changing gear oil
hi Everyone
thanx so much for all the help on the oil capacities and types.
this is going to sound stupid but here goes.
are we talking about the manual gear box?? not the front axle
differential??
my owners manual says frnt diff doesnt need ckecking or changing???
so i'm assuming, which i know what makes me, which is why im asking: we
are all talking about the gear box??
if anyone has a diagram of where tghis is the fill and the drain i
would greatly appreciate it heaps
thak you very much in advance
You all are the greatest and thanx Les for the site
Robert waiting to get very dirty
Robert,
Yes, we are talking bout the gearbox, not the front diff.  I will send you some illustrations.
Sent: Monday, October 13, 2008 9:51 AM
Subject: [Syncro_T3_Australia] changing gear oil
hi Everyone
differential? ?
Yes, manual gearbox. The drain is on the bottom, the fill is on the driver's side of the box about half way up.
Clean thoroughly around both and make sure you can get them both slackened before removing. That way you don't end up draining all the oil out and finding you can't undo the fill!
Front axle diff uses a different oil (GL5) and should also be checked for level. Worth changing if you don't know the history I imagine.
Gary
[2 0 / 2 1 Design]
28 Gwynne St
Richmond
Vic 3121
gary@twentytwentyone.net
www.twentytwentyone.net
Tel 3 9429 1868
Fax 3 9421 1110
Mob 0417 352782
On 13/10/2008, at 9:51 AM, mmultihull1 wrote:
hi Everyone
differential? ?
