clips to be a little tighter and putting a smear of grease on them.
Yours may be different of course. Before the above solution i used to give it a bit of a thump and the buzzing would stop.
There are a few relays in there, could it be one of those? More serious obviously if the latter.
Gary
On 06/04/2010, at 5:27 PM, Francesca Coles wrote:
Hi there,
Francesca.
Thanks, Gary. We'll investigate further on the basis of that.
Francesca.
On Tue, Apr 6, 2010 at 5:38 PM, Gary Cookson <gary@twentytwentyone.net> wrote:
Gary
Hi there,
Francesca.
Sounds like the dynamic oil pressure warning.
If the oil pressure is low, the buzzer operates over 2000 rpm.
This could be serious.
> Francesca Coles <fcoles6@gmail.com> wrote:
> Hi there,
> emanating
> along
> ideas
> soundtrack
> Thanks,
> Francesca.
Hmm, thanks. Will definitely investigate further.
> Hi there,
> emanating
> along
> ideas
> soundtrack
> Thanks,
> Francesca.
We had a new oil pressure switch installed back in January, and the noise developed thereafter, so perhaps I should be taking it back to the mechanic to check that the installation was correct? Any thoughts on this?
Francesca.
> Hi there,
> emanating
> along
> ideas
> soundtrack
> Thanks,
> Francesca.
Yes, there is a 99% chance that the mechanic has used the incorrect oil pressure switch.
This has become very common as these meatheads do not understand electrics.
There are two oil pressure switches on later VWs.
A low pressure which operates as normal by completing the circuit when the oil pressure is low and a higher pressure dynamic oil pressure switch which open circuits at under pressure and sounds the alarm over 2000 rpm.
A false alarm could also be a loose connection somewhere between the oil pressure switch and the circuit on the dash.
You could also have an engine problem (wrong oil filter, engine wear etc)
> noise
> mechanic
> Thanks,
> Francesca.
> >> Phill
> >> > Francesca Coles <fcoles6@gmail.com <fcoles6%40gmail.com>> wrote:
> >> > Hi there,
> >> > emanating
> driving
> >> > along
> any
> >> > ideas
> >> > soundtrack
> >> > Thanks,
> >> > Francesca.
All,
The attached article may shed some additional info for all concerned.
Date: Wed, 7 Apr 2010 09:02:12 +1000
Subject: Re: Re: [Syncro_T3_Australia] buzzing
> noise
> mechanic
> Thanks,
> Francesca.
> On Wed, Apr 7, 2010 at 7:13 AM, Francesca Coles <fcoles6@gmail. com>
> >> Phill
> >> > Francesca Coles <fcoles6@gmail. com <fcoles6%40gmail. com>> wrote:
> >> > Hi there,
> >> > emanating
> driving
> >> > along
> any
> >> > ideas
> >> > soundtrack
> >> > Thanks,
> >> > Francesca.
Thanks, Ken, for that article. It sounds like potentially a tricky problem to get to the bottom of. I'm going to start by taking it back to Volkwerke, because they installed the new oil pressure switch, and with their VW experience should know how to do this correctly.
Francesca.
On Wed, Apr 7, 2010 at 9:06 PM, Ken Garratt <unclekenz@hotmail.com> wrote:
All,
> noise
> mechanic
> Thanks,
> Francesca.
> >> Phill
> >> > Hi there,
> >> > emanating
> driving
> >> > along
> any
> >> > ideas
> >> > soundtrack
> >> > Thanks,
> >> > Francesca.
Sorry to bother you with my buzzing again, but I forgot to mention that the intermittent buzzing has not been accompanied by the oil pressure warning light coming on at any stage. The light is working, as it lights up normally when the ignition is turned on. Wouldn't the light normally light up as well when the buzzer sounds if there was a genuine oil pressure problem??
Francesca.
Francesca.
All,
> noise
> mechanic
> Thanks,
> Francesca.
> >> Phill
> >> > Hi there,
> >> > emanating
> driving
> >> > along
> any
> >> > ideas
> >> > soundtrack
> >> > Thanks,
> >> > Francesca.
> warning
> normally
> well
Probably.
To test the circuit, pull the wire from the high pressure oil switch.
Start the engine (no buzz, no light)
Rev the engine to over about 2000 rpm. The buzzer and light should operate.
Thanks, Phil.
I think we might look into installing an oil pressure gauge on the dash. Sounds like a good idea to me, given that false warnings seem to be a bit of a bugbear. Have others out there done this?
Francesca.
> warning
> normally
> well
Probably.
If you fix it properly, it will be very reliable. The same system is used on all Volkswagens and Audis since the late 80s.
I would not have an oil pressure guage due to the distance from the engine.
> Thanks, Phil.
> bit of
> Francesca.
> > > warning
> > > normally
> as
> > > well
> > Probably.
> operate.
Francesca,
I installed a temperature and pressure gauge in my van and it works fine.
Phil is right that it is a long distance and there is always a niggly feeling
how accurate the instruments are. However, the numbers matched as per Bentley.
Anyhow, you can have a closer look at our Sunday meeting.
Thanks, Theo. See you on Sunday.
Francesca.
On Mon, Apr 12, 2010 at 9:23 PM, Theo Weiss <teows@melbpc.org.au> wrote:
Francesca,
